Frequently when I turn on my 18-month old Samsung HL-S6188W (61" DLP) it is in a mode where none of the on-screen graphics (like the active input or volume level) show up. Also only some of the video inputs will actually get displayed. The only way I found to fix it is unplug the AC power. This seems to fix the problem. Has anyone else seen this problem?
    Genius:
  • Televison & ... Master
  • 1,673 Answers
This sounds like a problem is starting in the control area for the display information. Eventualy the set will need service for this. Most likely a component(s) is starting to fail in the area for the display information.
Jerry G.
Posted on Apr 13, 2008
Cannot change source or TV input. Stuck in HDMI2.
Sounds like you have a defetive main pcb. You might try a firmware update if there is one first.
Mar 19, 2013 | Samsung HL-S6188W 61" HDTV
Had check fan no 2 on tv. I replaced. The bulb is about 6 months old as well. I power on both fans are working the bulb comes on but the tv shuts off after a few seconds before the picture even comes on....
U recheck the tv projection lamp connections,the door latch and the lamp door closed properly and tightly.Yes,if the tv projection lamp LED light indication "LAMP" word it is still flashing or staying on the tv projection lamp some how dying again.The tv projection lamp should be replacing it again.
Sep 02, 2011 | Samsung HL-S6188W 61" HDTV
The audio on my Samsung HL-S6188W DLP TV is completely out--no sound from TV speakers in any input mode (ATSC built-in tuner, component-in, etc.). Furthermore, the optical-digital audio out does not...
Check your mute on /off status through your remote. If it is changing status & no sound,
It looks like sound circuit problem.Contact service center for assistance.
Apr 21, 2010 | Samsung HL-S6188W 61" HDTV
Loud hum and then an even louder grinding noise that sounds like something in a fan...Samsung hl r6167w
this is more than likely the color wheel is failing and needs replaced happens on dlp units frequently I would suggest replacing the color wheel should fix the problem
Jan 24, 2010 | Samsung HL-R6167W 61" HDTV
I replaced the fan # 2 after getting that error on
Which fan did samsung say was fan #2 ? As from my experience dealing with Samsung they dont know the difference between the fans but fan 2 error is usually refering to the fan under the light engine in the L7 and the L6 its the small one in the gray plastic case which blows under the ballast.
Dec 09, 2009 | Samsung HL-S6188W 61" HDTV
Tv turns on and plays pic for 3-5 second and turns off
This could be a ballast issue. It's a very common issue with Samsung TVs.
Nov 13, 2009 | Samsung HL-S6188W 61" HDTV
White dots on 50in dlp samsung
This is caused by dust or dirt in the Optical Block. Only a good TV Tech can solve this problem.Call one for an estimate.
Aug 03, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Green shade color on screen over tyhe program that is been broadcast
its a loose connections to you color amplifier RGB. cold solder in that board section.
May 30, 2009 | Samsung HL-R6167W 61" HDTV
Samsung 61 inch DLP Has a strobe light affect
possible color wheel,call for est cost of repair
Jul 29, 2008 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
