NetGear WG111 802.11g/b Wireless Adapter Logo
Posted on Apr 14, 2008
Wifi card my sony PCG-5201 does not respond when I insert my wifi card (a Netgear 802.11 b wireless PC card 16-bit PCMCIA Model MA4010). when I insert the resource CD it tells me to insert the CD and the card at the same time. the problem is that my CD drive is external and it plugs into a card port and my computer only has one card port. no mater what I do the computer will not acknowledge the existance of the wifi card I have tryed everything! HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
A
Anonymous
Where is wireless card in sony vaio pcg-9j1l laptop
This is ab old model laptop and it does not have a built-in wireless card.
You can install a PCMCIA wireless card in the PCMCIA card slot.
Checl out this WEB site for these.
http://www.bestbuy.com/site/Wireless-Networking/Wireless-Desktop-Cards/abcat0503003.c?id=abcat0503003
1helpful
What is the correct way of removing a Netgear WG511 Wireless card (for safe transport) without causing connection problems next time you insert it?
Use the Safely remove hardware Icon in the notification area to stop the device then use the button on the PCMCIA slot to eject it.
How to turn on wifi
hi
the T42 does not have WiFi, instead it facilitates internet connection via 16 BIT & 32 Bit PCMCIA slot to install a WiFi card , in order to go on the internet.
The ThinkPad uses the following adapters: v 360, 365X, 380, 600: 16-Bit PCMCIA v T20, T22, T23: 32-Bit CardBus and MiniPCI v T23: 32-Bit CardBus and MiniPCI Daughter Card v T30: 32-Bit CardBus and LAN on Planar Board (LOB) v T4x: 32-Bit CardBus and LAN on Planar Board (LOB). 16- and 32-Bit PC Card adapters are configured during ThinkPad initialization. Network Interface Controller data rates are: v For Token Ring: 4/16 MBps v For Ethernet: 10 Mbps...........16 bit PCMCIA 10/100 Mbps.......32 bit CardBus 10/100 Mbps.......MiniPCI and Daughter Card 10/100 Mbps.......T3x and T40 LOB 10/100/1000 Mbps..T42 LOB The MiniPCI Ethernet adapter is accessed behind a removable plate located on the bottom of the ThinkPad directly above the Model/Type S/N sticker. For T20 and T22, the MiniPCI adapter may be an Ethernet/Modem combination card. The Daughter Card (T23) is secured with two screws and is located next to the MiniPCI modem adapter.
please go to this link to read the manual -- it will explain the features for this ThinkPad of various series T42 model-type .
http://www-01.ibm.com/support/docview.wss?uid=isg2ffa39ae31a2f590e85256ced00828893&aid=1
please rate my service
1helpful
Can a wireless card be fitted to acer travelmate 230 laptop
you can buy either usb wifi adapter which is plugged into a usb port or a pcmcia card wifi adapter that plugs into it pcmcia port
1helpful
Need WiFi instead of Bluetooth
You have two choices for a wireless connection, a PCMCIA card or a USB device.
My choice would be a PCMCIA card, because it frees up a USB port.
There are quite a few PCMCIA card to choose from, I favour Netgear and D-Link.
Their instructions make them easy to install and setup.
Let me know if you have problems.
Sony VAIO internal wireless driver causes computer to lock up
There is a possibility you have a faulty wireless card. I would go with a external PCMCIA wireless card. Don't forget to disable the internal wireless card in the BIOS.
2answers
Boost PCMCIA Wifi Card Range
em maybe you just need to change the pc card or honestly just change the pc for fast and efficient browsing.
Want to try to utilize an old sony Vaio PCG-F520
OK you can certainly add wireless to this machine. But be careful which type you buy. If this machine has windows 98 you have to ensure the wireless adaptor will be compatible. . you have two choices for the adepter type either USB or PCMCIA (aka PC Card) I'd go for the PCMCIA version, it will be more likely to play well with the older system. Also, Dont buy a MIMO card, a simple 802.11B or 802.11G compatible card will work. these are in the sub $40 price.
Dont attempt to install XP or VIsta on this PC, it will be unbearably slow. Stick with 98 or better yet windows 2000.
-Good Luck
1helpful
WIRELESS MODEM
Pcg U1 doesnt have wireless card. But is has PC card slot. You can buy a PCMCIA wireless card or USB wireless to get access to wireless internet access or PCMCIA modem if you use a modem to access the internet.
I hope this help
Wireless network setup
Based on your post, you currently have a working Netgear WiFi Card installed in your laptop. What you want to do is remove it from the laptop and install the said card to your desktop.
For your desktop to be able to accept the NetGear WFi card which is a PCMCIA Cardbus device, you need to install either:
1. a USB Adapter for PCMCIA as shown here; or
2. a CardBus/PCMCIA to PCI Adapter Card available here.
Either one will work. Of course you need to install the necessary drivers for the NetGear MA701NA in your desktop which is available from the CD installer that came with the NetGear or online here.
Considering the cost of the USB adapter or the PCMCIA to PCI card, you may want consider buying a PCI WiFi card or USB WiFi dongle.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Top NetGear Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
