Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Hard drive on Bizhub 350
I would like to install a hard drive on my Bizhub 350 and am wondering if 40GB is the limit, and how to do it. Wether it is a IDE or SATA drive etc.
    Champion:
  • 214 Answers
You have to order it form KM service, because, there is also special cabel and metal plate to install hdd, and installation instruction is included.
good luck
Posted on May 11, 2008
Dell laptop HD
This model laptop came with a 60Gb hard drive and it will work with a 40Gb hard drive.
If it was me I would install a 60 Gb hard drive not a smaller one.
Apr 30, 2013 | Dell Inspiron Computers & Internet
Hardrive is unknown device in bios
The BIOS determines the maximum size hard disk the computer can support.
The max hard disk size for this model Dell is 80Gb.
To use your 250Gb hard drive, install this Hard drive into an USB hard drive case and use it as an external USB hard drive.
Mar 09, 2013 | Computers & Internet
Cannot install whs on ssd using flash drive
I would suggest cloning the OS install.
Install the OS on the 80GB SSD with the Foxconn board that is giving you troubles with the 40GB SSD. Then clone the drives and swap SSDs.
WHS 2011 probably will throw up a flag stating that it needs to be reactivated because of hardware changes, but it should go smoothly.
Dec 23, 2011 | Foxconn (M61PMP-K) Motherboard
I have an hp nx9010 and the hard drive appears to have failed if I am buying a new hard drive what type do I need? IDE or SATA and should I look for a certain rotation speed? The current hard drive is a...
This model laptop is installed with an IDE 40Gb hard drive.
You can use a faster hard drive but the BIOS limits the maximum size hard drive you can install.
Check the specification of this laptop for the maximum size hard drive you can install.
May 22, 2011 | HP Compaq Business Notebook NX9010
I am connecting my 40gb PATA HDD, but my PC doesn't start. There is no problem when i connect my 80gb PATA HDD in same PC. My 40gb HDD had detected once but it gave symbol S@ in the BIOS setup. Can U...
You did not indicate that the 40 Gb hard drive had Windows installed on it and whether it was the original hard disk for this computer.
There is a possibility the 40Gb hard drive is faulty.
Try installing the 40Gb hard drive as a slave drive with the 80Gb drive as the master drive (don't forget to set the jumper on the 40Gb hard drive as Slave. Check the BIOS to see if it detects the 40Gb hard drive, and when the computer boots up, if it can see the 40Gb hard drive and opens the various folders and files, then the hard drive is OK.
Sep 19, 2010 | Computers & Internet
IBM deskstar 120 GXP 40GB will only format to 22GB. Its an old drive setup in an external usb enclosure
sounds like you're trying to format with FAT 16 or 32 which limits the partition size.
Try formatting with NFS which has no limit on partition sizes
Oct 25, 2009 | IBM Deskstar 120GXP 40 GB Hard Drive
Can I install larger then 40GB hard drive in a
Yes you can install a larger hard drive in this model laptop.
Jul 29, 2009 | Compaq Evo N600c Notebook
How much hard disk GB support in p4bp-mx
Hi araamudhan12,
Its your choice. The motherboard will function with either size hard disk drives. The 160BG drive will store more information than you might think. So the question you'll need to ask your self is, do you really think you'll come close to filling up a 500GB hard disk drive. Most users install two drives. One as the primary & the second as an extra storage drive & to back up the primary drives data in case the primary has a problem. When looking for a hard disk drive, go with the drive or drives with the longest warranty.
When installing a new drive & the new drive will be your primary drive. Disconnect the 40GB drive. Allow windows to format the drive & install windows from scratch. Once windows is installed & completely updated you can re-connect the 40GB drive & copy all your personal data back to the new hard disk drive. When your sure all the data from the 40GB drive has been copied over. Install another 160GB drive as your back up drive / storage drive. Keep the 40GB drive just in case you missed data that you though you did not need. The Asus P4BP-MX motherboard can run, two Ultra DMA 100MHz hard disk drives.
Have more question, post here.
Mike
Apr 11, 2009 | ASUS P4BP-MX Motherboard
Erroe code
You post a wrong printer nr, you must have bizhub C350 not bizhub 350, beacause 350 doesnt have that kind of code.
In Bizhub C350 that code means:
C12C0: Hard disk recognition error
You have the following options:
- reinstall the hard disk
- change hard disk
or as a last chance change PWB-MFP
good luck
Feb 06, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
611 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
