Machine doesn work. H4 keeps flashing - Office Equipment & Supplies
    President:
  • 2,072 Answers
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Posted on Apr 13, 2008
What does Olivetti d-copia 120 error message H4 mean?
  1. H4 00 means Heat roller abnormally low temperature
Jan 26, 2013 | Office Equipment & Supplies
Tip
Sharp AL2020 AL2040 AL2060 AL2080 H4 H-4 code reset procedure
In most cases the flashing H4 or H then 4 code on these machines is caused by voltage fluctuations or surges. Normally there is nothing wrong with the machine and the code is easily reset. Here is the procedure:<br /> Press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys) <br />Press "C" then the "Auto" key (exposure mode) then the "C" key then the "Auto" key again.<br />So in other words C, Auto, C, Auto<br />If done correctly the display should go blank.<br />Then key in 14 as if you were going to make 14 copies.<br />Now press the "print" button<br />The machine should automatically shut down and restart with the H4 code being gone.<br /> If the H4 code comes back after reset then in this case you have a fusing unit problem and will need to have the unit serviced. <br /> Works on Sharp AL series 2020 2040 2060 and 2080<br /> Good Luck and Thank You for using Fixya.<br />
on Dec 22, 2010 | Office Equipment & Supplies
"Clean" light keeps flashing. Machine doesn't
Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jul 15, 2011 | Kenmore Dishwashers
Sharp AR-123E, H4 error code, printer not ready
it doesn`t need to change board. code 14 clears.
May 04, 2010 | Sharp AR-M205 Copier
H4 READING
H4 flashing mean fuser unite fault.Fix it # interrupt C interrupt 14 press start key machine on/ off.If it are not fix change thermostat or Heater lamp.
Dec 14, 2009 | Sharp AR-5320 Black and White Copier
Error code H4-00 and machine is "locked-up" in scan mode
H4 is a fuser error. It needs to be replaced by a tech. Sometimes they can reset this error in service program.
Apr 24, 2009 | Toshiba E-Studio 3511 Color Copier
Sharp H4 Error message
Hello sir; The code need to reset;
1, press "#", "interrupt", "c", "interrupt" keys.
2, enter 14 then press start.
3, if machine work, please don't forget to give me a good rating.
THANK YOU !!!
Feb 09, 2009 | Sharp AR-5316 Advanced Digital Imager...
Xerox XC 1020 copier code H4
With "H4" flashing press:
1.Clear button
2.Auto button then again
3.Clear button
4.Auto button
It should be done quickly. If it's done quickly enough all lights on display should go off.
5.Enter number 14 (as if you are making 14 copies).
6. Press START/COPY button.
The machine goes back to normal. If not, thermistor on the fuser (heater) should be replaced.
Sep 02, 2008 | Office Equipment & Supplies
H4 Problem
Hi there, if you want to clear this code its very simple, do the following: -on your control panel locate the clear and auto exposure buttons, next -hit in the following sequence clear, auto, clear, auto without holding them down, after that all your panel lights should go out. If they do not you have to keep trying...They will go out. -Next program the machine as if your going to make 14 copies -Once 14 is displayed, hit the green start button and your copier should be working again. Cheers! :)
Sep 11, 2006 | Xerox WorkCentre XE88 Laser Printer
125 people viewed this question
jasbo
jasbo
