Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
My emroidery carrage reads the wrong hoop i have done every thing the manual says to do but it still tells me the small hoop is in when
When using either hoop you should place the frame on the carriage before you send across the design as there's a sensor in the carriage. Also when you send across the design and it asks you if you want the design optimised for speed you must always say YES. If this doesn't work then i suggest sending the machine to your local agent as the sensors may be faulty.
Posted on Apr 29, 2008
When trying to embroider on my husqvarna Designer 2 machine, I keep getting the message wrong hoop. I've tried repeatedly to start again, but keep getting the message. What's wrong?
Possibly the hoop is just a tad too small for your design. The hoop needs a certain degree around the edge to move the presser foot. For instance, a hoop that is 5"x7" can only take a design that is perhaps 4.5"x6.5".
Perhaps your machine is not correctly recognizing the hoop.
Apr 18, 2017 | Sewing Machines
When I install embroidery hoop light keeps blinking n saying wrong hoop size looked it up n it's saying malfunction
Ok, there are a couple of possibilities, and I'm going to include an image. I"m not sure whether you're trying to use the small or large hoop, but the first thing you should try is turn off the machine, take the hoop off entirely, then turn on the machine without anything and let it reset to its default position, which will be the center. If it has a problem there, make sure the needle it at its highest position.
Next, put the large hoop on, bring up a design, (preferably a design that came with your machine--there are sample designs in the \Library directory where the program is--that's generally in c:\program files\futuraquartet--and is designed for the hoop you're trying to use, and transmit to machine. If it tells you the hoop is the wrong size, download a patch from www.futura-support.com. If it STILL tells you you have the wrong size, reseat your USB cable into the machine and tape it in place with masking or duct tape.
The third possibility--and the one pictured in the photo I'm going to attach--is there is a tab on your hoop which indicates the hoop size, and your TAB may be off. It needs to be dead center of the sensor, which is also pictured. A while ago a BUNCH of hoops were manufactured with the tabs slightly off, and if it's off, your machine can't read the size. What generally happens there, though, is it will indicate that there is NO hoop attached, rather than the wrong size.
You can see the sensors--they're inside the arm where you put your hoop, and they're not covered up. Below it are the large hoop (top), and small hoop (bottom). The hoop tabs have to match up to the sensors exactly, and you'll be able to see if it doesn't by matching up the notch in the hoop that matches the catch in the embroidery arm.
Oct 20, 2014 | Singer Futura Xl-400 All-In-One Sewing And...
Embroidery
When you are editing the design make sure you are actually doing it in the hoop size that you want. It may be that the design has been done in a larger hoop although it does not really require it. I can change the hoop size on my machine. Good Luck!
Oct 15, 2017 | Bernina Sewing Machines
Bernina artista hoop not recognized
Calibrate the embroidery hoop
Note
The embroidery hoop can only be calibrated with the oval hoop.. You'll find the instructions for each machine in the relevant user manual.
Aug 15, 2012 | Bernina Artista 180
My futura ce200 is driving me insane because i have the small hoop selected on the computer but the machine thinks that the large hoop is selected. How do i fix it??
Before attaching small hoop, turn on power switch to
move the carriage to embroidering standby position, and
turn off power switch.
check troubleshooting in manual
user manual link
http://www.futura-support.com/files/CE200-Eng_Fre_Spa040607.pdf
hope this helps and you get it working soon =)
Feb 05, 2010 | Singer CE-200 Quantum Futura Computerized...
My Singer Futura keeps telling me that I have installed the small hoop and need to change it to the large hoop...but I have actually installed the large hoop. It is giving me an incorrect error message. I...
Make sure you have the latest software version. Current version you may check in About dialog under Help submenu and in the same submenu you wil find a function Live Update.
Also make sure you switch on the sewing machine either with the large hoop connected or without hoop. If sewing machine was switched on with the small hoop attached, it will provide this error message about wrong hoop.
Jan 30, 2010 | Singer CE-200 Quantum Futura Computerized...
Futura CE-200 Stops in middle of design and says wrong hoop size
Dear cjnations
Firstly we must all remember that the CE200 is a very particular machine and requires that you follow certain procedures in order for it to run smoothly. When using the small hoop, firstly you must make sure that the small hoop is selected on the screen by going to Tools, Select Hoop & clicking on small frame. Once this has been done and the design selected, you must then attach the small hoop before sending the design to the machine. If you attach the hoop after sending the design, the machine will give you the error message.
Good Luck!
Nov 16, 2008 | Singer CE-200 Quantum Futura Computerized...
Tension problem?
HI Judy
These may be obvious thoughts that you have already looked into but when I have these problems they are usually resolved by one of the following@
1. Clean out the area around the bobin
2. Put a good stabalixer under the fabric in the hoop.
3. Check I am using the correct emroidery needle
4. Use correct thread for fabric.
Sorry if you have done all of these
Stephanie
Aug 02, 2008 | Husqvarna Rose
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
71 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
