Canon VIXIA HF R100 High Definition Flash Media AVC Camcorder Logo
Posted on Jun 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I'm trying to install pixela on my computer and it needs my canon hf r100 serial number. where's the number located?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 24, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
763
Points
10
It is on the bottom of the Camcorder, just leave off the letters. Put in numbers only.
John
Anonymous
Level 3:
  • Master 10,594 Answers
  • Posted on Jun 19, 2010
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2955758
Points
33084
Check bottom of camera, serial numberwould be written on label pasted at bottom of camera.
How can I download the software for ImageMixer 3SE? I have misplaced the disc for this software and need it for my Cannon camera Vixia HFR100
You can download some software for the Vixia HF R100 here: https://www.usa.canon.com/internet/portal/us/home/support/details/camcorders/support-high-definition-camcorders/vixia-hf-r100 . However, ImageMixer 3 SE is third-party software that is only available on the driver disc that came with the camera. Some companies will send you a replacement disc for a small fee. You'll need to contact Canon support, https://www.usa.canon.com/internet/portal/us/home/support/ , to ask if they have discs available.
ImageMixer 3 SE is available here: http://www.pixela.co.jp/oem/canon/e/imagemixer3_se_canon/ . However, this is only for updating the software on a computer that already has the program installed.
I hope this helps.
tip
Import Canon VIXIA Series Video to FCP and Edit Canon VIXIA HF Video in FCP
Most Canon VIXIA HF series and other VIXIA series camcorders record video in high definition using a special codec (compression/decompression) called AVCHD, for example, Canon VIXIA HF11, VIXIA HF R11, VIXIA HF200, VIXIA HF R100, etc store videos in HD format using AVCHD compression and the files have MTS extension. For Mac users, it's virtually impossible to edit Canon VIXIA AVCHD footage natively in FCP due to different video codec and taking large space.
But also some of Canon VIXIA HF series camcorders can support iMovie' 09 or iMovie' 11. You can check the list of Canon VIXIA HF camcorders compatible with iMovie' 09 as follows:
Canon VIXIA HF M30, VIXIA HF M300, VIXIA HF R100, VIXIA HF R11, VIXIA HF S20, VIXIA HF S21, VIXIA HF S200
So if you would like to edit Canon VIXIA AVCHD video in FCP, you need to convert these AVCHD MTS files to FCP supported video format like MOV, MP4, DV, then you can import them to FCP for editing.
Doremisoft Canon VIXIA to FCP Converter is specially designed for Mac users to convert camcorder video like Canon VIXIA video, Sony HDR video, Panasonic HDC video, etc to Final Cut Pro MOV/MP4/DV. It also supports converting video including MTS/M2TS/TS/TRP(AVHD H.264, VC-1, MPEG-2 HD), MKV, etc to MOV, MP4, AVI, M4V, 3GP, 3G2, MPG, DV, MPEG-1, MPEG-2, WMV, etc.
Doremisoft Mac AVCHD Converter not only have the ability to convert HD videos to SD (Standard Definition) format, but also the ability to convert SD to HD which contains MPEG2-HD, MPEG4-HD, H.264-HD and more. More editing functions of Canon VIXIA to FCP Converter you can see edit AVCHD MTS/M2TS Files on Mac OS.
Before you import Canon VIXIA videos to FCP to edit them, the following easy guide can help you convert Canon VIXIA AVCHD MTS/M2TS files to MOV, DV or MP4 for FCP.
Step1: Add Canon VIXIA Video Files
Click "Add File" to upload your chosen Canon AVCHD MTS, M2TS files to Canon VIXIA to FCP Converter after you lauched it.
Step2: Set Output Video Format for FCP
Click "Profile" to open the Profile drop-up list to select MOV, MPEG-4 or DV as output video format for FCP on Mac OS. And you also can convert Canon VIXIA MTS files to iMovie, Quicktime, iDVD, iPod, iPhone, etc.
Step3: Convert Canon VIXIA Video to FCP
Click "Start" to convert Canon VIXIA videos to FCP, and you can edit your these converted AVCHD files with FCP on Mac OS X after converting finished.
Related: How to convert AVCHD(MTS,M2TS) to DV on Mac?
How to Convert and Edit Canon VIXIA HF200, VIXIA HF R11, VIXIA HV30 Video to iMovie?
on Nov 17, 2010 • Computers & Internet
The Pixela video browser provided with my Canon HF G10 locked my computer and will not load successfully. I uninstalled and reinstalled the software three times but the software remains unresponsive. ...
As you had rightly confirmed there is a conflict in the software with your OS/graphic card and it needs to be checked if the CD contains any machine error. If you are able to check with the support site for a download try and see if this works out. If not check this CD on another PC to confirm the case of a faulty CD or software in which case you can lodge a complaint to the support customer center.
So please check this out first.
Where is the serial number located on the Canon Vixia HF R100. Thanks
The serial number label is located on the battery compartment cover. The three rows of four digits comprises the number.
Sep 14, 2011 • Cameras
WHERE IS THE SERIAL NUMBER LOCATED?
The serial number shold be located behind the battery
Where the serial number on my camara?
On the camera itself it may be located in one of 4 different areas
1 on the bottom of the camera
2 inside the back door of the camera
3 along the rim of the lens
3 in between the screen and the main body of the camera
1helpful
Install. ImageMix. (Canon HF-10), not accepting the serial number
I found another serial number under the batteri, and then it worked out fine.
15helpful
3answers
Serial numbre installing ImageMixer for Canon HF-10
I have a problem with my cannon fs100, I am looking for the serial number and it's not any where near, under or over the battery. Please help?
10helpful
3answers
Imagemixer3 install won't take serial number when installing for Canon VIXIA HF100 I have a canon fs100 and it won't take the serial number if I leave off the letters. Someone said to change the...
This from Canon support relating to the HF10. Replacing the first 3 digits with 808 worked for me; Dear Mr , Thank you for contacting Canon. I am uncertain as to what you are trying to register for. Therefore the following two procedures may not work for the registration you are trying to complete. You should first try the prefixes 21, 22, 23, 24 (one at a time) in front of your serial number, these are regional prefixes which are applied to serial numbers for region specific products for software registrations. Alternatively you can replace the first 3 digits of your serial with the characters 808. This can help with warranty registration and the canon image gateway. Pixela Support - 00 800 1532 4865 (international toll free number) - 01489 564 764 (Uk number)
Top Canon Video Cameras Experts
NOEL
NOEL
john h
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
