Does my rca tv model f27650 have a atsc tuner
  • 84 Answers
No it does not
Posted on Apr 13, 2008
RCA Guideplus gold gemstar analog or digital
Most of the RCA GuidePlus Gold gemstar TVs worked with analog TV signals (NTSC) only. The Guide+ information was only broadcast in NTSC signals and is no longer being provided. If you can check the date of manufacture of the TV, you can use the size to check if it had an ATSC tuner added if it was made for the US market. 37"+ TVs had to have a digital tuner in second half of 2005. 25" TVs needed to have the ATSC tuner after March, 2006. The next year all TVs had to have a digital tuner.
I hope this helps. Please add a comment with the model number of the TV, if you would like me to confirm the tuner information on your set.
(The RCA F31317 TV with Guide+ was manufactured in 2000 and thus only has a NTSC tuner.)
Dec 26, 2015 | RCA Televison & Video
Is the Rca true flat digital
I'd need the model number to tell if the RCA TV has a digital (ATSC) or analog (NTSC) tuner. The mandate for inclusion of the ATSC tuner depended on the size of the TV and the year of manufacture. Small (<25" diagonal) TVs didn't need to have an ATSC tuner when they were built until 2007. The older TVs could still be sold with a "cable-ready" or similar NTSC only label. (The 32"+ TVs had to have the ATSC tuners in 2005 and the mid-size TVs had to have the digital tuners in 2006.)
For example the 27F530T was manufactured in 2003 and only has a NTSC tuner. However, the 20F424T was manufactured in 2008 and does have an ATSC tuner.
I hope this helps.
Aug 07, 2015 | RCA Televison & Video
Atsc tuner
that is a good question that you can answer for yourself.plug in the antennawire and turn it on . if not you need one of the converters
Jan 21, 2015 | RCA Televison & Video
Does RCA model F27450, made in November 2002, have a digital (atsc) tuner?
Doubtful. That's long before digital broadcast was implemented. You will need an adapter box.
Sep 09, 2014 | RCA F27450 27" TV
I have a Jensen TV, Model Number TS2050J. I need to know if it has a QAM tuner built in.
Hi.
No, your tv is an older model sdtv with an analog only NTSC tuner.
Newer model have an ATSC/Qam digital tuner, but not your model.
This means that if you want to watch tv, you'll have to get a converter box. It will have the ATSC/QAM tuner i it, and it converts the signal into lower definition NTSC, and then sends it to the tv through either coax cable, or rca cables.
Once in a great while you might even find one that has s-video output, but those usually are expensive.
I hope this helps you out.
Feb 08, 2011 | Jensen TS2050J 20" TV
Is the rca true flat tv able to be used by putting up an antena -or will we need a convertor box ? currently we have direct tv and are thinking about canceling it and use an antena.
This model does not have a built in HD tuner (ATSC Tuner). You would need an HD antenna (that is a more recent antenna that receives UHF) and an HD converter box to get the newly broadcast HD signals.
Nov 06, 2009 | RCA TruFlat 27F520T 27" TV
Programming a ATSC DTV tuner on a RCA Universal Remote
Try a code for a "satellite receiver" of the same manufacturer of your DTV tuner. I've heard of a cross-remote complaint with the DirectTV box and the DTVPal box. Note, your DTV tuner may say RCA, but it could be manufactured by a common DTV tuner maker. The system looks very close to a Zinwell. Don't have an RCA model to try the codes out, though.
Dec 27, 2008 | Televison & Video
RCA Model # F36650 tuner.
if your tuner is already dead replace it.because the original tuner of your TV is very expensive. the solution of your TV is converting tuner, you buy a kit name AUDIO TV CONVERTER . simply conection and and not very expensive. just plug the unit to ac line and connect the cable line to rf of your Television and its OK. im just trying to suggest my solution to you JRANDY phillipines tech
Apr 19, 2008 | RCA F36650 36" TV
Rca g26261tn colortrak television
If the TV is HD then yes it is ATSC if it is HD ready Then it is NTSC if it is noe of the above then it is NTSC. The Advanced television standards committiee was developed in 1982 .
Mar 08, 2008 | RCA F32665 32" TV
RCA F27650 27" TV - Snow Bursts
The model you listed, F27650 uses the new ATC113 series chassis, which is only about 3 years old. The ATC113 chassis is not known to have snowy issues, but if yours is then I would suspect that a solder joint is loose in the tuner. If your set is actually around 9 years old, then it might perhaps have the notorious CTC175 - CTC187 series chassis, which went snowy all the time due to cracked solder joints on the shield grounds around the tuner and microprocessor. In either case, some good quality resoldering should cure your trouble. If you have never done fine solder work on PC boards with small surface-mount parts, allow a qualified tech to handle it for you.
Aug 08, 2007 | RCA F27650 27" TV
Televison & Video Logo
Top Televison & Video Experts
