Question about Mitsubishi VS-45609 TV
Picture Zooms in and out
I've had this TV for a few years now and I love it. It still has a great picture but lately the image seems to zoom in and out. When a bright image is displayed the image gets large, and the edges fall off the screen. At its worst it can split the station logo in half. when the image is darker the size seems to return to normal. In the begining after the set warmed up it went away but now it don't. I tend to run the brightness and contrast settings lower than default so I don't think I'm pushing it too hard.
  • burningjazz Jun 27, 2008
    I have a 2001 ws55905, after powering on the set it's in the full zoom mode. As the set stays on it returns to normal.
    The original repair mention the power board - Any Ideas,
    Scholar:
  • 170 Answers
Check your b+ goin to the flyback, and see if the voltage changes durring picture changes. if this is too high or moves around alot, then you have more then normal then i would check your p/s. either or it could be a weak regulator. Also could be something else, i know that magnavox has a problem with this, and they have you replace 2 sm trasistors on bottom of board in the ABL line, i believe.
I checked the mitz web site and they have nothing listed for this problem. might also want to check caps in p/s and 100uf on signal board while your in it.
Posted on Apr 13, 2008
How do i get the picture off wide screen
some remotes have 2 zooms
one for the tv zoom.
one for the cable box zoom.
i traded in a box thinking it was bad. sillyme
Jan 04, 2015 | Televison & Video
Picture not focused at 12x zoom
It's probably something to do with a lag or jam on your shutterspeed. so when you hit the button, and move you get a little blur. If its not this you might need to have your lens cleaned inside and out due to the camera zooms and catches the blurs on the lens after zooming so far in. I would recommend taking it to your local camera shop for adjustments and cleaning.
Sep 19, 2007 | Panasonic Lumix DMC-FZ7 Digital Camera
RCA entertainment series TV does not show the entire image
Check the picture settings. It sounds that the picture settings to TV is Zoomed.
May 29, 2012 | Televison & Video
Once u zoom into the picture that is very far away how do u keep the picture zoomed in after u snap the shot ...
Once you've framed your shot (zoomed in) and taken the picture. That's it, the picture you've taken is the one in your view finder, and that's the way its kept.
However, if you want to zoom in further, you can using the software you were provided with your camera, you can, you can also zoom in using your camera menu. Once happy you can then save the edited picture. But this time its a digital zoom and it will reduce the resolution. The picture won't look quite as fine. It will be a balance between picture quality and the extent you want to zoom in.
Apr 19, 2011 | Olympus PEN EPL1 Body only Digital Camera
Picture format to large
There should be a format button on your remote to change between widescreen & fullscreen as well as the zooms. May say format or aspect. If not on remote look through your menus. Make sure which ever u select u do not choose a zoom. This will cut of top & bottom of picture
Apr 06, 2009 | Televison & Video
Sony DSC-P3 Zoom stopped working
i had that same problem. check your image size, the camera cant zoom if the image size is set to 3.1M or 2.8M(3:2)
how to change image size:
turn on camera and leave it in camera mode (picture taking mode)
press the delete/image button
change image size until camera zooms again
VGA gives the biggest zoom range
i hope this helps
it worked on my camera
Jul 27, 2008 | Sony Cyber-Shot DSC-P32 Digital Camera
Mitsubishi WT-A42 projection 42" HD1080 series
It sounds like your regulator circuit is defective. Not an expensive repair, maybe $200.or a little more.
Apr 08, 2008 | Mitsubishi WS-65909 65" Rear Projection...
Picture zooms in then out very fast then stops
try to see if it happens more in bright wight sens if so replace the regulator and check for bad solder connections
Oct 11, 2007 | Mitsubishi VS-60719 60" Rear Projection...
Nikon Coolpix 3200 won't take pictures
Wat sort of error messages are you getting when you press shutter?
Aug 14, 2007 | Nikon Coolpix 3200 Digital Camera
Mitsubishi VS-45609 TV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
