Question about RCA HD61THW263 61" Rear Projection HDTV
Lightning Problem Seems a lightning strike took out my bulb eventhough i have a surge protector. after replacing the bulb perhaps 1 hour later a shadow began to appear at the top of the screen and progressed slowly down until only the edges are visible. please can you help?
  • Anonymous Mar 03, 2009
    heavy wind cause a power surge and even with a surge protector the blue power light comes on and stays on but the screen stays black
  • anolbazo04 Apr 16, 2009
    I HAVE RCA/INFOCUS TV HD61THW263 THA BUTTENS ON FRONT PANEL ARE BLUE AFTER WHEN TV IS TURNED ON, BUT SCREEN IS BLACK AND IS NO SOUND...
    IF ANY BARRY HAVE SOLUTION FOR THIS PROBLEM?
I HAVE A 61" RCA INFOCUS ALL THE LIGHTS IN FRONT OF THE TV IS BLUE YOU UN PLUG IT AND PLUG IT BACK IN IT STAYS BLUE. YOU CANT TURN IT OFFOR ON
Posted on Aug 23, 2008
  • CAN_TEA_ONE Aug 25, 2008
    I HAVE A 61" INFOCUS RCA THE BUTTENS IN FRONT ARE BLUE .THE TV WONT TURN ON . I UN PLUG THE TV . PLUG IT BACK IN . AND THE BUTTEN STAY LIT . WOOD THE LAMP STOP IT FROM COMING ON.
  • CAN_TEA_ONE Aug 31, 2008
    I PUT AND AD TO SEE IF ANYONE KNOWS ABOUT THE 61>RCR DLP NO POWER ALL THE LIGHTS IN FRONT OF THE TV IS BLUE I PUT AND ENGINE IN LAST YEAR. MODEL- HD61THW263 THANK YOU SOUZACANDY@YAHOO.COM
Sanyo tv won't turn on after a lightning strike.
Ask friend if broken when given to you. If not I would suspect the power supply is fubar..
Sep 16, 2017 | Sanyo Televison & Video
When and How Should a Surge Protector Be Used on a Fixed Switch?
Common Causes of Lightning Strikes
  • Outdoor network cables or power cables are routed overhead.
  • A switch is deployed outdoors but is not properly grounded.
Damages of Lightning Strikes
  • If power cables of a switch are routed overhead in an outdoor environment, lightning strikes may burn the power supplies.
  • If network cables of a switch are routed overhead in an outdoor environment, lightning strikes may burn interfaces of the switch.
When a switch undergoes lightning strikes, overvoltage is induced by lightning on network cables and transmitted to interior of the chassis. The surge protection measures, such as lightning rod and chassis grounding cannot prevent the damage. Therefore, surge protectors or surge protection circuits are recommended.
Surge Protector Use Precautions Take the following precautions to protect a switch from lightning:
  • Ensure that the ground cable is connected to a ground bar or a ground point on the cabinet.
  • Avoid routing cables overhead in an outdoor environment. Bury cables underground or route them in steel tubes.
  • To protect network interfaces against lightning, use 8-line surge protectors (or Huawei certified 4-line surge protectors).
  • When installing a network interface surge protector, connect the IN end to terminals and the OUT end to network interfaces of the switch.
If a fixed switch is installed in a network box, follow these instructions:
  • Connect the ground cables of the switch and surge protectors to the ground bar in the network box.
  • The maximum length of a ground cable cannot exceed 40 cm, and a length of smaller than 15 cm is recommended.
  • If the network box is located outdoors and power cables are routed aerially over a long distance (more than 300 m) to the network box, it is recommended that you install a power supply surge protector in the network box. The decoupled power cable must be at least 3 m long
S2300 Switch Thunder link com
Dec 08, 2016 | Office Equipment & Supplies
Got hit by lightning and won't turn on. Power source is good. Need to find out how to take it apart.
Most of the time after an appliance has been hit by lightning, it is toast. In the case of a printer you can probably buy a new one for the cost of the replacement part. Next time make sure you also purchase a surge protector to plug your computer and printer into and then you will be protected from lightning strikes.
Sep 29, 2015 | HP Officejet 6700 Premium E-All-In-One...
Is the module of lg tv 32ld330-mb affected when theres a lighting strike???is there a chance to be fix??
The damage from a lightning strike tends to be random. Sometimes it's minor, and only a few parts are affected. Other times, many parts are ruined, or destined to fail soon as a result of the current surge.
If the strike came over the power line, the input surge protectors in the power supply should be replaced, even if they look good. It would be prudent to replace the entire power supply. If you had the set plugged into an external surge protector, that should have taken most of the hit and should also be replaced. (Some surge protector manufacturers will pay up to a certain amount for repair or replacement of equipment plugged into their products if it is damaged by lightning.)
If the lightning came over an unprotected input cable, fixing the set would be a gamble. You could end up changing a lot of modules, beginning with the main board.
Jan 30, 2015 | LG Televison & Video
After a lightning storm my bosch single 30" wall oven displayed an F03 err. I turned the power supply off at the breaker for one minute as directed by the oven's manual. This action did not...
Find out what the F03 error is for and then check out the appropriate area. If there was a strike of surge the most likely place to look for damage is the area where the electricity first enters into the device.
Sep 07, 2017 | Bosch HBL 5036 Electric Single Oven
My sister in Charlotte, NC had a couple of seconds power outage, her processor, modem, monitor, tv and phone were connected to outlet thru a surge protector. All work except processor. Is there a reset for...
No reset for that processsor.. ALL Surge protectors are not guaranted for lightning strikes. Does she know if lightning hit the line that services her home?
Jul 13, 2010 | HP Pavilion a1540n PC Desktop
Power Surge - No lights on control panel
u might need to change Lightning/Power Surge Suppressor the comes inside of ur motor connected between the black and white cables of the power input of ur motor
Jul 14, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sony KV-20FV12 channel will not change
Pasted from another message I just posted-
It may be too late for this advice, but if you live in a lightning prone area, you should consider having a 'whole house surge protector' installed.
The cost should be well under $300 (a lot less if you install it) and with the included insurance (most often for $25,000) it is a good investment.
If your house was struck, I'm surprised you don't have a list of things that no longer work.
No, I don't think it is worth the cost of a repair, if you can even find someone to do it for you.
Most of us are retired-
Jun 24, 2008 | Sony KV-20FV12 20" TV
Rca hd61thw263 61 in. dlp
Sep 09, 2007 | RCA HD61THW263 61" Rear Projection HDTV
RCA HD61THW263 61" Rear Projection HDTV Logo
149 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
