Question about Toshiba Computers & Internet
Toshiba M55-S135 laptop. Video on screen is 1/3 blue at top, bottom 2/3's are white
    Master:
  • 507 Answers
Sounds like ur screen needs replacement bud its going bad due to age this is normal for any LCD display to show its age
Posted on Apr 27, 2014
  • 188 Answers
SOURCE: Toshiba Satellite M55-S135
for all problems like this start by simplifying - pull both ram chips out and try each one individually. Remove any accessories like the CD drive and hard drive and see if the machine does anything different.
If these basic steps dont help its probably an internal problem with the laptop and you would have to take it somewhere to disassembly and diagnose.
Posted on Jan 14, 2008
panthers85
  • 54 Answers
SOURCE: toshiba m55-s135 memory install
Not all laptops have spots for two sticks of ram. Double check the specs but the slots should have been in the same spot.
Posted on Jul 30, 2008
  • 357 Answers
SOURCE: toshiba satellite m55-s135 won't power on even when plugged in
When the AC adapter is plugged to the wall, if it has an LED make sure it is on, remove the battery and connect the adapter to the laptop, does it power up?
Install the battery after charging, see if your laptop powers up.
If the laptop does not power up, the motherboard needs replacing.
I hope this helps to resolve your issue.
Good Luck.
Posted on Mar 15, 2009
Dellea
  • 30 Answers
SOURCE: dell flat screen goes white and colored block appears and floats
Check that your monitor is connected properly and tightly to the computer. If it is, then the monitor may be bad. Borrow a friend's monitor and try to see if it works, if someone else's monitor works, then replace your monitor.
Posted on Mar 27, 2009
jepito
  • 216 Answers
SOURCE: White block on left side of moniter screen
the screen has failed - i once had a screen with same problems :() order a screen from here newegg.com
Posted on Sep 03, 2009
Toshiba M55-S135:How to replace the internal mini pci wireless card? Which screws to remove?
Whoa!
1) Remove ALL power. Remove the AC adapter (Charger), and Battery.
2) Put all of those screws back in. Tighten, but Do Not over-tighten.
3) http://www.irisvista.com/tech/laptops/Toshiba_Satellite_M55/laptop_motherboard_1.htm
Scroll down, click on the photo for Step 2.
Remove the screw for the Wireless Module Cover. (Wireless card)
Lift the cover up ON the screw side.
There are tabs on the other side. (Side facing you)
Close the small window. Now click on the photo in Step 3.
White cable (Wire), and Black cable. Make a small mark on the White wire, (Sharpie?), and near the terminal on the Wireless Module Card the white wire goes to.
Remove the screw/s, remove the Wireless Module Card.
Reinstall in reverse.
Regards,
joecoolvette
Aug 15, 2012 | Toshiba Satellite M55-S135 Notebook
What keys do i use to brighten or lower my screen brightenss on my toshiba satellite m55-s135?
deffinitely not a connection issue there should be some weird buttons by the f5 buttons look at instructions
May 06, 2012 | Toshiba Satellite M55-S135 Notebook
No appear in my deskop proprieti output monitor because missing the,, ialmnt5.sys driver'' Please help me !Thank you so much ! I have one lap top Toshiba Satellite M55-S135
The ialmnt5.sys file is a driver file for video cards. The best solution in this case is to reinstall the video driver.
Go to the manufacturer's support website to download the latest drivers for your device.
Here is the link for your laptop drivers : Satellite M55-S135 drivers.
Make sure to select the correct OS version to get compatible and working drivers.
Hope this helps.
May 19, 2011 | Toshiba Satellite M55-S135 Notebook
How can chang my vga card for m55-s135
Unfortunately your video card on the M55 is part of the motherboard itself...it is an integrated chip. You would have to take it to a repair shop that has the machine capable of desoldering all the connections and resoldering a new graphics chip to the board. Buying a new motherboard may end up cheaper in the long run, but I have seen repair adds on EBay from companies that specialize in these types of repairs. Give it a look and see what you think.
Jul 01, 2010 | Toshiba Satellite M55-S135 Notebook
My toshiba satellite M55-S135 is showing a blue screen with "physical memory dump complete" & to contact tech support. Basically, wanted to ask if my laptop is crashed...
Hi:
Crashed is a generic term, and the physical memory dump error is a windows based error that could be a bad memory stick, or a corruption in windows. If you have 2 sticks of memory in your laptop, a cheap and easy way to troubleshoot this would be to remove one stick, then the other,to see if one stick removed stops the crash. If it does, then you have solved the problem, and if it doesnt' then you have a corrupt software issue.
Hope you get a cheap fix!
Jan 18, 2010 | Toshiba Satellite M55-S135 Notebook
Laptop screen replacement
http://www.irisvista.com/tech/laptops/ToshibaM55/laptop_LCD_screen_removal.htm
That should help you. Good luck and have a great day.
Oct 21, 2009 | Toshiba Satellite M55-S135 Notebook
Lan driver
Go to the following site.
1. Choose Category = Portables
2. Choose Family = Satellite
3. Choose Model = M55-135
Filter on Lan and the drivers come up for XP
If this doesn't work list the detail specs from the device manager on the specific component you want and it can be found.
Jan 29, 2009 | Toshiba Satellite M55-S135 Notebook
Toshiba M55-S135
check your battery on some other's laptop, i think the battery life is over, you have to replace the battery
Oct 29, 2008 | Toshiba Satellite M55-S135 Notebook
Toshiba m55-s135 screen
Hi
Problem with you laptop inverter replace it has shown in pic...
Thanks
Jun 16, 2008 | Toshiba Satellite M55-S135 Notebook
Computers & Internet Logo
32 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
