Sony FD Trinitron WEGA KV-20FS120 20" TV Logo
Posted on Apr 13, 2008
Does not come on when turned on
We shut if off, and it will not come back on, the little red light just blinks and nothing happens. Is there a reset button I am just not seeing?
  • Anonymous Apr 16, 2008
    when turn onn no have image very much time
Anonymous
Level 1:
  • Contributor 54 Answers
  • Posted on Apr 14, 2008
Anonymous
Contributor
Level 1:
Answers
54
Questions
Helped
14494
Points
86
Sometime when the red ligth blink there is a problem in the system inside the tv. I suggest to fix it by a repairman tech.
1helpful
I have a 2003 sony kp51ws500 television and there's a timer on the tv and it won't turn on. A red light blinks 6 times then nothing happens. I unplugged, I hit the reset button, nothing happen
read the instruction manual and see how to operate.
if the timer is for to sleep, the problem will be the IC associates with him, you must see the block diagram and w.diagram. and tracking the signal.
go to www. retrevo.com and download the diagram. God bless you
Samsung CLP-315 This unit has seen very little use. Perhaps 100 pages. It sat idle for 9 mos. while we were in FL. When I returned home I turned it back on and printed 1 page with it. I thought all was...
It is possible that it reciecved a small power surge while you were gone on your trip, and you need to leave it unpluged from the wall for 40 Min, to clear and reset the operating processor.. It should go back to normal after leaving unpluged, but you might have to run set up program agian too.
I cant get it to turn on the red light blinks but thats it
check the ground. it is most likely disconnecting also check the fuse between your battery and the amp and the actual amp fuse.
1helpful
Red light blinks but nothing happens
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
2helpful
3answers
Red Light
slow blinking light means the unit is in DRY MODE.. flast blinking light means some sort of arcing or bad power supply..
if in dry mode let the unit run for an hour and it will stop blinking ..
2answers
Sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
7helpful
3answers
Tv plays for a few minutes then shuts down. the red light blinks.
You need reset the lamp timer after
replace the new lamp.In the remote control pres menu------setup------lamp timer----message do you replace a lamp appear----press yes----and ok.
88helpful
10answers
My flip video camera froze.it wont turn on....
Have you tried resetting the camera? Hold down the power button and the red button simultaneously until the camera shuts off (takes about 10 seconds). Then, just press the power button again and the camera should turn back on. I had the same problem; when I pressed the red button to stop recording, the camera froze, and the red light remained on. I tried resetting it like this, and it seemed to work.
NOTHING HAPPENS!!!!!
power supply probel, need to take to service
Blue screen and shut off by self
You will need to reset the Netcommand and tuner settings in the set. The little indented button in the front of the set needs to be pushed in (when the set is off). The front light will blink for about a minute or minute and a half. Then, reprogram the Netcommand settings. This should solve your problem. If you need more information, then, reply to this post and I will respond.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
