Question about NEC MultiSync LT80 Multimedia Projector
Capcitor test and replace
Hi I have the same issue as http://www.fixya.com/support/t31536-nec_lt80_issue_any_advice and I have narrowed the buzzing sound to an area with what I believe are several capacitors. How do I test for a bad one and replace it? Any recommended Capacitors-r-us?
  • 563 Answers
Hi there
That buzzing noise is a faulty part that would need replacement.
The thing is you will never be able to test which is the faulty capasitor , so rather just replace the part.
Posted on Apr 15, 2008
How do I reset my nec projector model vt700 lamp time without remote
How to Reset a NEC Projector Lamp Timer ... - RelampIt
www.relampit.com/Projector-Lamp-Timer/NEC-Projector-Lamp.php
How to Reset a NEC Projector Lamp Timer. Make sure the projector is in standby mode; Press the Off or Help button on the remote control for a minimum of 10 ...
NEC reset lamp without remote Questions & Answers - Fixya
www.fixya.com/tags/reset_lamp_without_remote/browse/nec
My bulb warning had just recently appeared a few weeks prior, so I thought the bulbmust ... ...reset the Lamp timer o an NEC MT1050 projector. ... ...reset lamp usagetime without the remote on NEC VT490 HelloPress the MENU button on the ...
reset lamp hours nec projector without remote Questions ...
www.fixya.com > Forum > Tags
Find solutions to your reset lamp hours nec projector without remote question. ... My nec vt48 projector gets hot and turns off. It ... Question about VT700 Projector.
Replacing The Lamp - Nec VT700 User Manual [Page 58]
www.manualslib.com > ... > Projector > VT700 > User manual
Jan 29, 2016 | NEC Office Equipment & Supplies
How to run diagnostic
Maytag Bravos MTW6600T Top Load Washer Run ... - Fixya
www.fixya.com > ... > Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test cycle related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test ccu related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer Diagnostic ...
Dec 02, 2015 | Maytag Bravos MTW6600T Top Load Washer
I have a Ruud condenser on which I just replaced the capacitor and contactor. When I power up, the fan motor spins very slowly and a buzzing occurs about every 15 seconds. The buzzing sounds like it's...
Hello Zing77,
I understand that you are having a problem with your Rudd condensor. The fan is turning slowly and the compressor is making a buzzing noise which has a Diversitech hard start conected to the capcitor.
You have already replaced the run capcitory on the unit and have attached the compressor wire to therm and c and the fan to therm and fan. The hard start kit shoudl be attached to the therm and c with your compressor wires attached to the same place. The hard start kit is to give the compressor the extra push (electrical charge) to start.
You need to check your connections and make sure that you purchased the proper run capcitor. If you have purchased the proper compacitor and the connections are right then you have a bad fan and the compressor as gone out on the unit.
Thank you for choosing FixYa.com
Justin
Mar 27, 2011 | Heating & Cooling
I need a user's manual for NEC Pinwriter P6300
Hi. i hope this finds you well.
Please see the following link for a Comprehensive Support Document for Nec Pinwriter P6300. http://support.necam.com/printers/csds/273916.pdf
I hope this will help you with your issue.
Thank You for using FixYa.
Dec 22, 2010 | NEC Office Equipment & Supplies
My freezer is buzzing - what is the problem
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 20, 2010 | Woods Upright Freezer MU07W
My rca r52wh73 wont turn on the power supply fuse was blown i replaced it and it blew right away. what do i need now and where can i find it? Thanks
You got a bad capcitor then on the power supply. You need to change out the bad capcitor so the fuse will not blow. I would recommend just buying a new power supply to save face as with anything eletronics just reparing one thing as you did brings out new issues.
Remember before touching anything eletrical I advice you if you do not know what your doing leave it to the experts who do thanks for using Fixya.com
Sep 22, 2009 | RCA R52WH73 Projection Television
NEC DTU-16D-2 Phone manual
Here's the manual for all NEC Electra Elite =>
http://www.chickasawtel.com/pdf/manuals/elitemultilineug.pdf
Please leave a Helpful or FixYa! Rating. Thanks!!
Sep 29, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Whirlpool Microwave
I would suspect the high-voltage transformer in this case, but the capacitor may be failing.
The high voltage section uses and generates voltages that can be instantly lethal.
So I don't recommend that anyone work in this area unless he has either a lot of experience or at the minimum, a good understanding of the safety issues and procedures involved.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Also, there should also be a very helpful "mini-manual" hidden inside the unit behind the control panel. It's very helpful when troubleshooting.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Here are some links you or a friend can use for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 02, 2008 | Microwave Ovens
NEC MultiSync LT80 Multimedia Projector Logo
208 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
