Question about Mitsubishi WD62628 62" Projection HDTV
Tv only 2 years old
Just a few days ago - my WD-62628 bulb went out. I bought a new one and replaced it according to the instructions. Now the fun begins ....
After replacing the bulb the set powers up with a flashing green light ( I believe it's doing it's diagnostics at this time ) then the green light goes out. I then hit the power button a second time and the set powers up like normal showing video and sound. Problem is after about 30 seconds - the set shuts down and the lamp indicator shows solid red. I have done this serveral times and even reset the tv, yet I get the same outcome.
the manual gives me 2 conditions - for red steady indicator, either the lamp has reached the end of it's lamp life ( can't be this since I just replaced with a brand new one ) or TV may require service.
Any better suggestions?
    Genius:
  • Mitsubishi Master
  • 1,673 Answers
I don't know your set in particular, therefore I will be generic.
On some projection sets, there is an hours counter that is manualy resetable. Make sure that it is reset. If you can have a readout of the amount of hours used on the lamp this will tell you if this needs to be reset.
Normaly, when the set reacts as per your description, there is a cooling problem, or a fault in the power supply.
Also with your model of set, check to see if there are any safety switches that work with the cover or door for the lamp access. With the safety switch option, if the uPC thinks that the lamp is not properly enclosed or installed it will not allow for proper startup.
Jerry G.
Posted on Apr 13, 2008
My sony KP-443X3U rear projection tv went to standby and I cannot get it to switch on. It is approx 6 years old. I think the bulb needs to be replaced?
Google the model number to locate it with "lamp" and You Tube has video instructions for replacing in most models--lamp has a 2,000 hour or 2 year average life and is meant to be replaceable by the customer who owns the set.
Nov 06, 2012 | Sony Televison & Video
Wd65738 flickering
I had a TV do that about a year ago, the repair man said it was the color wheel inside the tv. I changed the bulb to see if he was BS'ng me and eventually got the manufacturer to send a color wheel and I change it myself, was very easy...TV works fine ever since. Hope this helps
Jul 10, 2012 | Mitsubishi WD-65738 DLP TV
I bought a mitsubishi wd 52327 new several years ago. I've replaced the lamp once and it worked fine but now it needs to be replaced again. We bought a lamp off EBay w/housing. I installed it but the tv...
Hi Brent, Mitsubishi's have a problem with the power supply and the Light Engine which incorporates the Digital Module of which it has to be purchased as a complete assembly. I sincerely believe you should not put that kind of money into a dlp set. The cost of the light engine is in the area of $1100.00. Your last idea is the best one.
Mar 09, 2011 | Mitsubishi WD-52327 52" Rear Projection...
My 62 inch dlp tv came on and was working then with out any noise or notice the picture went to black and a steady red light came on under the word "lamp". We looked at the bulb and it does not look burned...
The tv lamp was replaced when? The tv on about 4 or 5 hours a day right?The lamp was replaced about a year or a year an a half ago?The projection lamp is dead,the life span is over.Must replaced with a new lamp.
Jul 01, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-52327 TV won't consistently turn on, new lamp
the problem is in the power supply circuit
capacitor may be or so the click mean theres cap are leakink or get dry that why is so long to power on.
hope that give you a idea.
May 05, 2010 | Televison & Video
Mitsubushi tv model # 52327 ballast replacement
The ballast for the lamp too should be replaced along with the lamp. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Mar 13, 2017 | Mitsubishi WD-62525 62" Rear Projection...
WD-57731 every 6mos bulb replacement
You need to make sure you have at least 6 to 8 inches of clearance behind the set. You may also need to replace the balast
Sep 08, 2009 | Mitsubishi WD-57731 57" Projection HDTV
New bulb/TV still shuts down
Its far more likely the result of the power pwb capacitors that have failed. As the 34 code will appear if the capacitors fail on the Power PWB. You can get the V26 DLP Power repair kit at the following link.with free instructions
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Apr 30, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Blown bulb
time to change the bulb, the bulb doesen't last very long for the price that it cost. I have replaced three in mine in the past three years.
Jul 04, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD62628 62" Projection HDTV Logo
211 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
