Question about Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television
Problem with color
The color is red and green and I cannot adjust it to anything else. I have tried the video settings and gone through the whole menu but nothing seems
to work. Any suggestions would be great.
thanks
  • 927 Answers
Good Day, and;
Try this first:
TO RESET THE CONVERGENCE EEPROM, PRESS "MENU 0359" TO ENTER THE CONVERGENCE MENU THEN "8970". If not the TV may have a circuit, come back.
Good Luck, Big Irish.
Posted on Jul 02, 2008
Perblem lg37lb1r has a color very often the color of green blindon
You can adjust the green temperature at the color RGB adjustment.press the menu button then choose the video adjust then scroll down to RGB setting RGB stands for RED,GREEN AND BLUE..adjust it according to your preference..
Apr 06, 2012 | LG 37LB1R 37 in. HD-Ready LCD Television
I own a Mitsubishi WS-73711 that needs a new convergence board. I hired a crappy tech to come out and fix it in Septemeber, and have not heard back since. So now, the convergence board is gone and I would...
For a whole board try shopjimmy.com
For just the parts to fix it your existing board.... www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 23, 2011 | Mitsubishi WS-73711 73" Rear Projection...
Can not get the focus grid to line up correct green adjusts fine but blue upper left corner will not adjust and the red grid is way off and will not fix
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
May 08, 2011 | Samsung HC-P4752W 47" Rear Projection...
Picture had a shadow on the right side, now the whole picture is dark.
  • Screen looks 3D
69189a5.pngSOLUTION
May 02, 2011 | Philips 60PL9200D Projection Televisions
Thee green on my Hitachi 43fdx20b has gone wacky, ive seen an answer to if the red and blue go wierd but not the green. What can I do to save my t.v.?
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 24, 2011 | Hitachi 43FDX20B 43" Rear Projection...
Out of convergence - getting error that sensor is not getting any signal during auto-converge - is there a way to manually converge - or replace anything??
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 15, 2011 | RCA D52130 52" Rear Projection Television
All my colors are off. I have tried to adjust them myself, but it still is too green. Where can I find the correct setting for the color?
No - Do not adjust those knobs..this is a major mistake...these were factory set and should only be adjusted when repalcing tubes. If you are having alignment issues read beliw...
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 15, 2011 | Hitachi 57F500 57" Rear Projection...
Shadows of green and red in picture
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 08, 2011 | Zenith R50W46 50" Rear Projection...
My hitachi ultravision digital 43uwx10bis showing red and green i tried magic focus but it didnt work
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 08, 2011 | Hitachi 43UWX10B 43" Rear Projection...
RED CONVERGENCE SCREEN PATTERN BOWING AND CAN'T ADJUST
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 13, 2009 | Samsung HC-P4752W 47" Rear Projection...
Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television Logo
73 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
