Question about Philips Magnavox 27MS343S 27" TV
Philips TV - 3years Old will not turn on
My TV was working fine up till yesterday. Not it will not turn on. The Cabe Box is on - and we have reset the cable box. We have unplugged and re-plugged the T.V. but we have not had any luck.
Need to know if the TV is dead, and we need a new one, or if this is something that can be fixed, or if we are overlooking something obvious.
  • 1 more comment
  • ajrich77 Apr 14, 2008
    the same thing happened to me today with a similar model Philips TV. Sucks.
  • Lindsey00 Jun 16, 2008
    I have the same problem is there anything that can be done to see if it is workable?
  • carrollba Jan 14, 2009
    I have a Philips TV, Mod# PA 7027 C101. This was given to me used and it worked great for about 1 week. Now I push the on/off switch and nothing happens.
  • 2,322 Answers
Check the info from this link to have an idea what could be wrong with your TV. This might not be a DIY unless you have some basic hand soldering skills, if not you can google how to solder/desolder. You tube has very good videos.
Good Luck.
Posted on Apr 15, 2008
Sylvania LC427SSX worked fine until comcast upgraded the cable box cable modem. TV works with DVD player but not with the cabe box. Could this be a firmware issue that requires me to upgrade the software?
In my area, Comcast has blocked all free watchable basic channels. You now need a very small but special box to receive those. If it's a conventional cable box, you might have to call them to send a signal to reset it.
Feb 14, 2014 | Sylvania LC420SS8 LCD TV
HAD A POWER BLACKOUT TODAY NOW TV DOES NOT TURN ON, HAS NO POWER
If you didn't have it plugged into a power surge strip, you may have blown the tv. Write it off on your taxes next year and buy a new one. If you do have it plugged into a power strip check to see if the lite is on/then if not push the button to reset it. That should do it. Also, same with your satelite/cable box.
Mar 19, 2013 | LG 42LC2D 42 in. LCD HDTV
Magnavox MODEL # HD1905 C121 CHASSIS # 19E604-00AA SERIAL # 43468127 My Magnavox is stuck in a demo mode. I cannot turn the power on or off, and NONE of the buttons work, nor does the...
on the set press and hold the up and down volume buttons together till the tv turns off then press power to turn back on and everything should be fine
Jun 10, 2009 | Philips Magnavox 20MS3442 20" TV
Philips Home Theatre System - no sound or power light on sub woof
reset the device to factory settings, it is written in your manual how to do this. If that doesnot work, unplug the powersocket for about 30minutes, it will cause an internal reset which might solve it.
Edgar
Jan 23, 2009 | Philips HTS3450 System
Philips TV HDMI CEC EasyLink tries to control Cable set top box
I finally found a fix to this! YAY. I thought I might have to return the TV. I have the Phillips 42PFL5603D, but should work for other models.
On the TV press menu picture settings---picture---dynamic contrast (turn off) AND active control, turn off
If you have Comcast Moto box: on the Cable box go menu--->setup--->cablebox set up---RF BYbass set to ON
If you have a non-Comcast Moto Box, I'm sure there is an RF bypass setting in the menu. You'll just have to look for it. Another fix was close saying to only turn of the active control, but it took all 3 of these for it to work consistently. The latter let it work for all of 30 seconds.
Dec 29, 2008 | Philips 42PFL7403D/27 42 in. LCD TV
We can't get the dvr/cable box to work with the tv
Assuming you have connected the DVR/Cable box with a standard co-axial antenna cable, switch on the box and go to the tuning menu on the TV.
Tuning details are in the TV manual. If you don't have the manual, download here:
https://www.p4c.philips.com/files/1/13mt143s/13mt143s_dfu_aen.pdf
When tuning is completed go through the channels to find the cable box. (Note: TV will not tune to the box if it is not switched on when tuning)
If there is still no connection, the DVR/Cable box may need connecting with a composite video cable (red / white / yellow RCA connectors), rather than just a standard co-ax cable.
The connection is at the front of the TV. There is no red connector on this TV so you will have to use an adaptor to connect both left and right (red & white) audio into the white socket. Select AV on the remote control.
Mar 11, 2008 | Philips Magnavox 13MT143S 13" TV
RCA 32V420T 32" TV
reset by unplugging AC cord for few minutes, a few hours,or overnight,if needed.Let me know if that does not work.T.
Oct 09, 2007 | RCA 32V420T 32" TV
Tv wont come on
i think it's the built-in power surge/failure sensor.  Plug the TV into the wall and press RESET on the remote twice.
Jul 07, 2007 | Sanyo DS24425 24" TV
Philips Magnavox 27MS343S 27" TV Logo
81 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
