Question about Brother HL 1440 Laser Printer
Prints 'dirty' white page
My laser printer suddenly stopped printing data. the paper runs through the printer and comes out looking like a dirty white sheet.
there are no warning lights on the unit. on turning on the printer seems to go through standard startup procedure and indicates ready. When I send any data to the printer I get dirty white sheet. When I press the printer test all I get is a dirty white sheet. I have replaced the toner cart even though the light does not indicate toner is low. I have not tried to change the drum since it does not indicate drum is bad and drums cost too much. Seems to me that data is not getting to the system somehow. All systems for handling the paper seem to work properly.
  • 5 more comments
  • Anonymous May 09, 2008
    random pages will be perfect - the suddenly there's toner everywhere - smeared on pages . When i take the toner out it's amess inside too. Put a new toner, same problem. Help!
  • packice Jul 03, 2008
    I know it and a lot more.
    Take out the cartridge and drum pakkage.
    Take away the cartridge.
    What is left is the drum (grren roll) package.
    You see 2 screws and a little one in the hole. Unscrew them and unlatch the 4 latches
    Wouw you can see a dirty brush. Dirty wire mash. And a kind of chip.That is not a chip. Only a fuse which will blow by Brother software at ??? prints. In the future if the drum out signal comes shortcut it.
    Now I cleaned everything again. Do it outside the powder is not healthy.
    Show me your results
  • cantfinddrum Oct 23, 2008
    I hear clean the drum but for those of us who dont know where the drum is a little visual help might be worth a thousand words. I have been all over the internet and the brother site, clean the drum clean the drum clean the drum where in the world is the drum, do I have to completely disassymble the printer to get to it. Help
    Thanks
  • bjmorgan98 Feb 06, 2009
    Brother hl 1440 printer prints dirty white pages.
  • tech50 Feb 17, 2009
    I followed packice's directions to clean the drum, but I cannot find the 4 latches. I removed the 3 screws but can't get anything else apart. Where are the latches?
  • Anonymous Mar 30, 2009
    Dirty Printouts
  • Cary Micheau
    Cary Micheau May 11, 2010
    have you checked the corona wire oppisite the drum? take out the drum and toner and airdustthe inside?
A white indicates that no information is being written on the drum. Another white page fault can be when the corona wire becomes broken, contamiinated, or corroded. That makes the attracted charge between the drum and paper is severely reduced.You might have to replace the module containingn the corona wires. Hope this helps a little.
Posted on Aug 10, 2010
Where the heck is the drum?
Posted on Jun 16, 2008
TRY CLEANING THE DRUM...
Posted on May 12, 2008
Prints one page and jams, displays paper jam
so it does print and exit one page before it jams? if so you have something wrong with the exit sensor. if it does not feed it all the way thru it might not be feeding paper in to the machine fast enough. the feed tires might be dirty.
Sep 23, 2014 | Samsung Ml3312nd Black White Laser Printer
Color Laser Printer Pink Tint
have you tried cleaning the charging wire and the transfer belt
Feb 17, 2014 | Ricoh Aficio SP C420DN Laser Printer
FIRST printed page is quite wrinkled, the rest are fine
Hello sir;Try to print one page, when the paper process half way then stop the machine, remove the cartridge, check the paper is wrinkling, if yes ,that's meanspaper feed roller dirty or registration roller slipply, ortherwise, check the fusing unit, need to replace presure roller. The 2nd issue, you need to replace paper stop roller or rubber pad.
May 12, 2009 | Brother HL 5250DN Laser Printer
Paper comes out looking a shade darker, almost dirty.
9 out of 10 times this is caused by dirty contacts. It can also be caused by some electrical charge getting to the paper as it goes through the printer or a faulty (weak) power supply board. Your first check should be to remove all of the consumables and clean all metal contacts with an alcohol wipe or similar. Hope this helps.
Please take a moment to rate this solution, thanks.
Mar 26, 2009 | HP Color LaserJet 2600n Printer
HP laser jet 1018 printing problem
Service is required (or a new laser you can now by at very low price)
Jan 30, 2009 | Office Equipment & Supplies
A series (10) vertical lines on print outs
See Charge roller my be dirty or Catriges PCU Units
Jan 22, 2009 | Ricoh CL3000E Laser Printer
Gray background where printo on glossy paper 130g/m2
hello
this sounds like a bad black ink cart, or the fuser rolls built into the printer are dirty.
you can swap out a black cart to test that theory, you can also just print a single blank page (no text or graphics) onto a piece of glossy paper and see if there is anything there after its gone thru the printer.
if the piece of paper has stuff on it it had to come from the rollers inside the printer.
service required,unless your comfortable changing out parts in your printer.
norm
Nov 06, 2008 | HP Color LaserJet 2600n Printer
Brother HL 1440 Laser Printer Logo
1,886 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
