Water is not coming into the machine and shuts off w/in a few minutes of starting.
  • 96 Answers
Don't know what model machine you have but many models will stop if the correct water level is not reached within a certain amount of time. You need to check if the water main is turned on, if the hose inlets filters are not clogged and finally if there is power to the water valves.
Posted on Apr 14, 2008
Rinnai RL94i - Produces hot water for 3 minutes, then stops
I just had this exact problem. It kept getting worse until we had no water. Our Rinnai tankless hot water heater started the same way though, with hot water for a few minutes and then would shut off with an error code 10. We just had to shut the hot water off and then back on, wait a minute or so and we had hot water back for a few minutes. Our unit would come on with a loud vibrating noise and remain until it shut off with an error code 10 (air flow fault). The solution was to remove the blower fan and blow out the squirrel cage. Ours had moths in it. We also vacuumed out the fan housing. Be careful to mark any wires you disconnect and take pictures before removal. Our unit is now almost silent when it comes on and supplies endless hot water.
Jun 10, 2014 | Rinnai RL94i Tankless Water Heater
Lound vibration when running
Check gas control valve.
Good luck,
Marty
Feb 18, 2013 | Rinnai Water Heaters
My ice machine manitowoc q 132a starts up stops after few seconds while water pump start
There is a high pressure switch that stops the unit running if a fan fails or the condenser is clogged. Next time you start the ice machine, watch the bottom led on the pcb. It will tell you if there is a fault. Meantime, reset the hp switch and clean the condenser thoroughly.
Sep 06, 2012 | Refrigerators
The hot water shuts down for a few minuts then
your unit is undersized or you do not have enough gas supply to run the unit properly.
If you have to many water features running or you have to many gas items turn on at the same time it can cause problems.
Apr 10, 2010 | Rinnai Water Heaters
22" yardmachine starts and stops
loosen the bolt on the bottom of the carburetor up and let the water out and then re tighten and try it
Jul 22, 2009 | Mtd 22" Yard Machine Push Mower
My r85 rinnai water heater vibrates significantly and makes
Sounds like there is something loose in the line.Like cut off valve,check valve.
Mar 09, 2009 | Rinnai Digital Remote Water Heater Control...
Started a new load of wash and water never shut off flooding room
you can check for a broken/cracked/ dettached plastic hose leading from the back left side of tub to the pressure switch under the main console. usuall problem is it dry rots and cracks, or comes loose after shaking/vibrating,
Nov 15, 2008 | Kenmore 22422 Top Load Washer
Brews most of the water than stops and shuts itself off
Cuisinart Coffeemaker Decalcification Process
Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
-Tha Mp3 Doctor
Aug 27, 2008 | Cuisinart DCC-1200 Coffee Maker
Cutting out after a few minutes
Is the water supply (for supplying cooling water to the condenser) switched on? If not, there's no real mechanism for removing heat from the machine, and it might reasonably be expected to shut itself down. Once you've got water going to the inlet hose, you might check that the solenoid valve which shuts the water off when the machine is turned off hasn't failed, and that the jet through which the water squirts into the condenser (if that's separate in this model) isn't blocked. A.
Feb 16, 2007 | Hotpoint TDC32 Electric Dryer
Washing Machines Logo
64 people viewed this question
Top Washing Machines Experts
