Question about Minka Aire F300-ORB 10'' RETRO STYLE FAN Oil Rubbed Bronze Table
Minka Aire F300 BN
My fan has worked great for a very long time. Slowly the blades seized up and won't turn even though the motor sounds like it is trying to turn them. Should I try to oil it? Or is it a hopeless cause at this point?
    An expert who has written 2 tips or uploaded 1 video tip.
  • 125 Answers
You could try to, or open it up to dust it. If none of those work, then it will be time to get a new fan.
Posted on Apr 14, 2008
Hardwired ceiling fan turned off by itself and stopped responding to remote control, but the light turns on/off.
I've had problems with Minka Aire also. You might need a new receiver. Call Minka @ 1-800-307-3267 and talk to someone in tech dept.. Should be a one year warranty on the receiver.
Aug 17, 2015 | Minka Lavery Minka Aire F888-BNW...
Minka f502 is noisy - how do you tighten the screws that attach the fan blade to the motor hub?
With a screw driver? And perhaps you also clean all blades. Sorry if you already did that.
Mar 16, 2015 | Minka Aire Ceiling Fans Gyro Traditional...
Minka aire gyro fan quit oprating
Contact Minka Aire @ 1-800-307-3267. You might have to ship it back to Minka for repair or replacement depending how old it is.
Feb 28, 2014 | Minka Dryers
Minka aire f608 top won't screw on
Check to make sure your blades screws are tight. They could be rubbing against the glass.
Jul 01, 2013 | Minka Aire Ceiling Fan
Can,t get the Fan to go in reverse Is there a Switch on the Motor
should be a switch above the blades closest to the roof on the round part should be a black switch.... hope this helps
Mar 03, 2011 | Minka -Aire Brushed Nickel Remote Control...
How to i replace the light bulb in the minka aire ceiling fan
This is the concept f518-bn or 519-bn with recessed light.
According to the manual you twist the clear plastic cover counter clockwise. This is on the opaque white lens cover itself.
Manual is found here:
Mar 15, 2010 | Minka -Aire Brushed Nickel Remote Control...
Minka Aire Fan will not reverse.
My fan is a concept II and it had the same behavior. I called Minka Aire support about this - they said it was either the reverse module or the receiver. They sent me both no charge! I replaced them and now my fan reverses. i am not an electrician, but the replacement was fairly easy. Just made sure to disconnect 1 wire at a time, connect it to the new wire, etc until I was done. Minka Aire support said they would walk me through it on the phone but I didn't need them to.
Sep 30, 2009 | Minka -Aire Brushed Nickel Remote Control...
Noise from one of the fans on gyro fan
Please see my Solution to the post about the "HOT" motor, with blades that don't turn.
The Minka Aire Gyro fan heads do NOT have any exposed screws that can be tightened. Checking the rear (wood color) pointy trim piece -- first loosen, turn fan blades a bit, then it. tighten back up.
If your fan was just fine before, and now it's cranky, the problem could be the motor head's "tweaked" out of balance: EITHER from the rear trim piece (see above), or from the twin support arms. OR, the fan head has somehow gotten off-kilter and is whirling out of balance.
FIRST, gently rock each fan blade - they are PVC plastic, not wood, and should not Warp. Do they all look the same? Do they feel snug or loose in the fan head? IF that's all good...
1) With the fan OFF, swing that motor head thru it's up and down range a few times, make sure it's moving like the good one.
2) do the above-mentioned pointy trim piece thing, and the "swing thru" thing; rec-check BY HAND to see if it's corrected.
3) If not, check for fan head wobble by slowly turning the blade (fan head) and see if it's running parallel to the motor head. IF NOT, use a thin plastic (spatula) and gently wedge the kiltered side back to parallel - recheck afte each "nudge". It should spin nice and flat with no wobble, and not feel loose, either!
BY HAND: Spin the blades fast - does it bang? NO? great!
Yes? Double check that the grill hasn't gotten banged, and pushing into the blade's path. Re-try the "adjustment" of the fan head - if it still does not remove the problem, then the internal motor shaft supports may be loose, or broken.
Hope this Helps!
Jun 08, 2009 | Minka Aire F602-BNCH Gyro? Fan
Minka Aire F300-ORB 10'' RETRO STYLE FAN Oil Rubbed Bronze Table Logo
108 people viewed this question
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Are you a Minka Dryer Expert? Answer questions, earn points and help others
