Question about Miele S558 Red Velvet Bagged Canister Vacuum
NO Power I just finished vaccuming, then I turned it off and moved it, and all of the sudden it will not go on at all. Is there a fuse in the vaccum that may have blown?
    President:
  • 1,673 Answers
There is a fuse, you have to take the top off to get to it.
#225 is the fuse. You could have a problem with the reel cord asm also.
Posted on Apr 15, 2008
Suddenly the vaccum cleaner stopped working
If you are in the UK check the fuse in the plug.
Oct 17, 2014 | Vacuums
My rain vaccum
Need more information...Are you having problem with Main unit or the power nozzle? You can also call and speak to a Rainbow Specialist.
RainVac
www.rainvac.com
800-523-0510
Oct 07, 2012 | Rainbow E series Canister Wet/Dry Vacuum
Vacuum cleaner does not work
most upright vaccums have a reset button at lower rear area of the vaccum. operates similar to gfi plug reset, push button back in usually with small screwdriver. is your debris bag to full? power brush jammed with debris? hose plugged? this will cause motor to over heat and in turn kick out reset button. always unplug power cord before putting fingers in areas where moving parts are!!
Jan 01, 2012 | Bissell Vacuums
Turn on the power and nothing happened. I checked the power plug. It was ok. what caused the Vaccum didn't work? Thanks, Peter
Same, I have the same issue with this model. Brush motor is working but not the vaccum motor. Any ideas?
Jul 26, 2010 | Bissell Lift-Off(R) Revolution(R) Turbo...
Was vaccuming and vaccum quit. Tried unplugging and turning back on. Getting absolutely no power. unscrewed screw under handle and tried to make sure connection was being made. Don't really know what to...
ok..If you have a multimeter you can check plug fuse then switch and motor, if you put leads across the plug you will get some reading if its working.could be thermal cut out on the motor.
Apr 18, 2010 | Kenmore Magic Blue 24195 Bagged Canister...
Vaccum problem
No sound at all? or the motor runs but no vaccuum?
did it stop while using it? might have overheated due to dirty filters... strange that the light comes on but no motor at all... that would suggest to me that the motor is shot...
Here is a link the the manual.. there is no reference to any user accessable fuse or breaker...
Peace,
Mar 07, 2010 | Bissell 6594 PowerForce Bagless Upright...
Bissell vaccum cleaner just turned off why
Ive had this problem before. I have never figured out what caused it. I let it be for a few minutes and it started working again.. weird.. I'd just let it sit for a few then try it again.
Mar 02, 2010 | Bissell 6594 PowerForce Bagless Upright...
Part terminology and replacement help
call tti floorcare 1800-321-1134. have your model number and the plant number ready you will need it
Apr 18, 2009 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Steam Vaccum won't switch on
it sounds like your thermal fuse went out and u have to open it up ant test the fuse with a multimeter...I had the same problem and had to replace the thermal fuse...I ordered a fuse(sf188e) from ebay...cut the old one out and soldered in the new one...hope this helps.
Dec 30, 2008 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Bissell vaccum problem
Could be plugged, check the hose and at the bottom by the brush roll, the inlet maybe clogged. Also check the filter under neath the dirt tank. There are filters above the dirt container, clean those out. If after that it is still loud, then maybe the motor fan or bearins are bad and will have to be replaced, part #2031214 sells for around $55.
Jan 16, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Miele S558 Red Velvet Bagged Canister Vacuum Logo
544 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
