Question about Maytag Neptune MAH5500B Front Load Washer
Washer mah5500b Problem: Water fills and it doesn't do anything but count down the time. No movement inside at all. The letters Lr appear in the panel and it doesn't complete the cycle. Clothes are soaking wet, no spin outs, or any agitation.
  • 3 more comments
  • Anonymous Apr 21, 2008
    exactly the same problem -
  • john Dewitt Apr 22, 2008
    Same problem!! Had repairman out couldn't fix still does it HELP!!!!!!!!!!!!!!!!!!!
    Same Problem. Had repairman out could not fix. Help!!!!!!!!!!!!!!!!!!!!!!
  • Nieceyr7 May 25, 2008
    stop and try to restart washer. unpluged washer from the wall. I have try using different cycles.
  • ALBERT GARCIA
    ALBERT GARCIA May 11, 2010
    DID the sensor switches check ? latch door switch ??
  • 868 Answers
Replace the door Wax motor & main Control Board.
Posted on May 24, 2008
I have a Maytag model MAH5500B that starts to fill , stops and LR appears in indicator lights. Any suggestions?
remove the belt from the motor pulley and make sure motor spins freely,check the 3 windings with an ohmmeter for appx 8-11 ohms each,then check all connections everywhere by removing and reinserting them,then try to run the diagnostics from the tech sheet inside the washer,if all this fails then replace the M.C.U. motor control unit
May 29, 2011 | Maytag Neptune MAH5500B Front Load Washer
I have a maytag neptune washer model MAH5500B and the error code is "Lr"; what does this mean?
your machine has a fill problem either your screen is pluged on the water hose either hot or cold or your water is turned off.
Sep 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
Error code Lr
locked rotor you need a new motor control
Oct 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Fills with water then code LR comes up and it does nothing
Hello tombs72,
Unffortunately the LR code means locked rotor. Normally this requires replacing the motor and motor control board (sold together as one unit). I hope this answers your question.
Thanks,
edgin96
May 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Fills with water but wont wash or spin
The code LR stands for locked rotor you will need a new motor and motor control kit pretty expensive and only covered under you warrenty for a year!
Aug 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer fills with water and thats it
Possible a bad motor control board. Depending on the age of the washer, you may need to replace the motor control board and the motor as a kit. Also be sure to test that the motor control board is getting power, I've seen cases of the motor/ motor control failing and taking out the main control also. The tech sheet is in the console and should walk you through the steps.
Jul 18, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune fronmt load washer Model MAH5500B
Lr means locked rotor basically you have serious problems i would call a service tech for this.
Sep 29, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Wont work, flashes LR
rapoyner The "LR" error code means "locked rotor". It appears on the display after the machine has repeatedly tried to turn the motor. The cause of the problem could be the motor itself, the motor control board, the main control board or the wiring. If your washer is less then five years old most likely the parts are still under Maytag warranty. It has very sophisticated design and I wood recommend to call the Maytag authorized repair man even if the warranty is already expired. Gendos
Jul 06, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Nf pops up on the screen & the washer stops
The "nf" code is a "no-fill" fault. This indicates that your washing is not getting water supplied to it, or the pressure isn't substantial enough to complete a fill. You need to, first, make sure the water supply is turned on. Second, if the water IS turned on, and you're still not getting anything to your washer, you may have a fill valve problem. The fill valve is what both your hoses connect to on the back of the machine. It can become clogged with sediment over time (especially, if you have hard water or well water). Turn the water supply off and remove both hoses from the back of the washer. Check both these hose connections for clogs in the filter screens. If they are clear, then more than likely the fill valve has gone bad. I hope this helps you.
May 13, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
129 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
