Question about Nikon Coolpix S220 - Aqua Green 2.5" LCD Digital Camera
My camera keeps having lense errors. How do i fix this?
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Jun 18, 2010
SOURCE:
Lense error, restart camera
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Dec 03, 2011 | Canon PowerShot SD1100 IS Digital Camera
Error code S0042, DIMAGE G600
The S0042 error code relates to a problem with the zooming mechanism (lens would not retract or extended)
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. Let me know if it worked!
Feb 14, 2008 | Konica Minolta DiMAGE G600 Digital Camera
FEE keeps flashing with aperture ring nikor lenses
Your aperture lenses should be set to the biggest f-stop (smallest aperture)
Jun 07, 2010 | Nikon D70s Digital Camera
Canon A540 powershot freezes with Zoom lense still out.
Probably the most common failure for all digital cameras, a lens error. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 08, 2009 | Canon PowerShot A540 Digital Camera
Lense error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 06, 2009 | Nikon Coolpix S1 Digital Camera
Dsc w7
While turning in off softely press the lense in and out a couple of times. The lense would retract. If not fully, but most of the way, push the lense a little harder in until completely retract. If you turn it on, I should work fine. The reason the lense does not retract is most likely some dust in there somewhere. If it did not help, you would have to open the lense and clean it and close the lense.
I hope it helps,
Jul 13, 2008 | Sony Cyber-Shot DSC-W7 Digital Camera
Lense error
send it in for repair. their is no easy fix for this sorry. www.digitalcamrepair.com can help.
Jul 07, 2008 | Casio Exilim EX-Z750 Digital Camera
Lense error
Jun 21, 2008 | Nikon Coolpix S3 Digital Camera
Lens Error, Restart
Hi
What you are seeing is a generic stuck lens error message, turning off the camera and turning it on again will not fix the lens unfortunately.
Your lens needs to be cleaned or repaired, and if it cant be repaired it needs to be replaced. There are online places that will do it for a decent price and there are others that overcharge by way too much.
Fixya rules prevent me from giving you a link to anything off Fixya that would help you fix your camera.
Good luck from....
Darntoothysam com
May 01, 2008 | Canon PowerShot SD1000 Digital Camera
Nikon Coolpix S220 - Aqua Green  2.5" LCD Digital Camera Logo
297 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
