Question about Dymo LetraTAG Thermal Label Printer
Label maker not working
Near new Dymo LetraTag XR2003, poor/no printing due to label not feeding through. I have already replaced batteries, cleaned print head and bought new label cassette
  • jtmc Jul 05, 2008
    The Dymo LetraTAG hasn't worked right out of the box. This is the second one with the same problem. The tape won't come through
  • Anonymous Jan 24, 2009
    yes I do
Does a letratag label maker ever run out of ink
No. As mentioned, it is either the weak batteries or dirty print head.
Replace the batteries and clean the print head to improve the quality. If nothing helps, please contact us directly for repair (see dymo.com for contacts).
Oct 13, 2013 | Dymo LetraTAG Thermal Label Printer
My Dymo leaves a blank stripe horizontally in the center of the printing. Have tried new batteries to no avail. Is a thermal burnt out or dirty and can be cleaned or is it a throw away. Thanks a million.
That label maker comes with a head cleaner. It is usually clipped on under the label cartridge cover. Open it and see if it is there. You use that to clean the head.
Aug 09, 2011 | Dymo LetraTAG Thermal Label Printer
When typing the print is faded
Dymo LetraTAGs are thermal printers, so they don't use ink - just batteries and LetraTAG tapes.
When the print starts to fade it's time to put new batteries in. When the batteries are running out the text fades first even when the motor is still feeding tape.
Jan 31, 2011 | Dymo LetraTAG Thermal Label Printer
I have the dymo letratag. no letters come out on the paper. I can not find anywhere to put any ink.
LetraTag label makers are thermal printers, so they don't use ink - just batteries and LetraTAG tapes.
Jan 29, 2011 | Dymo LetraTAG Thermal Label Printer
Can I buy a new print roller for my DYMO LetraTag label maker?
You will need to contact Dymo at 1-800-640-6944 to inquire about the LetraTAG print roller as it is not available online. You can contact them Between Monday to Friday: 9am - 5:30 pm Eastern
Aug 07, 2010 | Dymo LetraTAG Thermal Label Printer
MY DYMO LETRATAG IS TYPING IN REVERSE WITH LOW INKING AS IF IT IS RUNNING OUT. I HAVE PUT A NEW CARTRIDGE IN. WHAT SET UP DO I NEED TO CHANGE PLEASE?
I FOUND THE MANUAL AND DOWNLOADED IT FROM A LINK FROM PREVIOUS QUERY. MIRROR PRINTING IS A STYLE AND THE POOR PRINT IS DUE TO OLD BATTERIES NEED REPLACING.
Jan 25, 2010 | Dymo LetraTAG Thermal Label Printer
Does a DYMO Letratag QX50 have a replaceable ink cartridge?
Yes, DYMO Letratag QX50 ink can be purchased on amazon, click here and take a look Amazon com DYMO Letratag QX50 refills. I hope this was helpful, cheers
Sep 18, 2009 | Dymo LetraTag QX50 Thermal Label Printer
Changing ink?
I had the same problem. I just put in new batteries and it is printing fine. Are your batteries low?
Apr 06, 2009 | Dymo LetraTAG Thermal Label Printer
Won't print
Here is the Dymo site for this issue:
https://global.dymo.com/enUS/RNW/RNW.html?pg=std_alp.php?p_li=&p_accessibility=0&p_page=1&p_cv=&p_pv=2.22&p_prods=21%2C22&p_cats=&p_hidden_prods=&prod_lvl1=21&prod_lvl2=22&p_search_text=&p_new_search=1&p_search_type=answers.search_nl
Type "light print" into the search box and the first result is the link you are looking for.
Here is the text of the link:
Poor Print Quality from Electronic Labelmaker trnsp.gif Question I have an electronic labelmaker that is printing poorly. The print on the label is either very light, incomplete, or striped. How can I resolve this?
trnsp.gif Answer Proceed with the solutions listed below if you have an electronic labelmaker. If you have a LabelWriter printer that is printing poorly, click here.
Solution 1:
Replace the existing batteries with a new/fresh set of alkaline batteries. The print head requires a significant amount of battery power to ensure proper printing on the label. Light print on the label may be an indication that the batteries need to be replaced.
Solution 2:
Replace the existing tape cassette with a new tape cassette. Light printing may be an indication of bad label stock.
Solution 3:
Using the special brush supplied with your labelmaker (located on the inside cover of the cassette compartment) or a cotton swab with a soft solvent (e.g. rubbing alcohol), carefully clean the transporter roller and print head. Dust, dirt, or glue may accumulate on the rubber transport roller or print head inside the cassette compartment and adversely affect print quality.
If the solutions listed above do not resolve the problem, please contact DYMO Technical Support to obtain a Return Material Authorization (RMA) Number.
Obtaining a Return Material Authorization (RMA) Number:
  1. Click the Ask a Question tab at the top of this FAQ.
  2. Fill out the email form completely and include the following information in the Problem Description field:
  • Full Name
  • Full Shipping Address (No PO boxes)
  • Phone Number
  • Date of Purchase
  • Model Name/Number
-hope this helps.
Mar 05, 2008 | Dymo LetraTAG Thermal Label Printer
Dymo LetraTAG Thermal Label Printer Logo
434 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
