Question about Samsung HP-T5044 50 in. Plasma TV
Samsung HP-T5043 blank/black square in center of display
I have a HP-T5054 mounted on the wall. It was working fine. I know have a black rectangle in the center of the tv approximately 27 x 15 inches. At this point, it only seems to occur on channel 2 and will go away for about 45 seconds if I hit the channel 2 button or change the station monemtarily. If I watch a different station, it doesn't occur. Any suggestions?
  • 54 Answers
Turn off the closed captioning. it is set to a text mode which only certain stations use with their closed captioning. use the tv remote menu key and find closed captions and turn it off
Posted on May 26, 2009
Black Rectangle on my TV Screen
turn off cc1 cc2 ccoff turn off close caption 95% off the time this is it ,some one might have hit it by mistake ,or you had a power out and it went stright to this good and do try before you buy another one
Jul 17, 2010 | Premier Mounts Universal Flat Panel Wall...
Blank Screen
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Sep 18, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Picture remains for few seconds then screen goes blank, sound remains on
I had this problem on my 42" Philips LCD. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
Sep 01, 2009 | Samsung SM932MW 19 in. LCD TV
50 inch Plasma Samsung HP-T5054 appears to have power however...
check the power inverter on the power strip. also check the caps on the board and if any of those caps have a round top it is bad and needs to be replaced. i hope this helps.
Jul 28, 2009 | Samsung Televison & Video
The screen goes complete blank with sound still on. It takes to shut TV off and power it on right away to get picture back-though the intervals getting shorter down the road . MY Screen goes black and I...
Jun 01, 2009 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
Screen goes black tv stays on. Turn off and on and TV's fine.
Mar 20, 2009 | Philips 42PFL3603D/27 42 in. LCD TV
I have sound but no picture on my 32 inch LCDHD TV/DVD. Picture flashes for a second an then the screen goes blank. Thanks Bill
This problem is caused by one of thee problems.
1) The inverter board(s) is bad.
2) Power to the inverter board(s) is off.
3) The CCFT(cold cathode fluoresent light) is bad.
Since the picture flashes for a second you may also check for loose connections for the above items.
Here is a simple test you may also try. With the TV on take a bright flashlight and press it against the screen. Look for an image around the edge of the flashlight. This will verify that an image is being sent to the screen.
Mar 12, 2009 | Televison & Video
Whilst watching tv after 10 to 15 min screen goes blank but sound ok ,when u turn tv off then back on u get pitcure for about 10 minthen goes off again
Feb 28, 2009 | Samsung LE40R74BDX 40 in. LCD Television
Lg lcd tv screen goes black but the sound still works 52lg70 screen goes blank, sound still works. i can change settings but cannot see the menu so the tv is still working there is just no picture.
This sounds like a mainboard problem. Unless you do not see a back light flash when you turn on the TV, which may mean it is an inverter board problem, this is most likely fixable by replacing the mainboard.
Jan 20, 2009 | LG 52LG70 52 in. LCD HDTV
Samsung HP-T5044 50 in. Plasma TV Logo
281 people viewed this question
Henry  Thomas
Henry Thomas
