Swintek Electronic Office Typwriter Problem
Our church has the above typewriter. I don't know how old it is. But I want to use it in the church library. When I turn it on, it seems fine. But whenever and whatever button I hit, it beeps without typing. Neither the index nor the reverse index works. It will not type or do anything. I have tried to move the print wheel by hitting the margin release, but no go. I have tried everything I can think of to make it work. There doesn't seem to be any batteries to be replaced. The manual does not mention batteries or this problem.
Any help you can offer would be greatly appreciated!
Linda Warren
  • 3,594 Answers
You didn't say what the model is. First be sure the print wheel is properly installed, then turn off the T/W and see if the carrier will move back and forth easily, if not try a little light oil on the shaft that runs thru the carrier (WD40 works well).
DickyO
Posted on Apr 15, 2008
When i switch on the typwriter its making a continous beeping noise..1st time i want to use
carrier may be hung up on something dropped into the machine, try turning it off and moving the carrier to the side by hand do not force it
Aug 25, 2016 | Brother GX-6750 Electronic Typewriter
Change the correction type
go to nadist.com you will find a manual.
DickyO
Oct 07, 2013 | Nakajima Ea-740 Electronic Typwriter W/...
Can you suggest a model for ARABIC & English letter Typewriter ?
It is unlikely you will get a typewriter with 2 languages....think of the problem of labeling the keys, as well as limited memory in a typwriter to contain both languages. Most typewriters are available in North America as either ENGLISH, FRENCH, or SPANISH. These being considered the most common languages.
Feb 08, 2010 | Olympia Office Equipment & Supplies
The flywheel from my brother ml300 typwriter came off and i don't know how to put it back on
I assume by "flywheel", you are referring to the "printwheel" which is removable from the typewriter by unlatching the print hammer mechanism by pulling the black lever on the right side of the print hammer towards the front of the machine. To install the printwheel, drop the printwheel in its cartridge with the letters facing the paper, then push the print hammer assembly towards the paper to the latched position. Turn on machine, and the printwheel will spin and "home". If printwheel homing is not correct, repeat above procedure with slightly more pressure when latching the printwheel. (The printwheel must latch on to its drive spindle securely). Good Luck
Nov 25, 2009 | Brother ML-300 Typewriter
Personal Wheelwriter 2
Roxanne;
I an very knowlegeable about wheelwriters, I will be in the office today until 5:00 pm edt you can call at 216-241-0027.
DicktO
Mar 11, 2009 | Lexmark Wheelwriter 3 Typewriter
How do I enable the BOLD feature on my Swintek 4040 typewriter?
Hi:
There should be either a mode or code key that you need to hold down while you are pressing the bold key. You should the see a little arrow light up under the bold function on the display if you do it correctly.
Good Luck
Andrew
Mar 09, 2009 | Swintec 7040 Typewriter
Sears typwriter
some typewriters have a carriage lock on the carriage to lock it in the center position, or it may have typet to the right margin which causes a typebar lock to activate untill you da a carriage return to the left side of the paper.
May 21, 2008 | Office Equipment & Supplies
Removing Symbols and return to just simple typing.
the cover of the typwriter is lose need to push down to self lock. then test .
Dec 04, 2007 | Brother GX-6750 Typewriter
Will not type
If the 1, 2, and 3 line space keys are flashing in order, you need to change the two AA batteries that are located inside your typewriter.
May 23, 2007 | Lexmark Wheelwriter 1000 Typewriter
56 people viewed this question
k24674
jasbo
jasbo
