Question about Akai PT46DL10 46" HDTV-Ready Television
Not working properly
Lamp was changed and tv worked fine.. when trying to cut it on, you have to hit power several times... then the screen show a awful color.. after a while it goes black.. i hear perfectly but no picture.. when i turn it off and on eventually i get it to work .. HELP!!!!!!!!!
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
Try new lamp.
Posted on Aug 03, 2008
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
Replaced lamp. TV worked great. Never reset message code. Finally, tv started cutting off after booting up. Reset lamp code, lights on front went one green. Thought that solved problem.
After a lamp replacement, you might have to reset the lamp time. It was a must. Contact the authorized service center; as there is no chance to you to get the screen display any further. The service engineers at the service center will do the needy.
Feb 25, 2015 | Televison & Video
Yesterday i changed the lamp. After this I turned the TV on and it worked fine. This morning, upon turning it on,it showed for a few minutes and then the screen went blank, the green power light started to...
how many times is the red led blinking? if you just changed the lamp make sure and check that the lamp door is secure if the door is ajar it will flash 3 times.
Dec 22, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Changed lamp and TV won't turn on, power light flashes 3 times
Red light blinking 3 times shows problem with lamp cover.
Lamp cover is not fixed securely in your tv after lamp replacement. Lamp cover is first thing that was removed to replace lamp, check lamp cover and make sure its back in place properly.
Thanks.
Jul 17, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Screen goes blank, sound still on
even though lamp came back on and worked for awhile, it was a bad lamp. replaced lamp and set works
Mar 23, 2009 | Samsung HL-R5087W 50" HDTV-Ready...
52HM95 Lamp Issue
The Tv will shut off and sho error if the ballast is bad. Replace the ballast and you should be fine.
Mar 22, 2009 | Toshiba 52HM95 52" HDTV Projection...
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Spark Gap Lamp Driver Problem? Sony LCD TV?
Lamp driver error 5 times - Lamp driver is faulty. The symptom will be no picture or sound . Repalce the lamp driver.
Apr 27, 2008 | Sony Grand WEGA KF42WE610 42" Rear...
Blank Screen - Panasonic PT-50LC13-K
Hey Ben, The TV is alerting you it is about time to change your light bulb, it will keep on doing this until the light bulb just dies.
Order your Bulb via On Line at any of the places, there are different prices, but average for the authentic one with the chasis included is @ 260.oo and only takes @ 5 days to get delivered. You can save up to 140.oo if you just order the pure light bulb, and go the extra mile changing it, I just explain someone how to about it, only takes you 30 mins. Good look, I hope I get help for my problem too.
Mar 16, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Projection lamp timer reset
I called 1800 211 PANA and they walked me through resetting lamp.
press recall and Volume- till solid screen shows, then hit recall till you see codes on top left, then hold volume- and mute(same time) till all codes return to 000000000000, then hit exit. turn off tv and check to see if it works
Jan 21, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Akai PT46DL10 46" HDTV-Ready Television Logo
37 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
