Question about Garmin StreetPilot C330 GPS Receiver
Garmin c330 the bottom half of the screen is blank
  • mikeb18181 Apr 14, 2008
    I have the same problem...the bottom half of the screen is blank...any chance someone has a solution?
  • 174 Answers
The screen is defective. It will need to be replaced. The screen is a a TD035STED2, search ebay for replacement.
Posted on Apr 15, 2008
Our garmin street pilot c330 tells us the battery is dead when it's plugged in and then goes blank. Can this type of battery be replaced?
yes the battery needs to be replaced, even when the GPS has external power the battery must be good for it to work,
May 15, 2010 | Garmin StreetPilot C330 GPS Receiver
Screen says low battery, then goes blank. can I get a new battery?
Yes, you can replace the battery. Please view video at link; http://www.videojug.com/film/how-to-replace-your-garmin-street-pilot-c330-battery-2
And also see link to purchase battery.
http://www.newpower99.com/Battery_for_Garmin_StreetPilot_c330_p/garmin%20streetpilot%20c330.htm
Please let me know if it helps.
Thanks
Apr 26, 2010 | Garmin StreetPilot C330 GPS Receiver
Brand new unit.Garmin c330, Will not stay on.
Since I didn't hear from anyone, I contacted the co. I purchased from. I was advised to send it back.
May 12, 2009 | Garmin StreetPilot C330 GPS Receiver
My streetpilot c330 won"t shut off.
IT'S CALLED A FROZEN SCREEN...
2 OPTIONS
ONE, RESET IT !!! (See resetting instructions below)
TWO, let the battery die out!
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 12, 2009 | Garmin StreetPilot C330 GPS Receiver
Dead battery on Garmin StreetPilot c330
The silver faceplate snaps off (there is a tab at the top of the screen); remove the silver faceplate, remove the 4 screws to open the unit. The battery is located on the back half, and is conected to the circuit cards with a balck and red wire through a small connector that also as two brown and white wires for the speakers.
Dec 15, 2008 | Garmin StreetPilot C330 GPS Receiver
Blank Screen on Garmin C330
It took a nap...
Dec 11, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin C330
IS the battery charged fully? Try turning it on while its plugged in.
Oct 07, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin Street Pilot C330 - screen problem
This doesn't fix Sitfar's problem, but for those how might find this helpful from Garmin's site: Question:  The touch screen is not responding correctly when I touch it. How can I recalibrate the screen?
Answer: To recalibrate the touch screen:
  1. Turn the unit off.
  2. With the unit off, touch and hold the Power button for 30 - 40 seconds.
  3. Follow the instructions on the screen.
May 09, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin C330
put your thumbnail under the silver faceplate above where it says garmin and on the right you will see a reset button. It will reset your garmin and you will not lose your information. Hope this helps.
Patti
Dec 12, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin C330 white screen
Have you tried a Master Reset? If not, it may help, but it WILL ERASE ALL OF YOUR FAVORITES, and may remove anything you have updated. To do a Master Reset, turn the unit off. Press the On button and the bottom right of the screen at the same time. Release the On button, but keep pressing the screen until the unit asks if you are sure you want to reset. Press yes. This may help.
Oct 28, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
59 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
