Question about Proscan PS52690 52" Rear Projection Television
Proscan model 52690
Was working fine child touched menu and now menu button will not bring up menu and it is stuck on channel 25 will not change channel and is also stuck on closed caption. I do not have a remote for this tv
  • Proscan Master
  • 8,617 Answers
You can get the Phillips universal remote that will work that tv at the following link with free shipping. The phillips universal is one of the best remotes for a universal and easiest to program also
http://servicemanuals.vstore.ca/
Posted on Apr 13, 2008
Zenith Z42PT320. I set parental lock code for my son and forgot password. How do I reset or retrieve?
Zenith TV unlock [Child lock]
Tune the television to a channel blocked by a child lock. The words "Enter Lock Code" will appear on the screen with four dashes underneath
Press the numbers on the remote control to enter the child lock pass code to unlock your Zenith television. When the code is entered correctly, the blocked channel becomes visible. The words "Enter Lock Code" remain on the screen if the password is not correct
Enter "0000" if you did not change the password on the television prior to enabling the child lock feature. This number is the default pass code for the child lock.
Push "7777" if you changed the pass code for the television but no longer remember the code. This number allows you to bypass the child lock and watch the programming.
Key lock
Press the "Menu" button on the remote control to access the "Main Menu" screen on the television.
Scroll to "Special" using the up or down arrow buttons and press the right arrow button to access the "Special" sub-menu.
Push the up or down arrow button to highlight "Key Lock" and then press the right arrow button.
Press the up or down arrow button to change "Key Lock" to "No" and then press the "Menu" button to save the setting.
Wish to get more? http://electrohelponline.blogspot.com/
Jun 07, 2013 | Televison & Video
How to change my vivitar vivcam 8025 language preferences....its stuck in some language i dont even know
Press the HOME button to bring up the main menu. Touch the pliers and screwdriver symbol to bring up the setup menu. Language should be the eighth item on this menu.
Dec 27, 2010 | Vivitar ViviCam 8025 Digital Camera
Asko Dryer t760 program menu won't change or is frozen The program menu is stuck on one setting, and the P1, P2, P3, P4 buttons don't change the program. When I try to reset the program (by pressing...
Welcome to FixYa.
By stating "the dryer does work" indicates it is likely an issue with programming.
What are the chances you have the menu lock-out option turned "on"...also referred to as "child lock".
You may quickly rule this out or confirm it is the problem indeed, by trying this.
CHILD-SAFE START
1. Turn the machine off then on.
2. Press ENTER five times, then press P3 five
times. (This must be done within 15 seconds.)
3. “Delayed start” displays with “0” flashing in the
lower right corner. Press the Right Arrow button
to toggle the display to “3.”
**NOTE: Child-Safe Menu Button**
Please note that when you set the child-safe Start
button, the Menu button is automatically
programmed to delay for three seconds before it
becomes active. This prevents a child from
accidentally changing the program settings.
When you want to change a program, press the Menu
button for three seconds to activate the menus. The
Menu button will work normally (without the
three-second delay) until you have completed your
changes. If it is not pressed for two minutes, it will
automatically revert back to the child-safe mode.
Let me know if this indeed solves the problem but either way please keep me posted.
Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
Sep 18, 2010 | Asko T761 Electric Dryer
TV flips through channels at 2 channels per second.
It sounds like a button is stuck or bad. I would spray some electrical cleaner on the buttons 1st. If that don't work, the switch is probably bad.
Jul 23, 2010 | RCA F32645 32" TV
HOW DO I RETUNE MY IN BUILT FREEVIEW ON A SAMSUNG LCD LE40R73DDX 40'' TV. PLEASE ITS VERY URGENT
find the ( d menu ) button on your remote then select ( chanel ) option then select ( auto store ) and press entter ! job done
Sep 29, 2009 | Samsung Televison & Video
Tv is stuck on channel 25
30 YR SERVICE TECH
THER ARE NUMEROUS THINGS THAT MAY HAVE CAUSED YOUR PROBLEM. TAKE IT IN TO A SONY AUTHORIZED SERVICER
Jan 12, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV is not working
If it's 3 weeks old bring it back if you can. There should be at least a 30 day warranty. When the channel and volume buttons on the TV don't work it sounds like something failed.
Oct 19, 2008 | Televison & Video
Toshiba 50HP66--can't change channels anymore
I had this problem. Unplug it while it is powered on. Worked for me.
Sep 08, 2008 | Toshiba 50HP66 50 in. Plasma Television
How to take off child proof lock?
try 0000???
Parental Menu Options
1. Press the MENU and VOL+/VOL- button
2. Press CH+/CH- button to select PASSWORD .
3. Then input the password 0000. It will bring parental menu display on the
screen.
The "Default Password" preset by the manufacturer is
"0000" . If you want to change the preset password to your own password, just
choose any four digits that can be easily remembered and set. Once you set
password for a particular channel, that channel will be blocked.
to reset tv you might have to contact support at this link.
http://www.haier.com/servicesupport/index.asp
Apr 12, 2008 | Haier HLH15BB 15 in. LCD Television
Child lock
press&hold DISPLAY button on hand set& VOLUME button on tv front cabinet. or turn on tv setpower switch while pressing & holding volume + & volume- button on front cabinat.the adjust menu is indicated with each parameter on the screen. hope this helps
Oct 07, 2007 | Televison & Video
Televison & Video Logo
136 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
