Question about Brother Disney PE-400D Computerized Sewing Machine
The feed dogs stick and bunch up the fabric and pull it out of the hoop.
The feed dogs seems to grab the thread and fabric and keep the machine from advancing. It is stuck so tight, the hoop lets go, no matter how tight I have it hooped. But when I get the mess cleaned up on top of the feed dogs, the bobbin thread seems to be ok. I have noticed several times when I insert the bobbin and wind the thread in , the thread sticks in the loop sometimes. Hope this makes sense. My machine was at the dealers last week for cleaning and repair for this problem, but it is not fixed.
  • Brother Master
  • 1,388 Answers
I would take it back to the repair shop with some of your samples and the "mess" in place so they can sort it out for you.......after all, you have paid them to do a service and should have a 30 or 90 day warrantee implicit in that arrangement.
I suggest you phone first to arrange to meet (with the tech too if possible) and outline your concerns, they do have a responsibility to you.
Whenever this happens to me (rare thankfully) I give the machine priority and generally talk it through with the customer and try a sew test with them present so we can see what is happening then and there.
I would not advise you to "play around" inside as it will void any warrantee.
www.bargainbox.com.au
Posted on Apr 14, 2008
Cant get the feed teeth to come up and grab the cloth -- the cloth wont move --do I have it set on darn ?
it is possible that you have the feed in the neutral position ( halfway between forward and reverse ) from your problem discriotion
Apr 24, 2016 | Singer Sewing Machines
My machine doesn't sew. When I start sewing it seems like the material isn't moving but at the same time I see that the threads haven't connected.
check for broken drive belt that works the bottom shaft in the machine
have a sewing machine service center service it
Nov 07, 2015 | Brother Sewing Machines
Fabric does not feed through machine
When you sew the machine must be set at the correct settings. If your machine won't straight stitch, turn it off at the power point and then turn it back on. Most machines reset to the default straight stitch setting. Secondly when you sew the presser foot must be down. This engages the "feed dogs" or the triangular looking "teeth" below the presser foot. As you sew, the feed dogs grab the two layers of fabric pulling them through, the thread above (spool) and the thread below (bobbin) meet to form the stitch. Finally, maybe fiddling around with dials and settings you may have dropped, or disengaged the feed dogs. Check with your manual on how to re-engage the feed dogs. Hope this helps and happy sewing. Remember, when all else fails..... read the manual.
Mar 11, 2015 | Brother XL-5700 Mechanical Sewing Machine
Fabric will not feed
DO NOT pull your fabric through. Under the face plate you will find the feed dogs. They are two rows of "textured" metal things that grab the fabric from underneath and pull it back. This pulls your fabric through. Look in your manual for info on the feed dogs. They are adjustable. You need to raise the feed dogs to a higher position.
Aug 12, 2012 | Singer Sewing Machines
My sewing machine will not pick up the bobbin thread. It sounds normal and pulls the fabric through, but the threads do not intertwine. I had been having problems with the bottom thread clogging and...
when the needle pulls the fabric into the feed dog you dont have enough fabric behund the neelde when you srart, and the fabric gets caught in the feed and the bobbin case underneath clean it out anf change the needle they often get bent after they get tangled in the thread and fabric
Dec 10, 2009 | Bernina Sewing Machines
Do I need the embroidery hoop? does it connect to the thing in the back of the machine and moves areouns?
  1. What do I need to get started at free machine embroidery?
    • A zigzag sewing machine with a drop-feed control. (In other words, you have to be able to lower the feed dogs so they don't try to feed the fabric.) It's nice if you can vary the width of your zigzag stitches too.
    • An embroidery foot or needle with embroidery spring. An embroidery foot helps by holding the fabric down against the throat plate while nevertheless being minimal - it lets you see what you're doing because it has very little surface area. You can alternatively get a needle that has a kind of spring built into it, and the spring holds the fabric in place. These can be nice in that they're even more minimal than an embroidery foot, but they're also relatively expensive and if it breaks you have to replace the whole thing instead of using an ordinary cheap needle with the special embroidery foot. If you use the needle with spring, you don't use a presser foot while you embroider.
    • An embroidery hoop. There are two primary kinds of embroidery hoops on the market. The old-fashioned kind, usually made of wood, has an outer ring and an innter ring. You loosen the outer ring, separate the rings, place the fabric over the inner ring, place the outer ring over the fabric, tighten the outer ring, and pull the fabric tight in the hoop. With the modern type hoop, you squeeze a pair of handles on the inner ring to remove it, place the fabric over the outer ring, place the inner ring (still squeezed) into place and release the handles. The more modern hoop is faster and easier. The old-fashioned hoop provides better tension on the fabric.
    • Stabilizer. This helps prevent puckering and slipping while you're embroidering. There are a variety of types out there. Some are papery and are torn away from the embroidery when you're done. Only use that on the back side of the embroidery, as it's almost impossible to get it all off. Others are also papery and also tear away but are dissolvable in cold water, leaving only a few easy-to-remove fibers in the embroidery. Your authors like this type of stabilizer. There is also a transparent plastic-like stabilizer which dissolves completely in water. Your authors have this but haven't tried it yet, but hear it's very nice. It's expensive though.
    • Fabric... of course. Make sure that your embroidery hoop fits on the piece you're going to embroider on. If the piece is to be small, you may want to embroider before cutting the piece from the fabric.
    • Thread. Contrary to popular belief, you can use ordinary polyester all-purpose thread to embroider, but it can weaken the fabric you're embroidering on. (If you do use polyester, you may want to fuse some interfacing to the back of your embroidery when you're done.) There is plenty of gorgeous 100% rayon embroidery thread available.
    • Thread for the bobbin. This won't be seen on the surface, so you can use anything you want. Trying to find a way to get rid of that day-glo orange thread you can't remember why you bought? Stick it in the bobbin when you embroider. Some embroiderers feel that it's best to use a softer thread (like 100% cotton) in the bobbin so as to reduce the possibility that the bobbin thread will break the embroidery thread, but your authors haven't had a problem with this to date.
  2. How do I prepare the machine and fabric for free machine embroidery? Drop the feed dogs and set the stitch length at zero. (If you can't set the stitch length at zero, don't panic, it's not that important.) Install the fabric in the embroidery hoop (with any stabilizer[s] you intend to use) so that the surface of the fabric is at the *bottom* of the hoop. (Note that if you're used to embroidering or cross stich by hand, this means you're putting the fabric in the hoop backwards.) When you place the hoop on the table such that the fabric surface rests on the table, the right side of the fabric should face up. Install the embroidery foot or special embroidery needle with spring on the sewing machine. If you're using the special needle, remove the presser foot. Place the embroidery hoop in the sewing area. (Some machines can't lift the presser foot enough to admit some hoops - you may have to remove the presser foot temporarily, position the hoop, and then re-install the presser foot if you're using one.) Set the sewing machine for a straight stitch. Reduce the upper tension until stitches interlock below the fabric instead of above or inside it.
  3. How do I lock the thread at the beginning and end of my embroidery so it doesn't begin to unravel? Make several stitches in place to lock the thread.
Nov 13, 2009 | Janome Memory Craft 9000 Computerized...
Bobbin thread tangling up
are you doing embroidery? if so turn off jump stitch cutting if possible. is the machine threaded correctly (pull needle thread out of machine and thread again with presser foot raised.
check for foreign matter in needle tension assembly. ensure there is sufficient needle thread tension.
the thread you see caught up underneath the fabric will be needle thread and indicates insufficient needle thread tension or something preventing the needle thread from being pulled up into the fabric (maybe a damaged bobbin case, or bobbin case position finger, or damaged needle plate hole).
goodluck,
scott
Jul 27, 2009 | Baby Lock Ellure
My xl-5700 the needle keeps breaking or the thread keeps getting all bunched up plus I lost my instruction manual can I gat a new one
About the needle problem, Brother's FAQ gives the following response:
Make sure the needle is correctly inserted with the flat side facing the back and pushed up into the machine as far as possible.
The needle could have been damaged or bent. If so replace with a new one.
Make sure the fabric is not pulled excessively when sewing. Let the feed dogs move the fabric. Do not pull the fabric.
The combination of needle size, thread size and fabric is incorrect.
Be sure to use the correct needle and thread size for the fabric you are sewing.(example: Denim-size 16 needle and 40-50 heavy duty thread).
As for the manual, here's the link:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000063/ps21xl55565700ug02en.pdf
Dec 05, 2008 | Brother XL-5700 Mechanical Sewing Machine
Bobbin thread/feed dog eating fabric
This is a very common problem with really lightweight fabric and can often be cured (if doing straight stitching) by using a straight stitch needle plate and foot. The wider needle plate and foot openings on newer machines give the machine/thread a wider area to pull the fabric into the machine. By using a straight stitch plate/foot you remove the wide opening, eliminating the majority of the problem.
Also - try using a specially coated needle (Teflon or other non-stick finish). The thread feeds more smoothly through the needle and the needle more smoothly through the fabric, causing less drag into the needle plate opening.
Hope this helps. Don't hesitate to respond to this if you have further specific questions. We're always happy to help
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
Dec 03, 2008 | Euro-Pro 8260 Mechanical Sewing Machine
Brother Disney PE-400D Computerized Sewing Machine Logo
74 people viewed this question
Top Brother Sewing Machines Experts
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
