Question about Chamberlain 1/2-HP Whisper Drive Belt Drive Garage Access System
The opener seems to want to continue closing the door once it hits the ground. Seems like the closing mechanism needs to be adjusted back closer the the garage door closer unit. This did not just happened. It has worked fine for an extended period of time and seems out of alignment from its use over time. (The product is actually a 3/4 HPS Whisper Drive Plus)
    Problem Solver:
  • 15 Answers
Try to re-program travel and force limits. Make sure that travel limit (down) does not go too far (thus excessive force). Apparently this system has a force sensor that senses if there is something in the way of the door. This is different from the safety sensor "eyes". The problem in your setup is that you have programmed the door to travel down too much and he system looses its ability to use force sensor. Adjust travel limit (down) to a little less travel and you will be fine.
Posted on Nov 01, 2010
We opened the door, now door won't close. The closer rod is locked open
Turn the screw in the end of the shaft (on the door end) counterclockwise to release all the pressure.Once it closes or slams shut, use that screw to adjust the closing speed. Other problem could be the stay open lock (the metal piece that slides along the shaft) could be all the way out keeping the door from closing. If it is just push on the door a bit then slide the lock plate all the way back to the end of the shaft, and the door will close.
Dec 21, 2013 | Wright Products Tap-N-Go White Screen and...
Adjust briton door closer
WATCH VIDEO AT <http://www.fixya.com/answer/answerpagelistview.aspx?ctg=231>
Feb 10, 2018 | Cars & Trucks
The garage door will open and then close then open and then the light starts to flash it's a Merlin 230t
This just happened to me. The issue was that the chain that the motor moves back and forth to open/close the door needed to be tightened as the tension had become slack, so the door was hitting the ground hard when it closed and the system automatically raised the door. I closed the door by adjusting the downward travel and then tightened the chain tension by twisting the bit at the of the chain (you'll see it and can use your fingers to do this), once done, then it was a matter of adjusting the upward and downward travel knobs and testing the door to make sure the door was back to normal.
Jul 27, 2012 | Home Security
The van was hit on the back passenger side resulting in a dent . The open door light along with the interior lights flashed when I hit a bump. I hear something that sounds like a fan continuosly blowing....
I think this may be the "closer" motor continuously trying to gain a positive latch--and unable to do so. This could be from a damaged latch switch.
The sliding door has three motors, a slide motor, a release (or unlatch) motor, and a closer (or latching) motor. The open door light and interior lights coming on seem to indicate that the "closed and latched" switch is sometimes open-- allowing the closer motor to continue to operate.
Another possibility is that the dent has changed the geometry of the door mechanism especially the draw of the pull cable. The slide motor has a sensor that pulses when it runs. The door management controller counts the number of pulses of the slide motor sensor to determine when the door is fully closed and then stops the slide motor. At that point, the closer motor operates to latch the door. If the cable geometry has changed, the door controller may be shutting off the slide motor prematurely and the closer motor cannot complete the latch.
Mar 28, 2011 | 2000 Honda Odyssey
On my GE Profile side by side, the refrigerator door does not close all the way.....I have to give it a small push to make sure it is closed. Also, when the door opens it continues to swing open and hits...
you can adjust the hinges on the top of unit... make sure with the door closed you have the same distance all the way down between the two doors... if that is good there is a hinge cam that is plastic and probley the culprit here.... lastly make sure the door seal has no rips,tears or coming apart... you can take a hair dryer and reshape these if this is a older unit just be careful doesnt take alot and if heated to long will melt the door seal quickly......
Dec 31, 2010 | Refrigerators
Garage Door will not stay closed.
You need to check the adjustment for the travel of the door ... All automatic closers have a built in safety mechanism that prevents children, pets and even yourself from being crushed by the door ... so if the travel is set to low the door will hit the ground too hard and safety mechanism will activate opening the door again! Look at you documentation for how to adjust this for your particular model :)
Sep 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Driver side front door makes a strong spring side when opening and closing. It seems to be in the door stop mechanism but that has been replaced and the noise continues.
Try spraying your door hinges and springs with WD-40 lubricant and then swing door back and forth several times until noise hopefully disappears. Might have to spray more than once. Best wishes!
Jul 31, 2009 | 1999 Volvo S70
My 1999 pontiac montana rear sliding power door will not work
hi there,
this can be stuck contacts on the door. better to check the sliding contact point for any dirt debris on the slide or it may need some lubricant for easily sliding.
Apr 18, 2009 | 1999 Pontiac Montana
Beeping from refrigerator about once a minute.
If this is listed under the right model, then the only thing it could be is some models have a
door alarm,that will beep if the door is not closed. You could check and clean the gasket.
Or it the switch that tells the fridg that the door is closed. Check if there is a top door adjustment to bring the door closer to the fridge where the door hinge is. This might apply or push on the switch more.
Mar 29, 2009 | Samsung RF265AA Bottom Freezer French Door...
Chamberlain 1/2-HP Whisper Drive Belt Drive Garage Access System Logo
438 people viewed this question
Top Chamberlain Building Materials Experts
Joseph Hoffmann
liveone15
Are you a Chamberlain Building Material Expert? Answer questions, earn points and help others
