Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Will not run or drain
I turned on my washer (Whirlpool Ultimate Care II) it filled with water and did nothing else. I stopped it moved the dial to rinse waited a while an turned it back on. Nothing happened besides a hum (normal) then a click. If I retried right away it wouldn't even hum. I also noticed water on the floor from under the washer (this may be a seperate issue). I used a pen to to hold down the safety switch and tried to get it to drain or spin, I noticed the washer "jumped" like the motor torqued up then quit, it hummed, clicked and was dead again. Guessing either the motor or the transmition needs repaired/replaced.
  • cougkat Apr 14, 2008
    I just took the front/side(s) cover off and rigged it to work w/out the lid. When the spin should kick on I can see the water exaust manifold (or what ever it's called) torque. I asume this means that the motor wants to turn but can't for some reason.
    I got it fixed!!! Whew...:D I took the "manifold" (it's the waterpump) off and tried the washer again, it spun-up. I tried to turn the impeller, it was stuck. Turns out one of my kids socks fell into the tub out of the bowl and got sucked in. I pulled it out and reinstalledthe pump and started it up...ran just fine. Hope this helps anyone else with a similar problem.
My wash machine doesn't open from the front but I am having problems with it not draining
Posted on Apr 23, 2008
My Whirlpool Ultimate Care II Washer doesn't stop filling with water
If this only happens when the machine is turned on,the tube from the tub to the water level switch is pinched or broken. If the clear plastic tube is not pinched or broken,the water level switch in the control console is bad. If the machine lets water through when it is in the OFF position,the water valve where the hoses connect are bad.
Dec 27, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
Wont stop filling with water
You need to replace the fill switch its not sensing or stopping the w ater. It is fairly simple. Remove the plastic molding on the ends. Remove two screws holding down the control panel. The fill switch is over to the left, and has a clear tube attached to it. Remove tube and wires, lift tab keeping it from turning, turn 45 degrees and remove switch. Replace and test in all positions. Good luck whirlpool is a good brand.
Jul 12, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care II stops after filling
Hi, could be faulty timer, faulty water level switch, faulty start capacitor for motor, or faulty motor. always put clothes in machine before starting. you can empty machine by lowering drain hose to flow level.
Aug 02, 2009 | Whirlpool Ultimate Care II GSW9650LW Top...
Washer stopped after wash cycle
The lid switch is the culprit. Push down on the lid it should start. It needs to be adjusted . the tab on the lid is not activating the switch. Try triming the door bumpers.
Apr 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer fills but won t advance to the next setting for all cycle
Do you hear the ticking of the dial moving? if so it could be that the points aren't getting connection to cycle it threw the various cycles
Nov 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool ultimate care II keeps filling flooding the garage. It will not move off the fill position on the little turn dial. we manually move the dial to try to get it to agitate and the only spot it will...
A couple questions.
Does it continue to fill with the timer turned off.
Yes, you have a mixing valve problem
No. You probably have a pressure switch problem,
I would guess its the pressure switch, check to make sure the hose running from the outer tub to the pressure switch has a cut in it and needs to be replaced, or the pressure switch is bad.
If you are uncomfortable trying to find problem call a service tech.
Jul 12, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
160 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
