Question about Sylvania 6319CE 19 in. TV/VCR Combo
The tv turns on, but the tape is stuck, will not eject
So the tv turns itself back off within 54 seconds. please help!
  • Anonymous Jun 13, 2008
    Same problem - tape stuck inside causes the tv to turn itself off. How do I go about taking it apart?
The rubber band inside for the ejecting mechanism broke. you need to take it apart and reattch with a rubber band.
Posted on Jun 05, 2008
go to and order the replacement belt kit. then google your model number on alignment pdf. Your mechanism is out of alignment due to bad belts
Dec 03, 2017 | Televison & Video
VCR tape was hung in Sylvania SRDV495. Got the
You need the aligniament the eject gears to tape gears.Please remove the cover platen and the rear cover(bottom) and align the gears manually.Obturated the sensors hole and insert the cassette.Verify the eject and the tape belts.If you have knowlwdge VCRs the problems solved in 1 hour.
Aug 21, 2009 | Sylvania Televison & Video
Symphonic tv vcr combo will not eject tape
You need a new VCR belt it located on right side of the vcr tray take your finger and start rotate the belt clockwise, it should release the tape. or the motor is going bad.
Apr 25, 2009 | Symphonic SC319C 19 in. TV/VCR Combo
Tape won't eject,tv keeps shutting off
sounds like your tape is jammed try turning the tv on and ejecting the tape while using something to try to lift the tape up and out good luck.....
Dec 19, 2008 | Emerson EWC1301 Combo
VCR repeatedly tries to play and eject when tape deck is empty
the tape carriage is probably stuck, or something stuck inside blocking the tape sensor.
feed a tape in and see if it does it "with" the tape too
hope this helps
Jan 08, 2008 | Sylvania 6313CB 13 in. TV/VCR Combo
My guess is that the prisim broken or led (light emitting diode) below it has failed so the vcr is stuck in an endless load...
It will have to be taken apart and the tape in it manually unloaded by turning the load motor counter clockwise. Then visually inspect the prisim and test the diode.
If any of this sounds too foreign take it to a good shop and they'll have it back and running in no time..
Hope this helps!
Nov 14, 2007 | Philips CCC132AT 13 in. TV/VCR Combo
Tape stuck and tv turns off
With the set unplugged remove the back and extract the main board. You'll find a metal cover over the tape housing area that is easily removed by removing some screws holding it to the board area and manipulating some wired over it... You should then be able to see the tape and what's hanging it up. If you need to unwrap tape from the pinch roller or around the guides do so carefully. When it all looks free you can either manually crank the load motor assembly to eject the tape or put it back together enough to plug it in and press eject. If you do the later be VERY careful... Good Luck! Bill
Jun 01, 2007 | Sylvania 6313CB 13 in. TV/VCR Combo
TV keeps turning off after 30 seconds
This is usually a sign that a function has not completed or a switch has stuck in an incorrect position. eject can only happen if the sensor (either optical or mechanical senses that a tape is present. The swich might be stuck or the sensor might be blocked or bad. You can open up the unit and try to determine if the sensors are not being blocked by any of the mechanical parts of the unit. You will need the service docs to show you where the components are located. I hope this helps. Shuttle83
Feb 16, 2007 | Symphonic SC3813 13 in. TV/VCR Combo
My Tv is turning off by itself
if all you want to do is disable the vcr portion turn the set on , install a blank vhs tape it has to be blank or the vcr will try to read it .and the tv and dvd should work fine. this is a timing problem in the vcr deck its not hard to fix but it is a pain.
Nov 05, 2006 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Sylvania 6319CE 19 in. TV/VCR Combo Logo
115 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
