Question about Vacuums
I have a modelF5914-900 steamvac cleaner.serial #0704 0011 4711 I cleaned the carpets in my house and then started to do the stairs with the stair attachment. I got down to the last four stairs and the solution would no longer come out. I checked the tank and hose connection and tried priming the pump per the instruction manual. nothing worked. Could you make a suggestion as to what the problem could be? Thank You
    Scholar:
  • 170 Answers
Check fuses goin to the pump, is the pump working? if so you may have an air pocket or a air leak in the intake.
Posted on Apr 13, 2008
    Master:
  • 377 Answers
Check the hose. Take the hose off the vacuum cleaner, if possible. If the clog doesn't shake out, try running something down the hose. Don't poke a hole in the hose.
  • pincer
    pincer Apr 13, 2008
    Fill the steam cleaner with the appropriate amount of cleaning solution and hot water. The instructions on your particular steam cleaner will advise on the amount of solution and water for your particular brand.
    Patience is important when steam cleaning carpets. It is not a task you can hurry along. The slower you move the steam-cleaner along the floors the cleaner your carpets will get.
How doI hook up furniture/stairs attachment
Hoover Steamvac Spinscrub - How To Attach Hose and ...
? 2:54
https://www.youtube.com/watch?v=XTgoEezUlRs
Mar 13, 2011 - Uploaded by Doug Weeks
... spin tool. Used for stairs and stains etc. hand held. ... Hoover Steamvac Spinscrub - How To Attach Hose and Spin Tool ...Every time I attach the upholstery and then turn the vacuum on, water begins to leak from the bottom.
Hoover SteamVac Connecting Hose & Tools F5915900 ...
? 1:41
https://www.youtube.com/watch?v=heAeez1YlFc
Nov 23, 2011 - Uploaded by HooverVideoGuides
How to properly connect the hose and tools ... Hoover VacuumVideo Guides ... I cant get the water to come out the water isnt coming out the spray part to scrub my furniture ... Get Best Price for Hoover SteamVac Carpet Cleaner here ... for the love of god when not using the hand tool where on the machine ...
Hoover SteamVac Connecting Hose & Tools F5912900 ...
? 1:41
https://www.youtube.com/watch?v=fPU9pXgNo98
How to properly connect the hose and tools ... Hoover SteamVac Connecting Hose & Tools F5912900 F5914900 F591... ... Hoover Vacuum Video Guides .... Hoover Steamvac Spinscrub - How ToAttach Hose and Spin Tool ...
Jan 09, 2016 | HOOVER COMPANY Steamvac Deluxe
Model number 5918900
hellllllo......a picture is worth..mmmm....go to youtube there's 20 videos ezzzzz.....tkx....g.scott
Sep 26, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Vax customer support
It is unclear as to whether you have a vacuum cleaner or a carpet
cleaner. When there is no more give you have stretched the hose
to the MAX. Vacuums and carpet cleaners come with stair tools.
If for some reason you do not have these go to a local vacuum
store and tell them what you have and ask them what you may need.
Regards,
Dennis
Aug 19, 2014 | Vacuums
Water leaking from bottom
Trun switch off
Unplug from wall
Remove all clip on parts, remove all covers as far as you can (screws)
clean all parts carefully
put back together ensuring the seals are clean.
Hope this helps a bit
good luck
Jul 13, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
I have a Hoover Deluxe Spin Scrub carpet cleaner that has lost suction. I read the solution by Chris Jones of GoVacuum.com, in which he described the design flaw whereby the tool attachment hose tears at...
A tear in the hose will only affect pick up through the hose when using it to clean furniture, stairs, and such. It will have no effect on the carpet cleaning operation. If the hose cannot be replaced for a while, black electrical tape is one solution to seal the crack.
Mar 29, 2011 | Hoover SteamVac F5914-900 SpinScrub...
How do i hook up my stair cleaner part to my hoover steamvac to clean my carpeted stairs? f5909=900 model
Hi There,
I'll be happy to walk you through step by step how you can attach the hose to your Hoover SteamVac.
Here are step by step instructions for you:
Step 1. To prevent possible leaking, remove
clean solution tank by pressing down on
tank handle (D) and pulling forward; set
tank aside (do not set tank on furniture2_bing.gif).
Remove hose from storage rack.
Step 2: Step on handle release pedal (E) and
lower carpet cleaner handle until it rests
on the floor.
Unlatch back part of recovery tank and
remove lid.
Step 3: Remove recovery tank front panel (F)
by sliding it straight up.
Step 4. Replace panel with converter (G).
Slide converter halfway down opening
until it is firmly in place.
Step 5. Before connecting tube (H) to
cleaner, make sure black tabs are
extended by pulling tan collar toward
tube.
Open door on hood labeled “Stair/
upholstery Cleaning Connection”. Press
round solution tube connector onto
round projection inside door. Press connector
collar down firmly to ensure
that it is fully connected.
Step 6. The tank replaces in a hinge-like
manner. Position front of lid under tabs
(I) on front of tank. Rotate lid down onto
tank.
Make sure lid is secure on all sides
before cleaning.
For full suction, it is important that
the recovery tank lid is properly
secured before cleaning.
Reverse procedure to remove hose
and solution tube.
Raise carpet cleaner2_bing.gif handle to upright
position.
I hope that this was helpful to you in hooking up your Hoover SteamVac hose. If you found this helpful, please be so kind and rate my repair helpful by clicking the 4 thumbs up icons in the top right hand corner of the repair, this is really appreciated.
Thanks again,
Chris J.
GoVacuum.com
Apr 25, 2010 | Hoover SteamVac F5914-900 SpinScrub...
NO DIRECTIONS FOR HOW TO ATTACH AND USE STAIR TOOL FOR MY HOOVER
Here is the link to Hoover's manuals. I could not locate a model F5900-900 But i believe it is F5914-900. Please verify before downloading manual by checking the serial number stick for a model. Its silver and should be on the back or bottom.
Dec 09, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Manual for F5835900
Check the filter inside the dirty water tank. Make sure it has a 1/4 in. gap from the top to the top of the filter.
Nov 14, 2007 | Hoover SteamVac Carpet/Upholstery Deep...
Attaching the attachments
Take off the brush that is on the end of the hose, then attach your stair cleaner on the end of the hose.
Sep 23, 2007 | Hoover F5832-910 SteamVac Supreme Vacuum
Vacuums Logo
80 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
