One of the fans on power supply unit does not work, is this the reason behind the beeps my packard bell pc desktop sounds and doesn't send any sign on the screen?
If its a Repeating short beeps, this tyically implies power supply or mainboard issues. However here is list of Pachard Bell Beeps codes for the main boards.
Beep Code Description 1 1 3 CMOS read/write failure 1 1 4 ROM BIOS checksum error 1 2 1 Programmable interval timer failure 1 2 2 DMA initialisation failure 1 2 3 DMA page register read/write failure 1 3 1 RAM refresh verification failure 1 3 3 First 64k RAM chip or data line failure 1 3 4 First 64k RAM odd/even logic failure 1 4 1 Address line failure first 64k RAM 1 4 2 Parity failure first 64k RAM 2 1 1 Bit 0 first 64k RAM failure 2 1 2 Bit 1 first 64k RAM failure 2 1 3 Bit 2 first 64k RAM failure 2 1 4 Bit 3 first 64k RAM failure 2 2 1 Bit 4 first 64k RAM failure 2 2 2 Bit 5 first 64k RAM failure 2 2 3 Bit 6 first 64k RAM failure 2 2 4 Bit 7 first 64k RAM failure 2 3 1 Bit 8 first 64k RAM failure 2 3 2 Bit 9 first 64k RAM failure 2 3 3 Bit 10 first 64k RAM failure 2 3 4 Bit 11 first 64k RAM failure 2 4 1 Bit 12 first 64k RAM failure 2 4 2 Bit 13 first 64k RAM failure 2 4 3 Bit 14 first 64k RAM failure 2 4 4 Bit 15 first 64k RAM failure 3 1 1 Slave DMA register failure 3 1 2 Master DMA register failure 3 1 3 Master interrupt mask register failure 3 1 4 Slave interrupt mask register failure 3 2 4 Keyboard controller Test failure 3 3 4 Screen initialisation failure 3 4 1 Screen retrace test failure 3 4 2 Search for video ROM in progress
4 2 1 Timer tick interrupt in progress or failure 4 2 2 Shutdown test in progress or failure 4 2 3 Gate A20 failure 4 2 4 Unexpected interrupt in protected mode 4 3 1 RAM test in progress or failure>ffffh 4 3 3 Interval timer channel 2 test or failure 4 3 4 Time of Day clock test failure 4 4 1 Serial port test or failure 4 4 2 Parallel port test or failure 4 4 3 Math coprocessor test or failure low 1 1 2 System Board select failure low 1 1 2 Extended CMOS RAM failure
Is there beeps coming from inside the tower case? Does the Hard Drive make a spinning sound after about 15 to 20 seconds? It could be a mother board issue, it could be a graphics card issue.
If you press the ON/OFF button, and then you do NOT hear anything (no fans, no beeps), then the power-supply inside the desktop has failed. Take the computer to any computer-store, so that they can sell you a compatible replacement power-supply.
Probably $40 to $80, plus installation.
i'd say your not passing the post test....if you hear a beep when you start your pc it should boot to windows screen if you dont hear beep you could have a loose cpu fan open up pc and make sure the fan is secure if not try tightening it can be tricky either that or it could be your power supply i wouldnt attempt fixing that if not sure what your doing..or try turning off your pc plug it out disconnect all periphals and press in the on button and hold for 2 minutes then try and boot
if it beeps there is a memory problem inside if not turn it on so its orange turn it a round and flip the the red switch on the back of the power suppy, multiple times and then start turning off the computer, ive got that to work it could just something dumb with the power supply
Sounds like an overheating problem. Clean the dust out of it, make sure it can get air on all sides, make sure the fans are turning. If that doesn't work, unplug the computer, hit the power button 20 times, wait 1/2 hour and boot it up.
Huh! Sounds like a power issue. Unplug, try cleaning out the guts in case something got in there, and retry, and again with a spare power supply if things are still bad. It would help to know whether something other than the power supply's clicking, I suppose....
Did you check the power lead or the power supply in another pc.
if you checked the power supply unit in another pc and it's fine, there is a faulty switch on your pc or faulty motherboard.
Check that the 21 pin connector from the power supply unit to the motherboard is in properly as the psu will not work if disconnected from the board.
