Televison & Video Logo
Posted on Apr 13, 2008
Picture and color distortion
Our tv was working fine then all of a sudden the upper half of the picture was distorted. It has double imaging with a blue line and a yellow line. The bottom half is normal. What could this be?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 22, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
149
Points
I am having the same problem hopefully some one answers us.
It's a Blue Convergence issue but how to fix it I am still waiting.
  • Anonymous Apr 23, 2008
    The problem is probable the STK Convergence AMP.
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
3 Horizontal lines distorting picture
When you say "distort the picture", are you referring to dark image? double picture
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Double Vision (Mainly around the edges of the screen)
Look for your Convergence amps and check the solder connections on them....you may only have to resolder the amps...and if they fail in a couple weeks, then replace them...
If you don't beat up the convergence amps for WEEKS operating them with the bad connections, they can survive...
PHILIPS 60PW936317 - COLORS GOT DISTORTED AS I WAS WATCHING TV
Your convergence chips and convergence resistors are going bad. When they fail the screen colors will look distorted/3d looking.  Another symptom is one or more colors can't be converged using the convergence menu. You can purchase the parts over the internet. Just make sure you get Sanyo brand convergence chips and the correct flame proof resistors. You can also check the site www.TvRepairKits.com. They are working on a complete kit for this model.
Double images on half the tv
Projection sets have two very common problems.
The first common problem is convergence
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
Distortion and double imaging
*Screen Looks 3-D
*Colors wont align
Double image
Yes,it can be fixed...most likely the problem requires the
convergence IC's to be replaced....You can DIY if you are
mechanically sharp and able to solder well....Part(s) come in a kit for your 43UWX10B....................# X 480293........T.
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
