Question about Motorola Mobility L6 Cellular Phone
My l6 fell and now the screen is blank what should I do
  • 484 Answers
V\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
What you have to do is simple.
1. Remove the battery cover, battery and SIM
2. Use the screwdriver or tweezers to gently pry off the RF grommet located on the antenna cap (below)
  • Removing the antenna cover:
    3. Carefully use the flat end of the tweezers to release two latches on the top end of the antenna cover, then carefully lift the antenna cover away from the phone.
  • Removing the transceiver PC board shield:
    4.Using the T5 screwdriver, remove the 6 housing screws from the phone. Set the screws aside for re-use (see Figure 10).
    5.Lift the metal shield away from the phone.
  • Removing the housing:
    6. Insert the plastic shim between the front housing and the chassis assembly. Slide the plastic shim around the phone between the front housing and the phone to release the housing catches along the sides of the front housing
    7. Carefully lift the bottom end of the front housing over the phone. The earpiece will still be connecting the front cover to the rest of the phone at the top of the phone so be careful
  • Removing the earpiece speaker from the front housing:
    8. Use the plastic shim or tweezers to separate the earpiece speaker from the front housing
  • Removing the LCD screen:
    9. Use the tweezers to release the display module assembly latch located at the side of the display module
    10. Lift up the top edge of the display module
    11. Carefully thread the display flex cable through the slot in the chassis assembly and lift the display module away from the chassis
Replace the old screen with new an
d reverse the whole procedure for reassembly
Take care
Posted on Jun 18, 2010
Testimonial: "thanks alot for this "
SOURCE:
Service l6 10
Sharp AR-M207 . Enter these keys one after the other to reset:
  1. # - * - C - *(pound, star, C, star).
  2. The screen will go blank and ask you to enter a code
  3. Enter "14" and press the print button.
  4. It comes back and asks if you are sure(showing "1" as default). Press enter.
  5. Machine should then reset
Aug 21, 2013 | Sharp AR-275 Copier
My motorola L6 Phone fell, kinda got wet, and now it cannot turn on, what are the possible causes?
As soon as it got u should remove d battery & dry every parts. For drying u may put it in uncooked rice.
Aug 27, 2009 | Motorola Mobility L6 Cellular Phone
Nokia N95 8Gb fell,screen is white.
The screen cable may have become loose or dislodged. You can find out how to replace the screen and also to check the cable here - http://spyda.vox.comlibraryphoto6a00d09e7ac027be2b00d41442e37f685e.html.
You can pick screens up on ebay too.
Apr 05, 2009 | Nokia N95 Cellular Phone
L6 phone
Hi!
My phone also fell into a bucket full of water. I just gave the phone to the service center for repair and it's now absolutely fine.
I would suggest you to do the same. Also, don't try to switch on the phone as it may lead to short circuit in your phone.
Thank You
Oct 04, 2008 | Motorola Mobility L6 Cellular Phone
Messages
from your cell phone dile in the cell # and send it. that should bring you to your voicemail.
if that wont work try taking out any memory cards or any other accessorys the phone may have.
If you have voice recognition on your phone try using that to get to your voicemail.
Aug 06, 2008 | Motorola Mobility L6 Cellular Phone
Blank screen
apparently you damaged your flex cable that connects the main board to the lcd - hence your calls work , but nothing on screen - to repair it costs - $25-40
http://horizonwirelessonline.com
Jan 23, 2008 | Motorola Mobility L6 Cellular Phone
L6 Band IN London? charging problem
try a new battery.......if that does not help then change the mainboard....or have the phone reflash.
850/900/1800/1900
Dec 17, 2007 | Motorola Mobility L6 Cellular Phone
Can't receive calls
majer of peoples suffer with this problem .........................
just do flash u r phone with help of flash saftwere
Nov 21, 2007 | Motorola Mobility L6 Cellular Phone
L6 fell into water - sticker still white
leave the battery out of the phone for 24 hours, lay the phone face down in a window seal where it can get dry heat. magic
Oct 09, 2007 | Motorola Mobility L6 Cellular Phone
Motorola Mobility L6 Cellular Phone Logo
125 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
