Question about Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator
Motorola T5210 does not receive
I have a pair of Motorola T5210 Walkabout radios. One no longer receives; it shows a quick flashing indicator light which seems to imply a busy channel. There is also a very faint squelch type tone - I have to hold it to my ear to hear this, and it is independent of the volume control. Is this repairable at a reasonable cost?
    New Friend:
  • 109 Answers
Are you sure that the radios share the same sub audible tone? Look at your owner manual for the section dealling with (and different people call it different things) ie: CTCSS, DCS, Private tone, code...etc... make sure that the tones are the same on both radios... this is usually the smaller number on the display.
Posted on Aug 19, 2008
Flashing red light on radio where it thinks its recieving. Transmits fine but does not recieve.
Three things come to mind:
1) The radio is receiving, hence the light, but you may have a different PL code than the other radio and it is muting the transmission. Check your programming to be certain both radios are programmed alike. The red light indicates activity on your frequency.
2) Your radio may have a problem with the receive side of the radio or a bad speaker.
3) The transmitting radio may have a problem with transmit. This can be a sign of a bad battery. Swap batteries and see if the problem moves to the other radio. If so, replace the battery. (It takes more energy to transmit than to receive, so loss of transmit is common with a bad battery.)
Best regards.
Apr 15, 2013 | Motorola CP200 Two Way Radio
Just received a brand new, in original packaging, ...
Your headset should enter the pairing mode just by opening its boom. If it has never been paired before, it will be in pairing mode right away. Otherwise, make sure that the bluetooth radio of all devices preivously paired with it, are turned off (or, at least, out of reach). As soon as its boom is opened, and it can't find any paired device active, it will enter the pairing mode. Once your headset is in pairing mode, make the bluetooth application of your phone search for new devices. After a while the H700 should appear on the phone screen. Select it and make the application connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). The pairing process should be done only one. All subsequent connections between any two previously paired devices should be done automatically, provided that their bluetooth radios are on and with each other's reach.
Hope you are able to sort your problems out.
Regards, Carlos
May 19, 2010 | Motorola Mobility H700 Wireless Headset
What does 2 flashing blue light mean on the S9.
Blue (three flashes) powering on/enabling indicator light
Blue (steady) pairing mode
Blue with 10 quick purple flashes
pairing successful
Blue (long flash)
standby (connected but not
on a call or streaming music)
Blue (quick flash)
incoming call
Blue (long pulse)
on a call
these are all the normal blue flashes that the s9 makes
Dec 10, 2009 | Motorola Mobility S9 Headphones
Instruction manual
Here is a link to the 5200 series user manual: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5XxX_User_Manual_E.pdf
Check your Frequency, interfernence Code eliminator and Qt filter (if any). These all should match each other on all your radios.
Another issue which will cause a radio to receive but not transmit is a low or bad battery. It takes more energy to transmit, than to receive.
Best regards.
Nov 28, 2009 | Motorola Talkabout T5210 2-Way Radio
Motorola S805 headset worked fine with T60 laptop
Solution I found with the same devices is to properly par the devices.
Refer http://direct.motorola.com/ens/s805/QuickstartGuide.pdf
It basically states :
1.Ensure the headphones are turned off (L indicator light not blinking).
2.Press and hold L button. After about 6 seconds, the L indicator light becomes steadily lit.
3.Release the L button. The L indicator light remains steadily lit.
If the L indicator light is flashing or not steadily lit, repeat steps 1 through 3
Now on the T60:
Search for Bluetooth Devices as you would normally.
The T60 lists Bluetooth devices it finds.
Select Motorola S805.
Select OK or Yes to pair your headphones
with your phone.
Enter the passkey: 0000
Select OK.
When your headphones successfully pair
with your phone, the L indicator light
changes from steadily lit to rapidly flashing.
That's it next time you start a audio program on T60 output will be sent to Motorola Headphones
Nov 13, 2009 | Motorola Mobility S805 Wireless Headset
Motorola Tlkr T5 two-way radio can send but not receive
unit a is it in tone mod or diff. tone then b
Jun 07, 2009 | Radio Communications
Won't receive or transmit
Here is a link to the user manual: http://www.motorola.com/mdirect/manuals/T56XX_57XX_User%20_Manual_E.pdf
May 31, 2008 | Motorola T5710 (22 Channels) 2-Way Radio
Were can I buy the walkie talkie Motorola Talkabout T5210 2-Way Radio? thanks...
go to wal mart buy 2 set new cost 30 to 40 pair near to you att franco
May 12, 2007 | Motorola Talkabout T5210 2-Way Radio
Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator Logo
150 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
