Question about Hoover F7220900 SteamVac V2 Upright Vacuum
Clean water tank
Hi I live in ontairo Ca. I need the clean water tank any one have one at a good price?
Thanks
Rick
    President:
  • 1,673 Answers
Just have to call around to your repair shops in your area, and they are not cheap.
Posted on Apr 15, 2008
Hoover steam vac maxx 77 motor suddenly not running?? its almost new
Should still be in warranty. Read the warranty and get in touch with Hoover.
May 07, 2015 | Hoover Vacuums
I need to know why the Hoover Max Extreme keeps telling me t check the tank?
Hi! The solution and water goes in the top tank. Dirty water is suctioned into the bottom tank as you're scrubbing your floors. To fill the clean water tank, remove the clean water tank cap. The cap serves as a measuring cap for the solution. Fill the cap with Hoover carpet washer solution to the fill line. Pour detergent into tank. Fill the rest of the clean water tank with hot tap water and twist the cap back on. You are now ready to clean. Hope this helps!
Aug 20, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac F6210 solution tank spring repair
Hi there. The spring on the clean water tank cannot be replaced. A replacement tank would be needed. Follow the link to order a replacement clean water tank for your cleaner. Search Results
The clean water tank does not include the handle but your original handle will fit the replacement tank as well. Hope this was helpful!
Jun 19, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
Will spray water, but not solution
Hi there! The clean water tank has two spring loaded valves that releases the contents. Fill the clean water tank with water on both sides. Hold the cleaner up and push the valves in on both water and solution side. Both valves should push in and contents should drip out. If not, the clean water tank will need replacing. To order a replacement tank follow the link. Search Results The type of solution you are using can also prevent the solution from dispensing, be sure you are only using the recommended cleaning solution for this cleaner. If the clean water tank valves seem to be working fine, there may be an issue with the pump assembly that delivers the solution. We would recommend taking the cleaner in to an authorized repair center for service. To locate the nearest service center to you follow this link > Service Center Locator Hope this helps!
May 31, 2014 | Hoover F7452-900 All-Terrain SteamVac
It is not dispensing water and solution
Clean Water
Solution Tank
won't dispense.
1. Clean Water Solution Tank
not firmly in place.
1. Make sure tank is securely locked in
position.
2. Clean Water Solution Tank
empty.
2. Refill tank according to instructions for
surface being cleaned.
3. Dirty Water Tank lid not on
correctly.
3. Make sure lid is firmly in place.
4. Pump needs to be "primed"
(when using tool).
4. See "Before Using Tool" section.
Dec 17, 2012 | Hoover SteamVac F5914-900 SpinScrub...
There is a spring and a silver ball that seals the water from running out of the clean water tank, it fell out and I do not know how it goes back in. Bissel 1720 little green plus green machine
if it is from the tank,,,bad news,,, you have to replace the tank as a unit. according to the picture I see is an assembly and gives no parts breakdown on it exept the complete tank. there is a cover on top of the solution tank and is possible it goes there. that you can replaced but spring-ball part dont show on graphics. update.... cover is no longer available and tank price is about $23.00 at sears website part# 603-1204.
Good luck to you.
Feb 07, 2011 | Bissell 1720-1 Little Green Wet/Dry Vacuum
My scooba isn't picking up any water and the dirty tank is dry
This has happened to me twice. Frustrating. The first time I fixed it by half way filling up the dirty tank side, shaking the living bejeezes out of it, rinsing, and repeating a few times until big nasty clumps of **** fell out of the tank. The second time I was able to fix it by half way filling both sides of the tank (clean and dirt sides) with salt water, shaking the living bejeezes out of it, rinsing with fresh water, and repeating a few times with fresh water until big nasty clumps of **** fell out of the tank.
Jan 23, 2009 | iRobot 5800 Scooba Vacuum
Bissell ProHeat 7901 will not **** up water
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
adfa
Nov 11, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Hoover SteamVac LS F5899-910
Did you try to clean first the unit..
Jun 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Can I get a new clean water tank for my Hoover? After filling tank, as soon as I lock it in water poors out even before I can start cleaning carpet.
Take the clean water tank off, and look at the underside very carefully. This tank is made of a very thin plastic, and chances are, your tank is cracked or broken. Sometimes the valves fail as well.
There is a new tank available, a single-piece tank instead of separate water and detergent reservoirs. The part number you want to look for is 42272104. The new tank does NOT come with a handle, so save your handle and use it on the new one.
Search for this new part number online and find the best price. I have seen them for around $40.
May 17, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover F7220900 SteamVac V2 Upright Vacuum Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
