Is it possible to hook our dvd/surround sound component to the tv so that when you turn the volume of the tv up/down it works the panasonic
  • 82 Answers
The sound level from the TV Line Out is fixed, so you must control the volume from the surround sound component unit.
Posted on Apr 13, 2008
We have a new TV, old surround sound, old dvd player & want to get Blu-ray player with component video output to work with our surround sound. Is this possible & Which Blu-ray player?
component video output is not going to help you hook it up to a surround system. component video is just that - video. No audio signal is carried on it. You would be better served hooking your blu-ray player to the tv via hdmi cable and then running an optical cable from either your blu-ray player or your tv to the surround system (assuming your surround system has an optical input).
Dec 24, 2016 | Televison & Video
I just bought a Coby home theater system 5.1 surround sound dvd/cd/ player model#765. I've got it all hooked up but I have one problem, when I want to listen to my tv stations through the home theater...
Hi - Your Home Theater System and your TV should have separate volume controls. You should be able to control each individually. Start by checking the volume level on your TV with your HTS shut-off. Turn the volume on your TV all the way down to 0.
Next, turn your HTS on and check the volume level there. Is it still loud? If so, try turning the volume down on your HTS. That should do the trick. If its not loud then you know you can control the volume on either the HTS or the TV. If this answer does not help, then please write us back with a little more detail. Thanks.
Feb 28, 2011 | Audio Players & Recorders
I hooked up a new lg hd tv via hdmi through my digital cable box. I am not receiving true surround sound, only dolby II. I have my box digitally hooked up to the receiver and the HDTV digitally hooked up...
It's possible that the TV broadcast isn't in true surround, and is only dolby encoded.
You can try going back to the component hookups, but I am not sure that will solve your issue.
Feb 27, 2011 | Panasonic SA-HE100 Receiver
Blu ray connect to my sc-pt660
as far as hooking up your blu ray player to the sc-pt660, the only real way to utilize the surround sound (with true surround sound) is through the optical audio out. You need to connect your blu ray player through hdmi to your tv and then connect your blu ray player to your surround sound using the optical audio out/in. I, personally have the sc-pt660 hooked up through component cables so I don't waste an HDMI input on my TV. Except for cd's, there is no reason for you to use the actual dvd player part of the surround sound considering you have a blu ray player. In conclusion, hooking your blu ray player and the sc-pt660 up to get better video simply isnt possible (your blu ray player alone gives the best possible resolution, 1080p). As far as audio goes, run an optical audio cable from your blu ray player to your sc-pt660 to get true surround sound.
Mar 23, 2009 | Panasonic SC-PT660 Theater System
Volume not working
Make sure you have patch cables hooked up from the audio out of the dvd player to audio IN of the Television, using the same named input (Video 1, 2, Fnt, Bck, Aux) that you used for the video in.
Mar 05, 2009 | Samsung DVD-VR357
Low sound when turned to AUX for surround sound
remember to turn the volume up on the cable box and down on the surround sound so you will get max audio input to the surround system and then adjust using the surround sound remote! good luck
Jan 11, 2009 | Panasonic SC-HT680 System
Hooking up sony dav-hdx 475 with digital cable box and hdtv
Plug the digital cable box audio strait into the dvd player. Plug video from the digital box into your tv.
Thats what i did and it works perfectly.
Jan 04, 2009 | Sony DAV-HDX500 System
Hdmi not working
You need to set up the out put of your DVD player. First hook up a non hdmi output to the tv, either component or coax. You don't need to hook up the audio. You should get a picture from this connection. Then you can go into the menu and set your hdmi output to match your tv, probably 1080i. You may have to turn your volume up higher when using the hdmi cable than not. I hooked my audio up directly to a surround sound and don't use the tv's speakers.
Dec 01, 2007 | RCA DRC-285 DVD Player
Hooking up video
I am assuming that you are using a surround sound system?If so on the back of the satellite receiver you will have RCA cables labled yellow ,red,white uuse an rca cable to run from the output on the back of the sat box to an rca input on the surround sound unit.the inputs should be labled on the back of the surround sound unit.once you have the sat box plugged in look for the output on the surround sound (rca cables) run one set of rca cables to the rca cable input of the Tv.on the original tv remote select the tv input that is the cable from the surround sound is plugged in to . make sure the surround sound unit input is selected to the input that the sat box is plugged into.this will give you surround sound from your satellite receiver,repeat with your DVD player plugging the DVD rca cable output to another empty input on the surround sound.to switch between the sat box (satellite TV) to DvD select another input on the surround sound unit.Try to correspond the units you are plugging into the surround sound to the correct name of the component on the back of the surround sound unit to avoid confussion.any questions,Im here to help.If this works rate me FIXYA! if it helps.GOOD LUCK!
Nov 18, 2007 | Panasonic SC-HT40 System
FLM 3232 television low volume
I hooked my tv up and there is no sound coming from the tv. I do not have surround sound just the tv. How do I make it work I need volume please
Oct 15, 2007 | Polaroid FLM-3232 Television
Televison & Video Logo
103 people viewed this question
Top Televison & Video Experts
Electro Med Services...
