The picture is to high. I cannot see the top of the picture .Like on the base ball games the bases the outs .and innings do not show on top of the screen.
  • papaearl6 Apr 14, 2008
    This is on a sharp 52 inch Hdlc TV. 1080 AQUOS
    I do not have a projection TV. I have A 52 in 1080 AQUOS TV HDLC
  • 19,396 Answers
Your TV has either a vertical alignmet problem or a yoke adjustment problem.
In few cases you can fix a verical alignment problem with a reset procedure , as suggested, but in majority of tv sets you need to pervorm a service alignment procedure.
If is not that is a yoke adjustment problem, in this case TV need a yoke adjust procedure, this must be done on open tv with power on. It is quite a dangerous operation if not performed by an expert, in this case you will have to contact a repairman.
I can be more precise if you post make and model for your TV.
Regards
Posted on Apr 18, 2008
  • 1 more comment
  • Ginko
    Ginko Apr 18, 2008
    If it is an LCD then you need to adjust the alignment. Check if he procedure is in user manual, athorwise should be in the service manual, that is not available for download.
    Try contacting Sharp and get a copy, or ask the procedure for vertical alignment.
  • Ginko
    Ginko Apr 18, 2008
    Here is the user manual
    Follow the procedure at page 31, I think it will fix the problem.
  • Ginko
    Ginko Apr 18, 2008
    If you fix it accept best solution.
    Genius:
  • 1,142 Answers
Reset the tv set to the factory settings and that should resolve the issue
Posted on Apr 14, 2008
Screen resolution - Picture too big for screen
the resolution from the source is set too high, also check the settings in your television it may be set too high.
Oct 25, 2008 | Televison & Video
Tip
Playing skee-ball like a winner
Skee-ball is a bowling type arcade game where each player gets 11 balls that they have to roll up a ramp to try and get it into one of the holes at the end of the ramp. Each of the holes have a point value between 10 and 100 based on how easy they are to get the ball into.
Not all skee-ball machines are created equal so if you pick a machine to begin with you should stick to that machine. There can be small differences in the tilt or angle of the ramp that can really mess with your aim. You might think that changing machines will change you game but sticking it out and figuring out what is messing you up will actually make you a better skee-ball player.
Most people play and try to get the ball into one of the two 100 holes at the very top of the board but these two holes are the hardest to hit and if you miss in most cases result in no points. If you play with your friends you can make sure that you always get some points and maybe even the high score by always aiming for the 50 point hole in the top center of the board.
The reason that you should aim for the 50 point hole is because even if you miss this hole you have a very high chance of winning 10, 20, 30 or even 40 points. So while everyone else is failing to get the ball in to the 100 point hole you can rack up the points with this technique. But remember that in the end it is just a game and you are all out to have a good time.
on Oct 13, 2013 | Video Game Consoles & Games
How strong is base frieza at fourth form resurrection f without his golden frieza form
A good bit weaker than Saiyan beyond God Goku and Vegeta in their bases. For a comparison, Frieza would be a 1, Vegeta a 1.4, Goku a 1.6, Beerus a 10 and Whis a 15.
Sep 04, 2016 | Dragon Ball Kai: Doragon boru kai (2009)
Base of tatamia will not fold up, cables appear to have come lose from bottom. How do you disassemble the bottom to repair
Did you ever figure this out. I just got the Tatamia today and already the base won't fold up. The cable are still attached underneath the handles but it doesn't seem to have the resistance when pulling anymore.
Aug 14, 2010 | Toys
Spring loaded ball bearings - does the ball bearing sit on top of the spring or below the spring??
The ball bearing is a check valve. The ball should be in the input side of the water with the spring underneath.
input side ----->( O/////)-------> output side
Feb 21, 2010 | Jura Capresso Capresso Infinity Conical...
Gray triangle-shape base and ball-typed cam place on top of it
Its an older model called the QuickCam express if the decription was what I'm thinking it looked like.
For drivers go to
http://www.logitech.com/index.cfm/support_downloads/
go search by pictures
You probably won;t find it so hit the "Still Can't Find it" link and it pulls up the older products. When you see it click on the image and it goes to the page that shows the specs and has the drivers.
Jul 09, 2009 | Logitech Webcam
Help needed to adjust the picture size.
I can only suggest that you read the manuel it should give you guidelines for this problem .. if you do not have the manuel you may be able to download one in PDF form from the manufacturers .
The other slight possibility is if the projection unit is a rear free standing type it may have been pushed closer to the screen some how perhaps during a furniture reshuffle I have had this happen before and people dont think of it untill the engineer ask's ? .. regards Vortash
May 10, 2009 | Hitachi Televison & Video
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
