Question about Toshiba 32AF44 32" TV
Is this tv hd compatible, I see there is connections on the back of the tv, but i triedto plug it in from my hd cable box but there was no picture? the plug in says for a dvd player hook up but can uuse a cable box?
  • Toshiba Master
  • 1,689 Answers
You can use a cable box providing that its HD option is working. With many of the cable companies, you have to pay to have the HD option in the cable box activated. Then you have to pay subscription for the HD channels. That is the way it is at where I am located. Without the HD subscription active on our cable boxes this feature is dead!
The only reliable way for you to know if the HD option works in your TV itself is to get a known to be working HD source such as an HD DVD player and try it out.
Jerry G.
Posted on Apr 14, 2008
This is a TUNERLESS HDTV monitor. This kind of television was manufactured during the period of time when the HD tuner standard was still being defined. Manufacturers did not want to install digital tuners only to find out they were not compatible with the final standard. Having a cable connection would not provide service. You need to use a cable-system provided decoder box and connect either the HDMI or RCA Audio/Video cables to the Monitor. Then use the cable box to select you channnels.
Dec 08, 2013 | RCA D52W23 52" HDTV CRT TV
Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Aug 17, 2007 | Mitsubishi VS-60805 60" Rear Projection...
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
Can record Sky programmes but not view live.
You must connect up the TV to the SKY box, via Audio Visual cables too, in order to watch, recorded programs. You need to hook, up, Component, HDMI, or Composite, You select it by an EXTERNAL channel.
Connect the cable running from the wall into the "In" port on the Sky Box HD receiver. This cable brings in the signal to your receiver. Make sure the cable is securely fastened to the receiver, otherwise you might experience image and audio issues.
Attach an HDMI cable into the HDMI port on the Sky Box HDTV receiver. The HDMI is a single cable that provides both HD audio and video signals.
Plug the other end of the HDMI cable into an available HDMI port on the HDTV.
Power on the HDTV and the Sky Box HDTV receiver. Press the "HDMI" button on the TV's remote control. This will display the cable contents of the HD receiver onto the television.
May 08, 2010 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
My volumn doesn't work when using the HDMI cable
Your TV and the cable box may not be compatible via HDMI or the digital audio format of the cable box is not set to PCM (contact your cable provider for information on how to change this on your cable box... too many models to speculate). The easiest solution is to use the component connections on the box and the TV (5 wire - Green, Blue, Red, White, Red). This will give you HD and eliminate to question of compatibility. I hope this was helpful, best wishes.
Apr 22, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Screen is all Green
New cable box recently? If not, your cable provider has probably pushed a firmware update to your cable box. Green screens are very common with HDMI connection. From your symptom, I am going to take a guess that you are connected via HDMI. If so, switch to Component cables and your problem is solved. It's not the TVs fault... cable boxes seem to be the single largest problem child for HDMI compatibility. I hope this was of some assistance.
Apr 11, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Can't get HD channels selected on tv. Tried auto search with HDTV port connected and the menu selected to HDTV
Hello, the HDTV input is what you would use if you were not using a cable box.
You should connect your cable from the wall to coaxial input on the cable box, and connect an hdmi cable from the hdmi output on the cable box to the hdmi 1 input on your tv and then switch the tv to that input.
Tommy, HD Installations
May 25, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Significant volume decrease when using Comcast cable box
This low audio problem happened to me suddenly yesterday. I powered off over night - no change. I plugged the A/V cables into a second TV - no change. I called Comcast - problem solved.
Tap these buttons on the remote;
May 16, 2009 | Panasonic Viera TC-L37X1 37 in. LCD HDTV
Samsung 40'' tv can't get High Def when i connect to my cable plus
make sure your cable box is hd compatible, also depending on the cable box you may have to go through your settings and change the resolution and also change your settings through the menu's on the tv itself. what type of cable box do you have? is it a satellite box? which provider?
Apr 04, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Toshiba 32AF44 32" TV Logo
170 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
