Question about Canon i9900 InkJet Photo Printer
New logic board installed cant install driver
I just had a logic board installed in my printer but when installing the software cd it wont detect my printer. I've tried all the troubleshooting tips and also tried a different computer. any suggestions thanks
  • Bill001981 Apr 23, 2008
    Thanks the problem was fixed, what the repair facility told me was that they apparently installed a board for an overseas printer and they had me reprogram (i guess) it with a sequence of the power and resume buttons and it works fine now, Thanks anyway.
  • Robert DeAngelo May 11, 2010
    Sounds like an I/O problem. Printer and computer are ot communicating with each other. Make sure all cables are plugged into logic board. Insert cable into differnt but knowe working USB port.
After installing a new i9900 logic board, you *must* configure the destination country setting. The default setting is probably for Japan (PIXUS 9900i):
1. With the printer powered off, hold down the resume button and press the power button.
2. While holding down the power button, release the resume button and press the resume button two times. Now release the power button. The LED will blink green and remain lit in green. You are now in Service Mode.
3. Press the resume button 5 times to get to Model Setting mode. The LED will turn orange. Then press the resume button two times to set the model number to i9900 (LTR). Press the power button once to lock in this setting and turn off the printer.
Posted on Sep 22, 2008
My printer is not recognised by the computers at all. A salesman of canon said its because the logic board of f 380 is spolit. replace it and it will be solved. is it right?
Try this out.
if you have you printer driver cd with you install the drivers or if you dont have get it from
after installing drivers connect the priter and power it on,
if it is not detected,
click on add printer
select local port
select usb port click next
if printer is not listed-> click on brows give path of cd or driver folder
if drivers are correct, your printer will be listed
install it.
set it defualt and give test page print.
Mar 11, 2011 | HP DeskJet F380 All-In-One Printer
Cant install driver for deskjet 3915
did you use 39xx series driver? Torn on your PC, insert the CD Driver, plug the usb printer cable in, the PC should detect finding new hardware that is HP Deskjet 3915. When asked to install driver, chose install from CD. Follow the instruction and good luck
Apr 10, 2010 | HP Deskjet 3915 InkJet Printer
The driver gets installed but the computer cannot detect the printer.I have tried doing everything written in the manual and on the CD. Please help!
Try reinstalling the drivers or change the USB cable.If this not help your printer have problem in logic board assembly and need service but in most case is cheаper to buy new printer.
Oct 26, 2009 | Canon PIXMA MP150 All-In-One InkJet...
My computer wont recognize my hp photosmart 8049 printer
u need to install its software that comes with it in a cd
Sep 29, 2009 | HP PhotoSmart 8049 InkJet Printer
My lexmark all in one printer wont install since i got a new e machine computer--i tried the disk and it stops at drivers--tried to do by computer add a printer without disk and still doesnt work
If you connect and turn on the printer then turn on your computer it should start the found new hardware wizard. don't do anything until or IF it asks you to install the disc, the make sure you direct it to find the files under the correct drive letter which is usually "D" or "E" .Good luck, .Dana
Sep 07, 2009 | Lexmark OfficeCenter X3350 All-in-One...
Cant install my canon 190 printer
Have you check the printer cable thats connect from cpu to printer
Delete all printer driver, access from Start->control Panel->Printer and Fax. Right click to printer icon and delete all printer driver. Turn it off.
Then turn CPU on but not the printer yet.
Then after windows screen completly appears, turn printer on.
If the computer says detect a new hardware, that means a connection
between CPU and printer is fine.
Then instal the software driver from CD. Good luck !
Sep 06, 2009 | HP Photosmart 8250 InkJet Printer
Lexmark T520 wont work!
To start do the following:
Unplug printer USB, unplug power from pc and also remove the battery if it is a laptop, and restart printer and PC.
With printer still unplugged go to control panel>>printers and empty the printer cue.
Test a replacement USB cable and try plugging the printer on a different USB port.
If the above did not work , then reinstall the printer software using the printer CD. Unplug the printer and start software installation with printer USB unplugged.
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Mar 06, 2009 | IBM Infoprint 1120 Laser Printer
After installing new original black & color HP ink catridges, still error "E" problem.. on a HP PSC 1210.
hi im josh in cebu phils.may i help you|? friend if your HP printer displays error after installing you orig.cartridges. the problem is in your software your software connections are already corrupting thats why he cant manage it to detect. all you have to do is re install your printer cd driver. but before installing the new one you need to uninstall or remove the old one first.thats all good luck hope i helped you
Feb 28, 2009 | HP PSC 1210 All-In-One InkJet Printer
It wont print
I don't know why it is, but, so many of the printer problems I answer have to do with original install cd being corrupted(it may have to with mass production process) anyway, you can try this:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
Oct 14, 2008 | Xerox WorkCentre XD102 Printer
J5780 Installation Problem on Windows 2000 PC
hi this is due to improper Software Installation stapes below
  • Un install all printer driver & software u install
  • disconnect printer from computer
  • restart u r computer
  • insert Software cd in to cd rom
  • install software ,follow instruction & fill up Information.
  • when notify you to please connect printer thorgh USB please connected Usb cable to your Printer.
  • printer shuld be ditected then follow instruction
  • complite Installation & cheak it out..
If this information is useful for u please rate me....
Jun 09, 2008 | HP Officejet J5780 All-In-One InkJet...
Canon i9900 InkJet Photo Printer Logo
318 people viewed this question
old marine
old marine
