Question about HP Photosmart C6180 All-In-One InkJet Printer
Ink system failure
I get that message and have tried everything to fix it!! HELP!!
  • 1 more comment
  • Anonymous Apr 15, 2008
    my printer just did the same thing. called HP they can't fix it. I have had nothing but trouble with this printer, it is by far the worst printer I have ever had
  • Anonymous Apr 24, 2008
    My printer says ink system failed. This is a businnes & I need to get faxes and use my printer. Help someone at HP. My warranty is up & I can't get an answer from the main office
    Thanks, Mmeme
  • Anonymous May 01, 2008
    Error message states "Ink system failure OXC19A0025. The repairman fixed it, bought it home & it did the same thing again. He said he did a hard drive over ride? I think. HELP!
Actually, you can go to the HP chat for support. They'll walk you thru a hardware restart to remove the error code. The HP chat support is the way to go if your warranty is expired.
Posted on May 14, 2008
I believe you are correct about the printer being done. I had the same issue and called tech support and was told we should have someone from HP repair it. It is cheaper to buy a new one. We used it for approx. 1 year and 5 months, it worked fine until the Ink System Failure error appeared, now it is useless to us. Good luck.
Posted on May 09, 2008
I believe your printer is over. There is no fix for this type of issue. I had the printer for 1 year, used it for about 100 pages, changed a couple cartridges and got the failure ink system message. As one of the answers I received it is a bad design in the these types of HP inkjet printers. I will be putting it in the garbage!!!!.. No more HP for me. HP help desk is no good. They want you to purchase another machine.
Posted on Apr 24, 2008
Error code OXC4B827F
This is an Ink System Failure message. I would try this guide. 'Ink System Failure' or a '0x...' or a 'C2...' Error Message Displays on the Front Panel. To help resolve the issue.
If that doesn't work, please call our technical support at 800-474-6836. If you live outside the US/Canada Region, please click the link below to get the support number for your region. http://www.hp.com/cgi-bin/hpsupport/index.pl.
Oct 12, 2015 | HP Officejet 4630 Inkjet Multifunction...
What is error 0xc19a0003 mean for the HP Officejet 4620
ink system failure - error 0xc19a0003 means ink system failure error usually occur if you have issues with your ink cartridge or printheads. Have you try replacing either of the two?
May 12, 2014 | HP Officejet 4620 e-All-in-One Printer,...
I am getting a error message saying the printer does not have enough ink to ensure printer health. The empty ink cartridge must be replaced to resume printing. I replaced the cartridges and it does not...
These printers have been known to have ink system failure errors. This message can also be caused by using compatible or re-manufactured cartridges. We believe the HP Live update software is also responsible for "dobbing" on you if you use any other brand.
A Fix for the ink system failure can be found below Not sure if it will help with your particular error but it wont hurt to try.
http://fix-your-printer.blogspot.com/2009/03/ink-system-failure-on-hp-photosmart.html
Good luck
Apr 14, 2011 | HP Photosmart C6180 All-In-One InkJet...
Will not print, has error message 0xc18a0406. ink system failure
The ink system failure message has a chance to be fixed or it may be a permanent issue. It can be pointing toward a firmware failure in the printer and if that is the case the following steps should fix it.
Press and hold the “*” key. Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
Press and release in sequence the "1”, “2” and “3” buttons.
Display should say “Support” and display the FW rev (something like R0631R)
Mine reads R0631M
. Press and release the right arrow button until the display says “System Configuration Menu”.
Press and release the “OK” button.
Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
Display should say “Hardware failure status: Clear. Press OK to clear”.
Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer.
Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
Jan 20, 2010 | HP Photosmart C6180 All-In-One InkJet...
I have a printer ?HP c7280 All-in-one?a message, ?Ink system failure, error: 0xc18a0201.?
The ink system failure message has a chance to be fixed or it may be a permanent issue. It can be pointing toward a firmware failure in the printer and if that is the case the following steps should fix it. Press and hold the ?*? key. Press the ?#? key and release both keys. Display should say ?Enter Special Key Combo? Press and release in sequence the "1?, ?2? and ?3? buttons. Display should say ?Support? and display the FW rev (something like R0631R) Mine reads R0631M . Press and release the right arrow button until the display says ?System Configuration Menu?. Press and release the ?OK? button. Display should say ?Hardware failure status?. If not there already, Arrow Key over to ?Hardware failure status?, Press and release the ?OK? button. Display should say ?Hardware failure status: Clear. Press OK to clear?. Press and release the ?OK? Button. Message changes to ?Hardware failure status Cleared. Press Cancel to continue?. Press and release the ?CANCEL? button as many times as necessary, so that, either the ?Welcome to Photosmart Express? screen appears, or, the ?Ink System Failure? screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer. Turn the unit on. The printer may display message ?USE POWER BUTTON TO SHUTDOWN THE PRINTER? followed by ?PRESS OK TO CONTINUE?. Press OK. The Printer will start the ?ONE TIME INK INITIALIZATION PROCESS?. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
Jan 11, 2010 | HP Photosmart C7280 Printer
HP 8250 Photosmart printer that displays "system ink failure"
Try changing the ink cartridges.
If you installed the "HP Support Toolkit" software from the CD-ROM that came with the printer, use this Toolkit to "run a cleaning cycle".
It can print a "test" page, to show you which colours _do_ work, and which do _not_ work.
If all else fails, then find a qualified printer technician.
Dec 31, 2009 | HP - HP Photosmart 8250 printer
Can print...ink system failure - followed process but it wont wor
release the right arrow button until the display says “System Configuration Menu”. (on C8100 use Touch Screen)
2. Press and release the “OK” button.
3. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
4. Press and release the “OK” button.
5. Display should say “Hardware failure status: Clear. Press OK to clear”.
6. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
7. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
10. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
11. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
13. If the error is still there, or reoccurs replace the unit
Aug 21, 2009 | HP Photosmart C6180 All-In-One InkJet...
Ink system failure
have you unpluged it from the outlet? can you see any paper stuck?
otherwise you have a bad system board and would cost more to fix than just to by a new one.
Sep 02, 2008 | HP Photosmart D7360 All-In-One InkJet...
HP Photosmart c7180: "Ink System Failure" error code Oxc18a0306
I get the ink system failure message on my hp c7180 as well as an error code of oxc18a0306.
Aug 24, 2008 | HP Photosmart D7160 InkJet Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
199 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
