Power problem with car cd player_JVC KD-SH77R
Hi, having trouble getting player to boot up. power in is all checking out, i.e."red'_fine,"yellow"_fine,"black"_grounded. "Power/source" is lit up on stand-by, but when I press itfor power, the unit won't kick in. I've pressed "reset", it lights up ok then gos off in about 5 seconds( I don't know if that is normal).Any suggestion? Mark.
  • 323 Answers
Try hooking your cd player directly to the battery and see if it will turn on that way. May not have a good ground source. You have yellow running to your cigarette lighter and your red running to fuse box or power lead to battery source?
Posted on Apr 19, 2008
Swapped red and yellow wires on my JVC KD-R200, then swapped them back. Now it only powers on when I push the Eject button. Otherwise, nothing
Swapping the red and yellow wires cannot possibly have any affect on the radio. Both wires need to see 12 volts for proper operation. If they are reversed, it would only simply fail to save the memory settings. You have other issues. You have probably lost power on the red wire.
Dec 25, 2013 | JVC KD-R200 Car CD/ MP3 Player
Need info on wire color coding for jvc car cd player: JVC KD-G140
Try going to the crutchfield website and look for help installing stereo. they can get you vehicle specific wiring codes for free. Also, almost everey stereo has common color codes for wiring. red- switched batt. +, yellow-constant batt. +, black= ground, blue- power anrenna, etc.
Apr 12, 2010 | JVC KD-G140 Car CD Player
Jvc kd-s590, installing in other car and only the att (red) light comes on no display or sound. tried resetting, fuse is good. that's it.
sounds like only the constant(yellow) wire has power. you need to make sure that the switched wire(red) has power as well. good way to trouble shoot, is to hook the red to the yellow to see if it powers up then, if so you know the radio is ok, you just need to find a better power source for the red wire. hope this helps.
Aug 18, 2009 | JVC KD-S570 CD Player
JVC KD G230 CD player power trouble...
tienes q revisar voltage de entrada el de stand by y el regulador si no te sale verifica el micro procesador
Mar 07, 2009 | JVC KD-G230 CD Player
Jvc kd-sc500 cd car stereo
Jul 21, 2008 | JVC KD-SC500 CD Player
JVC KD-G200 cd player
I would suggest checking the accessory (red wire), the yellow is a constant feed from the battery, which will allow the clock to be displayed no matter what. The accessory wire is what is used to turn on the cd player. You may need to restrip the red wire and check the lead going to the red wire with a test light to make sure it is getting a voltage light.
Mar 03, 2008 | JVC KD-G200 CD Player
KD-G421 in Vectra Envoy 99
To stop the memory loss you need to swap the red and yellow wires around. (battery power and ignition power).
To stop the date loss, you need to cut the electrical ariel/remote blue wire.
Dec 27, 2007 | JVC KD-G421 CD Player
JVC KD-G110 car music system is taking CD and not getting played am not able to function any ...?
Hi. your radio has 2 power wires. A red one and a yellow one (with most decks) It sounds like your radio is getting only constant power but no "key on" power. Check your radio with the key on you should have power on both the red and yellow wires. If you are missing power on one of the wires theres your problem. If you have power on both wires then there is something internally wrong with your radio...
Sep 08, 2007 | JVC KD-G110 CD Player
Trouble playing JVC KD-S580
i have the same problem in a 2001 mercury cougar. i got power all the way to the back of the radio from the ignition (red) and constant (yellow) wires and the ground wire is good. Think the head unit might be screwed the fuses are all fine. not sure though
Nov 11, 2006 | JVC KD-S580 CD Player
77 people viewed this question
