Question about Sony SDM-HS73P 17" LCD Monitor
Monitor going black
You said it is a capacitor......do you know which one or where I could find it?
  • 180 Answers
At all radio shack.
Posted on Apr 23, 2008
My monitor goes for 3 seconds black, every 1 minute
First thing, try to connect the monitor to another CPU and see if its gonna work. If it doesn't, then this might be a capacitor failure. One of the capacitors in your monitor that are responsible for holding up power for proper display is faulty. A faulty capacitor is either bulged(with a hump head) or burst. This causes the monitor to go off a few seconds after you switch it on because the capacitors can no longer hold power long enough for your display. One way to work this around is to take your monitor to a Computer Technician to open it up and probably replace the faulty capacitors
Nov 06, 2011 | LG Flatron L1718S LCD Monitor
Having a LG Flatron L1718S. In the last week, when I start the monitor it shows about 1 second the image of the computer, the it turns black. Same appears when I disconnect it from the computer - a...
That means the monitor has a problem with the Capacitors. Capacitors inside your monitor can no longer hold up power long enough for your display. This is so because the capacitors might have been blown. This makes the monitor to go on for about 2 to 3 seconds then it goes off.
The solution is to change the capacitors from the board (the part that you connect he power cable). This must be done by a Computer Technician who will safely carry out the procedure. Open up the monitor, using a flat blade and try to separate the cover with the LCD, starting from the bottom, working your way through around. Before you do anything, check for any burged or any with a black smoked colour capacitors...If you find any, then it has to be replaced
Aug 22, 2011 | LG Flatron L1718S LCD Monitor
My LG 23SL7D will not stay on, it temporarily will connect to PC then screen will go black.
If the screen keeps going black and you know thet your graphics card is ok (test monitor on another computer), then the issue is probably with the internal monitor power capacitors, which you will need to take to a TV repairman to have inspected
Dec 31, 2010 | LG Computers & Internet
Monitor goes black after 10 minutes. Turn it off ...
Change eletrolitic capacitor in the power supply which is deformed.
WARNING: RESPECT THE ESPECIFICATION OF THE EACH CAPACITOR AND POLARITY!!!
Black side = Negative (-)
This video show you how to
http://www.youtube.com/watch?v=YCSNWi3UHf4
Best regards,
May 16, 2010 | Computers & Internet
Monitor stays on for 1 sec and goes black
sorenke, Monitor "switchmode-mode-power-supply" going into shutdown mode when detecting a FAULT CONDITION with some other circuit or with itself. Your monitor has same technology as any other backlit lcd display!! Read more of my responses to owners that have BLACK screen problems. Some have BLACK and BLANK screen problems Do you know flashlight test of SMPS status? How old is unit? How many Total "ON" hours unit have? Do you know what a bad electrolytic filter capacitor looks like? Have you been to YOUTUBE yet? 12fixlouie
Dec 15, 2009 | Hannstar I-Inc TW-191D Monitor
Dell 22" monitor goes black
Your monitor probably has bad capacitors now. Bring it to a local electronic repair shop and have the monitor tested. They can easily replace any bad capacitors.
I hope this helps. Have a nice day.
- HotRatchet
Dec 14, 2009 | Dell 22" SP2208WFP Widescreen Flat Panel...
Flicker then display goes black
your monitor got trouble at:
1) monitor inverter board components fail like capacitor or MOSFET diver, it can repair or change this parts to fix.
2) there is disconnection between the inverter and CCFL lamps
need to check by technician, it could be fixed,
3) check the DCpower supply board capacitors swelling which need to reaplace, and fix it.
all steps need to do and fix it well.
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
May 24, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Starlogic 20 inch widescreen monitor screen keeps going black
bad capacitors you will need to replace the "blown caps" and resolder new ones in.
Feb 01, 2009 | Star Logic 17" LCD Monitor
Monitor going black
HP's are known for bad capacitors in the power supply.
Replacing them is simple if you know how..not so simple if you don't.
Try your local TV repair centre. It should not cost alot to have the capacitors replaced.
Hope it helps =)
Apr 06, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
E153FP Monitor screen goes black light is green
The capacitors are probably bad. It is a common problem and easily fixed by taking it apart and replacing the capacitors. Try to find Rubycon Capacitors because they very rarely go bad. Do a search on google for bad caps. I have fixed about 30 monitors this way. Dell is a company well known for bad capacitors. It may not be your problem but replacing the capacitors should cost less than $10 if you do it yourself. www.photphot.com
Oct 23, 2006 | Dell E153FP 15" LCD Monitor
Open Questions:
Sony SDM-HS73P 17" LCD Monitor Logo
48 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
