Question about Maytag Neptune MAH5500B Front Load Washer
T is saying failed to lock the door need door latch switch part # 22003269
Bet if I did enough homework, obviously unplugged the unit, I could fix the unit myself right?
  • Anonymous Apr 14, 2008
    do you have instructions on how to replace the door lock? do you have to take the door and front off? do you have step by step and pictures? door will not unlock when wash is done. caseyj1@sympatico.ca thanks!
    Genius:
  • 1,073 Answers
Yea, not that hard th change the latch, you just remove the top and the bottom access panel and you can get to the switch on the right side, not hard at all go for it
Posted on Apr 14, 2008
  • David Coomer Apr 14, 2008
    sorry, wrong machine, you need to remove the door, and the frount panel and the 2 brackets that hold down the top, the latch assy is in the middle at the top sorry about the wrong machine thinking whilrpool
It giving me an F22 code, what is that mean and how do I fix it?
"F22" is a door lock error. The washer locks the door at the beginning of the wash cycle. If, after 6 attempts, the door fails to lock, the error code is displayed. You can attempt to correct the problem by perform the following steps:
1. Unplug the washer for at least 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main control board for the washer. Sometimes this is all that is required to correct some common momentary glitches. If the error code reappears after a CCU reset, proceed to step 2.
2. Check the door switch and locking mechanism for any obvious signs of broken or missing parts.
3. Check the wiring harness from the door latch to the CCU. You will need to remove the washer top panel for access. This is accomplished by UNPLUGGING the washer and removing the three screws that hold the top panel in place in the rear of the washer. With the screws removed, the panel will slide back, then off. Verify that the connectors are in place and snug.
If all these preliminary steps still don't fix the problem, the manufacturer recommends replacing the door latch assembly. Replacements can be purchased at appliancepartspros.com. Use the "Search by Part Number" feature and look up part number 8182634.
If you need further assistance, or have questions, please let me know. I hope you find this information helpful.
Mar 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front load washer, DFL code
Here are the steps to unlocking the door manually
1.Unplug machine
2.remove bottom panel
3.Reach up along the inside of the front panel and locate the botttom of the door latch assembly
4.Located on the bottom of the door latch assembly is a tear dropped shaped tab
5. Gently pull down on the tab about a 1/4 inch or until a click is heard.
6. You may now open the door.
This code means the door lock mechanism has failed or the central control unit has failed. Replace the door lock mech. first. This should fix the problem. (before replacing anything make sure there is no obstruction around the switch or in the switch.) After the machine has been unplugged it may fix itself. if not replace door lock mech.
Nov 21, 2008 | Washing Machines
Whirlpool Duett Front load washer, DFL code door won't unlock?
1.Unplug machine
Nov 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Theres a load stuck in my washing machine. the washer will not start. it keeps saying "dL" and "f". the owners manual does not say anything about "dL" what do i do?
Hi xstar57x
This suggest problems with the door lock/unlock mechanism
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Replace failed component
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Note: The door lock/switch assembly can be manually unlocked.
To Manually unlock the door lock system:
1. Unplug the power cord from the outlet.
2. Remove the lower toe panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about 1/4 inch or until a click is heard.
6. The door may now be opened.
Regards
Nov 16, 2008 | Whirlpool Washing Machines
Try to start light flashing ld and f what does it mean
Here are the steps to unlocking the door manually if clothes are still in the machine.
1.Unplug machine
Nov 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Front Loading washer Kenmore Ht3
1.Unplug machine
Nov 15, 2008 | Kenmore 46462 Front Load Washer
Whirlpool Front load
1.Unplug machine
Nov 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Error Code FL
it is saying failed to lock the door need door latch switch part # 22003269
Apr 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
ERROR CODE
1.Unplug machine
Mar 29, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Machine saying close outer door but its closed
I'm not an washing machine engineer but I do tend to do all my own home repairs - had to fix this fault this morning,
Quite easy to fix as long as there are no broken parts in the interlock and the solenoid isn't jammed.
UNPLUG FROM MAINS
Remove the top - 2 Philips or flat blade screws - pull backwards.
Remove front door - large flat blade inserted into gap in lower door hinge at back and gently twist to widen gap while pulling the door forward at bottom.
Remove 4 torx type screws (not sure what size) and 2 long torx screws from behind the hinge.
You may want to remove the coin trap door now - it makes the job of removal and refitting the front panel easier. Remember to put a tray underneath!
Unplug the ribbon connector for the front panel from it's socket and the clips - unplug the little pipe from the middle of the front panel.
Gently lift the front cover pulling the bottom edge forward a bit to ease removal. It is not necessary to fully remove the front panel so you can leave the mains switch connected.
Unhook the emergency release strap from the pivot arm.
2 Torx Screws above and below the door latch hole secure the latch assembly. Unplug the latch from a socket past the little foam block on the front - just inside the machine.
You now have the latch. Operation is quite obvious. The door loop pushes an angled plate that swings a hook into the loop. The solenoid when activated pushes a bar down to lock the hook in place and push down on 2 micro switches wired in series as the interlock.
To strip down the assembly unplug the micro switch plugs and push a small screwdriver into the top and bottom catches.
You can now lubricate the latch and check the function of the micro switches using a meter. They a easily replaced if you can find the correct type. (Unofficially - for a home repair - if one is not working you could always bypass one - but I wouldn't condone that obviously)
If you are careful enough - the operation of the solenoid and latch can be checked and observed by plugging the unit back in and pushing the door loop into the latch - be careful of the exposed wires etc - not sure what voltages are there!!
If it's unservicable then a replacement is about £35 online.
Reassemble in reverse - nothing to point out and is quite straghtforward. Dont forget the little pipe on the back of the control panel - it's easily missed.
Hope this helps.
Darren
Mar 08, 2008 | Dyson Flowcheck CRO1 Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
