Matsonic ms7308et motherboard
I have put my motherboard into a different tower case, but i am now having trouble finding what pin i put the "power plug" and other plud onto, can you help??
    Genius:
  • 1,027 Answers
Hope this helps
Posted on Apr 13, 2008
Vga Matsonic MS7308E
Hi, you can download the driver here:
http://www.desktop-computers.ws/view.php?modelID=MS7308ET
Unzip the file before installation.
Aug 21, 2011 | Matsonic MS7308E (MBMS7308E) Motherboard
DIY foxconn tower caseTSAA891 connection to abit NF7-S Motherboard
What are you asking for assistance with? Connecting the wires (if so which ones) or finding a manual?
What cables are you having trouble with? If it is the power supply cables you are having problems with, bear in mind that most modern motherboards/PSU's use a 20+4 pin arrangement. Some older PSU's have a different connector.
It could be that you need to update the PSU to match the requirements of the motherboard
Oct 11, 2007 | Computers & Internet
I have a ECS A740GM-M Motherboard in an Asus TX-381 case. I can't get the 2 front usb ports to work. What am I not wiring up right?
Make sure you are putting the front usb header connector on the proper USB pin connection on the motherboard. You should see nine pins in 2 rows together. Check the manual that came with the motherboard to find the correct pins location.
Apr 07, 2011 | Apex Computer Technology TX-381 Micro ATX...
Im trying to install dell i530 into Xion II case but cant figure out how the power switch led hooks up?
All of the pins locations and settings should be available on the motherboard manual. The pins should usually be located at the very bottom. ALL of the pin's settings will be labeled underneath the pins, but often hard to see, that's why I recommend reading the manual. All of the switches and LED pins will be different on different motherboards. The USB, if you have ones that are all separate connectors, goes like this: [+5V/VCC/Power] [D+] [D-] [GND]. USB and audio will always be the same.
Feb 17, 2010 | XION II Black Pearl ATX Mid-Tower Case
Looking for the manual for the matsonic ms7308et motherborad
Hai,
Try here. It shows a manual for the MS7308ET but according to Matsonic these should be pretty much the same. Difference between the 2 is the ET has 4 channel sound and the E only 2 channel.
Click here for Manual.
Hope this Helped!
Aug 26, 2009 | Computers & Internet
The computer does not start
Make sure at the very least that the power cable is plugged into the wall (or a UPS) AND into the computer (and it is switched on).
Try power button, if nothing happens then...
Look inside the computer, make sure that you have wires running from the front part of the case (usually near the power button) to some pins on the motherboard...
If not then you need to figure out what wires are what and plug them onto the pins (use the motherboard manual to figure this out, or the internet; google your motherboard name + jumper settings)
Try power button again, if nothing then try another power supply.
Post back if you have any further problems.
May 08, 2009 | Intel Motherboard
Matsonic ms9367e motherboard drivers (Graphic,Sound,Network)
download drivers of matsonic motherboard of different models that r available. see the specification of motherbords. download the ones which have same features as your motherboard
Apr 21, 2009 | Matsonic MS9367E Motherboard
Matsonic MS9337c USB front Painel connector
www.motherboarddiagrams.com has a lot of different diagrams and repair links please try this ok best regards mike
Aug 27, 2008 | Matsonic MS9337c Motherboard
Matsonic pin setings
please help me seach manual for motherboard matsonic ms9158ep
Jun 14, 2008 | Matsonic MS9158EP (DSMTSMS9158EP)...
Jumpers problem
170dd8e.jpg This is a jpg of a modern board. Your board may have more pins. The concept is close. Any difference would be located at the Power led. Your's could be three pins & the speaker could be three pins & neither connector would use the middle hole. I suggest you plug in one connector at a time with a boot up in between. Start with the power switch. Testing is simple, press the case power on button. Pc starts your good no light? Turn the connector around & try again. Next plug in the IDE led. Check for light on power up. Most boards, old & new keep their negetive facing to your right. These negetive wires are colored black & wihte. Positive wires are colored green, blue & red. As long as you do 1 connector at a time you should not have a problem. These are all very low voltage, most just leds. Take your time. It will work out.
Jan 14, 2008 | Matsonic MS8127C (MBMS8127C) Motherboard
Computers & Internet Logo
1,374 people viewed this question
David Payne
David Payne
