I have windows xp and i attached usb2.0 with it but my pc not detecting my usb 2.0 but when i insert the usb in my laptop the green light is on of usb.what shoud i do
    Sergeant:
    Novelist:
  • 166 Answers
Hello there.
For Windows XP, support for USB2.0 is provided in the Windows XP Service Pack 2.
You most likely do not have this installed, to check do the following: right click "My computer" on the desktop, left click "Properties", Notice underneath where it says "System:"
It should say Microsoft Windows XP, Service Pack 2.
If yours does not, then you need to update to Service Pack 2 as soon as possible, as this includes many security fixes to keep you safe online.
Please click here to upgrade to service pack 2.
Posted on Apr 13, 2008
I have windows xp sp3.my computer is not detecting i ball c12 webcam.it is properly connected to computer through USB as its nightvision lights are working... PLEASE HELP.....
Start by rebooting the PC... You may want to try different usb ports in the even that one of them is faulty. Check the Device Manager by right clicking on my computer, going to properties, and then go to the tab for devices and click device manager and see if the hardware is shown as attached. Have you tried inserting the disk that came with the webcam?
May 06, 2011 | Computers & Internet
Cannot install parallel to USB printer cable.
I can only really offer a suggestion. But try unplugging the adapter with your pc off. Turn the pc back on insert the disk. Then turn the printer on and try plugging the adapter back in. If your adapter/printer are working you should receive a request to add new hardware. From this point you should be able to have it "search for the best driver for your device." If this doesn't work you may be looking about a bad adapter and or unresponsive printer. also try using a different usb port.
Jul 18, 2010 | Computers & Internet
Windows XP Professional With Servise Pack 2 (e8503040) for PC: sir my pen drive is not showing in windows xp .\r\...
it may happen in some case when you are inserting your pendrive first time it will get installed its driver and all itself so it might happen that you have to restart. you can also update this USB driver..
May 18, 2010 | Microsoft Windows XP Professional With...
Canon Canoscan D1259U2F dont have any driver for Windows 7 64-bit
the only successful method I found for using CanoScan D1250U2F in 64 bit Windows 7 (I guess the same would be for 64 bit Vista) is to use Windows XP Mode in Virtual PC (attach the scanner as USB device and that's it - works perfectly)
I had a problem with Windows 7 detecting the device as CanoScan (needed for Windows XP Mode to detect is as USB device and allow attach) - the solution was to unplug the scanner, plug it in and CANCEL Windows 7 hardware detection process before it finishes - this leaves it as "CanoScan" device (auto-detect will leave it as "Unrecognized device" and with that unusable/un-attachable in Windows XP Mode)
latest versions of Windows XP Mode will make your hard drives accessible as network locations (no need for external media)
Jan 01, 2010 | Canon CanoScan D1250U2F Flatbed Scanner
No matter which computer I put my digital camera attachment to download pictures, it will not download pictures at all. It keeps telling me there is nothing attached (camera or scanner) to get pictures...
Since that you already used different computer still its not detecting the camera It means the problem is either On the USB cable itself or on the camera USB slot. Because windows XP vista or Windows 7 has a generic driver for all the camera it should detect all the camera thats been inserted on the CPU.
try to used different USB cable and make sure the USB cable is MODEL U-8 thats the right cable for your camera
Nov 07, 2009 | Kodak EASYSHARE Z1285 Digital Camera
Green light is on, but will only print test page. Cables are in place. Printer is about 4-5 yrs old.
you have a usb port computer problem,with computer and printer ON plug theUSB cable into a different usb input on your pc,your computer should detect the new device or printer attached and makes some alert noise if it does not detect the printer then fix your windows operative system
Jul 29, 2009 | HP LaserJet 1300 Printer
Bought HP Pavilion dv2910tx,not able to install Windows XP. Help
If the install cannot detect the hard disk then the hard disk is faulty and needs replacing or the disk controller is faulty.
You can check if the hard disk is faulty by :-
Go into the BIOS and check if there a hard disk diagnostic.
If not then remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port.
If this computer see it as an external hard drive and you can view the contents of the drive then it is OK and the fault is the disk controller on the laptop.
To setup XP.
You insert the Windows CD and boot up the laptop with the CD.
You have done this correctly to get the hard disk error message.
Apr 15, 2009 | HP Pavilion dv2000t Notebook
XP on HP Pavilion dv2000
yes
because it's using an AHCI  SATA driver
there 2 ways to install XP on your laptop
  1. If you own an external floppy disk. You can insert the driver before the installation begin. the setup will ask you to insert third party driver by pressing F6 at the first of installation. Press F6 then insert your SATA driver. choose it. then setup will detect your hdd. you can download the SATA driver form here:http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/HP-Pavilion-dv2054ea-SATA-Driver-550.shtml
  2. It's very hard to find an external floppy drive today, unless if you are an OEM or retailler. second way is you can insert the driver to XP installation CD, but it's very complicated. Or you can download a XP installation CD with sata driver here:http://fenopy.com/torrent/Windows_xp_sp3_5512_cdr_october_2008_with__sata_raid_/MTU2MTEzMA==/index.html
  1.
Jan 24, 2009 | HP Pavilion dv2000t Notebook
I bought a Sandisk Extreme lll SDHC card , that came with a reader ( ImageMate 8 in 1 SDDR-88) I cannot get this reader to work properly..I am using Windows XP. I apparently, do not need to update or...
It rather sounds like you're inserting the card after inserting the reader into the PC... am I wrong?
As long as the device is detected in the Device Manager (system properties), it should be fine.
Insert the card first, then insert the USB reader. From there, check that you get a drive-letter. If you do, great.. if it's brand new, it may require formatting the disk before you can open it and start putting things on it or using it in a camera.
When you say "no files are detected", i'm assuming you don't simply mean "there are no files already on the SD card"... because that's normal if it's new. =-]
Let us know!
Aug 20, 2008 | Computers & Internet
USB DVD ROM no detected
You need XP service pack 2 or later installed on your notebook. Does your notebook detect other USB drvices, if not your USB port on the PC is gone. If the USB prt is working and you have XP service pack 2 installed then you probably got a bum DVD drive so return it and get another.
Jul 14, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
