I am having a problem with our whirlpool cabrio elec dryer, showing the F1 error. usally after 38-45 min of use and it is intermittent.
we had a tech already check it out and could find no problems. we cleaned out all vents, and still recieve this error. going crazy not knowing what to do. we have extended warrenty and only had it for about 2 months.
please help!!
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 - CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A - C above, and verified that there are no issues
with the air pressure system.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
we get f1 errors on every load. It takes multiple resets to get it to finally work and when it does it will f1 again toward the end of the cycle. The word is that they are all lemons and techs cant fix them. We should all file lawsuit.
