Question about GE Profile Harmony DPGT750EC Electric Dryer
Not Drying No Heat
The dryer runs fine and gets a little hot but not enough to dry the clothes. I have 5 kids and need a dryer desperately, please help!!!
  • 156 Answers
Test for these first:
First of all, see if you have good voltage supply on the socket on which it is powered too.
(1) All venting is clear of lint, even disconnected from back of dryer.
(2) Breaker in house is not tripped. Cycle the breakers off and back on to make sure.
(3) Test continuity on all thermostats and thermal fuses, all have to measure 0 ohms when wires are disonnected and dryer unplugged. We tested the HiLimit Thermostat, Safety Thermostat, and Thermal fuse mounted to the heating element housing, all should have continuity. Also measure the two thermostats located near the exhaust duct in the rear of the dryer, get 0 ohms as well.
(4) Disconnect wires from heating elements. Test continuity from each terminal to the metal cage to make sure none of the elements were grounded. Good if theres no continuity there.
(5) Disconnect wires from heating elements. Test resistance between double coil and inner/outer coil. Each should measure around 19 ohms.
(6) Test the dryer temperature switch by removing wire from terminal 15, then took a reading between terminal 15 and terminal 16, should get 0 ohms there.
(7)Test the dryer timer by first setting the timer to 60 minutes. then remove the wire from terminal A. We then took a reading between terminal A and terminal B, and should get 0 ohms. then keet the leads on those two terminals and rotate the timer and had continuity throughout the 70 minute cycle.
Posted on Apr 14, 2008
Dryer model Roper RED4340SQ1 rmy heater don't stay hot all the time during a drying cycle is it normal or i need to change it
You may want to do a thorough tuneup on your dryer. I worked on a couple and wrote a pictorial on it. ROPER DRYER TUNE-UP
My Home movie of a Roper dryer with a heat problem:
Sep 06, 2012 | Roper Dryers
Gas Dryer not working properly
bad thermal sensor needs to be replace. But not available. sorry
Jun 07, 2012 | GE Dryers
Hi I have a dryer (Speed Queen) and I took off the front panel and cleaned everything and even in back, When I turn it on, I see the flame, But it does not get hot enough inside to dry the clothes, Is...
Clothes not drying, but dryer runs & heats
1. Defective operating thermostat---test thermostat,, replace if defective
2. Fan or it's pulley loose on shaft--tighten set screw
3. Incorrect heat or timer setting--reset timer
4. Clothes too wet when placed in dryer--wring clothes before putting them in dryer
5. clogged lint screen or duct ( little air motion)---clean
Sep 21, 2011 | Speed Queen AGS68AWF Gas Dryers
Runs fine Doesn't dry clothes, not enough heat?
You will first need to determine where the problem is, I would disconnect the dryer vent from the dryer. Now if the drying improves, problem is not the dryer, its the vent system. If no change, does the unit heat at first then slowly fail to heat? Does it produce any heat? I need more information to direct you in the correct direction.
Please get back to me
Sep 08, 2011 | KitchenAid KEYS700LQ Electric Dryer
Dryer end cycly without cloths drying. Doesn't
IF DOESNT HEAT UP ANYTING CHECK THE THERMAL FUSE AND REPLACE IT IF NECESSARY!!!
IF IT DOES HEAT UP A LITTLE IS NOT THE FUSE!! IT COULD BE THE EXHAUST PIPE (DUCT) CHECK THAT IS NOT BLOCKED OR CLOGGED!!!!
Oct 05, 2009 | Kenmore Elite HE4 Electric Dryer
Haier washer/dryer combo not drying clothes
Check things like the Filter / clear fluff...Make sure outlet hose if any is not kinked and passing air..Hope this helps..
Oct 02, 2009 | Haier 14.3 lb. Washer/Dryer Combo
DV448AEP sensor drying doesn't seem to work
I had the same problem with mine. My wrinkle free setting some how got turned off. As soon as I turned that back on machine kept running and dried the clothes fine.
Feb 19, 2009 | Samsung DV448AEE Electric Dryer
Does not heat
"Steam drying will get how but the air that comes later to actually dry is cold so the clothes never dry"
I am assuming "how" means hot in this sentence, if so, I think I can help! There is no "steam drying" phase for your dryer so what is probably happening is; the wet clothes are being heated properly [as a result causing steam] however if this steam does not escape frum the dryer it will simply condense back onto the clothing [leaving them moist/wet].
Check your flexible tube from the dryer and the vent on the outside of your home to make sure they are unobstructed. Hope this helps!
Oct 13, 2008 | LG DLE2514 Electric Dryer
Heating, draining water(enough?) but not drying clothes, they're just HOT, so is top of machine
You have a problem with the condensing duct.  Possibly clogged with excess and lint and needs to be cleaned out.  This requires disassembly of the unit to get to it.  Not a difficult job but not easy.
Oct 22, 2006 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
GE Profile Harmony DPGT750EC Electric Dryer Logo
110 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
