Question about Brother MFC-620CN All-In-One InkJet Printer
Shut down after job complete - Brother MFC-620CN All-In-One InkJet Printer
  • 1 more comment
  • Anonymous Sep 21, 2008
    I have exactly same problem. Brother MFC-620CN, insert power cord and it displays 'Shutting Down', followed by 'Shut down after jobs complete', then it shuts down. Can't do anything with it.
  • regalblue Oct 07, 2008
    Same problem, -plug in the power, it lights up, but then says shutting down after current job complete. this message then stays on the screen, and printer does not shutdown...
    please help!
  • Anonymous Dec 09, 2008
    Yes, I am having the exact same problem as well. I can't think of any reason why, it just started happening one day. Does anyone know how to fix, or is my machine basically toast?
I had same problem on a MFC-3820CN Brother advised as follows:
"If the cover is opened during the power-down routine, when putting the machine into Power Save mode using the Power Save key, the LCD will display the message you mention in your email. The problem can be fixed by disconnecting the power cord and then holding down the on/off button while re-connecting the power cord again."
While waiting for brother to get back to me I accidentally put machine into maintainence mode and then when I re-powered up the problem was gone so I have not tried above myself, but can confirm problem is fixable.
Posted on Jan 09, 2009
  • AlisonM Oct 25, 2011
    Worked for me and my Brother MFC-620CN but instead of holding down the on/off button I held down the Power Save button. Thanks
  • 197 Answers
Hmmm..shuts the whole power down?
Posted on Jun 16, 2008
2 Suggested Answers
yooperbud
  • 8637 Answers
SOURCE: printer is saying shut down
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
HP 8500 Shuts down after a few hours
Hi David,
Try the firmware update for your printer released by HP. Click on the link below and select the Operating system from the list.
Click on + on Firmware Update. Download and Install.
Download Firmware Update
Regards,Suhail
Nov 12, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Wont shut down
The only thing I can find in the manual (link below) is to press "STOP/EXIT" to cancel the job. http://welcome.solutions.brother.com/BSC/Public/files/dlf/doc000013/FaxMFCBase_UsEngUsr.pdf There is a help page on the Brother site below: http://welcome.solutions.brother.com/BSC/public/us/us/en/model_top/colormfc/mfc3220c_us.html?reg=us&c=us&lang=en&prod=mfc3220c_us
Jul 24, 2007 | Brother MFC-3220C Plain Paper Inkjet Fax
PRINTER SHOWING THE MESSAGE TO AVOID DAMAGE USE THE ON BUTTON TO SHUT DOWN DO NOT USE POWER STRIP OR WALL SWITCH TO SHUT DOWN
Your question is kind of confusing. From what I get is that your printer is saying to not shut it down by unplugging it or breaker switch? If that's the case simply hold the power button till it shuts down (if it doesn't shut off after 5 seconds release and it should shut down).
If the message is saying do not shut it down at all, try and wait it out. It could be loading drivers or saving data etc etc.
Another problem it that you could have print jobs waiting and shutting down could corrupt data. Try and look at the bottom right of your computer screen and find a printer icon. From there you should be able to right click and disable pending print jobs etc etc.
Hope This helps!
Feb 19, 2011 | Office Equipment & Supplies
My ip4300 keeps printing the same page over and over again. There's nothing in the print Q, but no matter what new job I send to the printer it prints the same old page. Is there a way to reset the printer...
Have you rebooted your computer? The printer's memory is very limited -- certainly not enough to hold an entire page. Your computer feeds the printer a line at a time, so it would seem that your computer's print spooler is 'stuck' on that print job. Try shutting the computer down completely, then restarting and see if that print job clears out.
Mar 24, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
During cooking, the microwave will work for about 3 minutes then completely shut down.There appears to be a complete power failure.After the units sits for about 5 minutes,it resets itself and you can cook...
sounds like the cooling fan has came adrift or stopped working , this will cause the magnatron ( the microwave generator ) to overheat tripping the over temperature stat ,so fix the cooling , but be sooooooooooooo carefull in there , microwaves + really high voltages , not really a job for a non electrician/microwave tech
Oct 20, 2009 | Samsung SMH7178STD Microwave Oven
Sony KP-51WS500 projection tv. Screen is green with curved lines
The green picture tube has an internal short. Happened a lot with that model. The tubes are no longer availible. But a reputable company called Video Display will rebuild the tube completely. But the tube must be pulled and shipped to them. Most repair shops would charge around $400 to $500 for the complete job.
Jul 09, 2009 | Sony KP-57WS500 57" Rear Projection...
Canon pixmaip4000
Delete Queued Print Job If a print job is corruptand does not print clearly, does not print at all or is preventingother queued jobs from printing, delete the queued job.
  1. On the Windows taskbar, double-click the printer icon located to the left of the time.
  2. At the Printer window, select the print job, under 'Document Name' column, to highlight it.
  3. From the 'Document' menu, select 'Cancel'.
  4. Repeat steps two and three to cancel another print job.
  5. Ifthe print job cannot be cancelled or will not stop printing, shut downthe compuer, disconnect the printer cable and then restart the computer.
    1. Close the Printer window.
    2. Shut down the computer.
    3. Disconnect the printer cable (USB or parallel cable).
    4. Restart the computer.
    5. If a message window appears asking to cancel printing, select 'Yes'.
    6. Verifythe printer icon no longer appears on the Windows taskbar. If the iconappears, double-click it and cancel the remaining print jobs asinstructed on steps two and three.
    7. After all print jobs have been cancelled, reconnect the cable to the printer and then try to print again.
  6. Ifthe print job does not complete, it may be necessary to disconnect theprinter cable, power off and on the printer and then reconnecting thecable.
May 04, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Reset Job on Workcentre 24
You need to also clear it from the computer. Open the printer properties on the pc to see if the job is still present. If so, cancel it.
Apr 07, 2009 | Xerox WorkCentre M-24 Color Copier
Printer is saying shut down after jobs are complete and it shuts down and will not start up
Jan 26, 2009 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-620CN All-In-One InkJet Printer Logo
556 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
